09-03-2012, 01:50 AM | #651 |
Windy Corner of a Dirty Street
Re: The Story Of A Cummins Suburban (Lots Of Pics)
Dude, quit with the chit chat and on with the pictures already! Geesh! Where’d dem danm pics!?
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
09-03-2012, 01:55 AM | #652 |
I had a V-8
I'm actually loading some as I type right now. Where are the rest of yours??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
09-03-2012, 02:02 AM | #653 |
I had a V-8
Looks like fun. What's up with your Sub these days??
09-03-2012, 02:15 AM | #654 |
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
09-03-2012, 02:17 AM | #655 | |
My biggest issue is that I am 3 hrs from the closest autoparts store so I cant just run out and grab a part or run to the nearest machine shop to have something made....sure makes it interesting though! |
09-03-2012, 02:25 AM | #656 |
Sorry about the messy response....
Anyway, my fab skills are lacking...severely compared to yours and as much as I know I could build stuff on my own, I fear that it will look like a redneck trainwreck or a buzzbox bomb aftermath. So simple tips are greatly appreciated.... |
09-03-2012, 02:29 AM | #657 |
I had a V-8
How did you clear the frame with the vertical vac pump?? Motor not centered or mounted much higher that I did mine?? It will work. Obviously Dodge did it for the masses, but I don't like it. As far as adapting hydroboost, the only thing that needs to be dealt with is the second return line. Add another nipple to the reservoir or put a "T" in the existing return line. The pump on your Cummins (provided it is out of a Dodge) is a Saginaw (GM) pump, so it will work as designed with hydroboost.
Keep looking on the fuel system. I posted about the pump, the tank, even the lines I bent up for it. I will have to do some looking for the pics on the clutch. I did a whole writeup on it and something happened and the post didn't take and got lost in the bowels of the internet and I never went through and re-did it. The van rear axle was purchased for two reasons. One was it was van width, second was it had 3.73's.
09-03-2012, 03:04 AM | #658 |
Uh..now I m second guessing what I have as far as vacuum pumps go...mine isnt vertical. Its about 8-10" long (hehe) but is horizontal. Ill post a pic tomorrow before work...
The fuel system is fairly simple so I'm sure my plan will work. I plan on running a large fuel filter and separator then a electric fuel pump to a regulator to step it down to a steady and consistent pressure before the lift pump. I chose to do this because I kept reading stories of the lift pumps not supplying enough fuel under load or extreme situations thus causing running issues. Maybe I'm rethinking the wheel here but this is what a lot of the cummins guys are doing. Ive got the stock 3/4 ton axles under the truck now with 4.10's in them. I bought what was supposed to be a mild wheeler with x-over steering, selectable lockers, NP205 splitter kit, hydroboost, brand new 40 gallon fuel tank, dana 60 front and ff14 rear axles and 4.10 gears. I thought I had won the lottery when I found this rig because it had a lot of hat I wanted/ needed for my burb...... WRONG-the dana 60-ff14 ended up being a dana 60 & dana 70 dually set up with 4.56's and lincoln locked axles. At least the axles had been upgraded to disks and converted to single wheel (via hummer wheels and a different hub assembly up front), but still a large expense to re-gear and replace carriers depending on how it was welded. My biggest mistake was having my father in law check it out for me...i told him my plans but there was a huge disconnect because what showed up at my house was a complete rock rig/ basketcase. Anyway, I figured I would try the 4.10's in the stock axles and re-gear the d60-d70 as I see fit afterwards. Pics on the slave mounted to the pedal would be AWESOME!!! Im kind of stuck on that right now.... Last edited by 71CumminsBurb; 09-03-2012 at 03:09 AM. |
09-03-2012, 03:12 AM | #659 |
I had a V-8
Ooof. That sucks. Start a build thread and post pics of what you have so far. Other than the carriers being welded, it doesn't sound too bad.
The vac pump you are describing sounds like a later model unit than I have and yes, those don't interfere with the frame. Never have a pump, mechanical or electric, pull fuel through a filter--always put the filter after the pump. Why keep the lift pump on the motor if you are running electric with a regulator??
09-03-2012, 03:36 AM | #660 | |
09-03-2012, 03:39 AM | #661 |
Last question for the night and if it's in here somewhere and I missed it or forgot about it you can smack me....but are you running a tach and what are you using to create a readable signal?
09-03-2012, 03:51 AM | #662 |
I had a V-8
ISSPRO tach. It uses small magnets epoxied to the balancer and a pick-up mounted to the oil pan rail to create a signal.
09-03-2012, 03:55 AM | #663 |
I had a V-8
So when we left here we were camped on the base of Baker Butte in Valley of the Gods, UT. I didn't get a good pic of the camp but I did get one that was mildy presentable after dark on a timed exposure. It is not as clear as I would have liked, but it is all that I have:
The view when we woke up was fantastic. Ironically, we had cell service and I was able to send a pic of the view to a few people around the country so they too could see what we woke up to: Eventually, we found it necessary to pack up and leave. Larry was first out. Some generic beautiful scenery on the way out: Once we got back on the road we were greeted with this sign--and they mean it: I'm no stranger to narrow dirt shelf roads, but this one was a little creepy for some reason--no idea why. A view of the road from near the top: A view from the top: There are two old square bodies in this picture: Generic scenery on the way to Hall's Crossing. There are six finger mesas in this pic: This area was really cool. It looked like it should have been a dump for industrial waste back in prehistoric times. We made it to Hall's Crossing on Lake Powell. Larry needed gas because he runs a stinky gas engine in his truck that is not very fuel efficient. I really didn't, but decided to top off because I have no idea where we are going and how far it is to get there. I followed Larry to the shack. Our destination is the building directly behind the shack in this pic--maybe forty yards in?? Larry's MIL had a pass of some sort and they rolled in for no charge. My truck had no passengers with a pass so the old battle-axe that was working the booth demanded fifteen dollars to enter the Glen Canyon Recreation Area. I tried to explain to her that I was just going to the gas hut right there and I will be gone in ten minutes and that she would never see me again. In some old battle-axe scratchy voice she rather impolitlely told me that even going that far is using the Glen Canyon Recreation Area and I have to pay fifteen dollars to enter. I paid. When all was said and done I paid just over six dollars a gallon for the fuel I bought. My boy actually does a pretty good impression of the battle-axe demanding her fifteen dollars.
09-03-2012, 08:21 AM | #664 |
GEARHEAD
Filters on the inlet to a pump are used to protect the pump and are common on many fuel injection systems where the pump is not in the tank. The tolerances on the pumps are close and they are too easily messed up. The inlet side filter is usually not as fine as the outlet side so it doesn't hurt the suction head for the pump as much.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
09-03-2012, 08:42 AM | #665 |
GEARHEAD
My favorite. Actually looks like a nice road, condition wise, steep though.
I had to work up in Alaska one summer long ago. Doing boiler inspections up there means traveling a lot of miles in a rental car (among other means) out into the bush. I had a ford thunderbird rental car that I took up to Eagle, AK, north of Chicken, AK. It is just a few miles from the Yukon border. There were a lot of washouts and no other traffic. That made the sphincter tighten up I can tell you. I wonder if I got pics of that trip somewhere. I probably saw more of Alaska in 3 weeks than most Alaskan natives see in their lives.
09-03-2012, 03:51 PM | #666 | |||
I had a V-8
09-03-2012, 06:54 PM | #667 |
Junk Yartist
Can't afford to go get it... stuck in storage
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
09-03-2012, 07:26 PM | #668 | |
Well, until the first winter after that mod....thats when I discovered that a large canister full of diesel wouldn't stay in it's liquid state when exposed to -20 to -40 degreee temps... Last edited by 71CumminsBurb; 09-03-2012 at 07:54 PM. |
09-03-2012, 07:51 PM | #669 |
If you had jerry cans, could Larry have filled them for you?
Maybe next time. |
09-03-2012, 08:09 PM | #670 | |
I had a V-8
I learned a lot of things on this trip. What works, what doesn't, what is good, what is bad, what I should bring, what I brought and didn't use (utilitarian things--not safety/survival items), what I need more of and so on. Changes to the equipment are occurring as we speak (or type??). Really in the whole scheme of things 6.00 a gallon isn't SO bad--probably not even worth a plan B to get around. It was more frustrating than anything I guess having to buy a five day or two week pass to buy a few gallons of fuel that in the end I really didn't need, but I always prefer to head into the wilderness with a full tank just in case..
09-03-2012, 09:35 PM | #671 |
GEARHEAD
The easiest solution is to have Larry go in with the pass, then the passenger walks back out and rides in with you, with the pass.
09-03-2012, 09:48 PM | #672 |
I had a V-8
Uh, yeah. Under normal circumstances maybe, but the battle-axe in the shack would have NEVER permitted THAT. That would have been cheating the Glen Canyon Recreation Area out of fifteen dollars. I wish I could liken her voice to something you would recognize. It was awful. That, coupled with the fact she was a royal bish, just made the whole experience grand. The wimmens that work in the gas shack say that she harasses them about entering if they forget their ID or pass or whatever they have. Makes THEM pay. She has the compassion of an IRS tax collector and the personality of a seasoned DMV agent.
09-03-2012, 10:18 PM | #673 |
Ya, she was a beeoitch!
09-04-2012, 12:14 AM | #674 |
GEARHEAD
09-05-2012, 02:51 AM | #675 |
I had a V-8
So we got back to Hole in the Rock Road. After airing down we hit the trail. The road starts out as barely a low spot in the sand. Larry is making the only tracks this road has seen in quite awhile.
After we got in a ways the road became a bit more discernable: Down the trail a bit we came upon this old soldier: (it was a running driving truck when we got there, but Larry took it for a spin and well, the picture tells the story) I think this may have been the only life form we saw on this trail other than us humans: At this point Larry remembers going down a side road to see something (he was not the trail leader/navigator on that run). We take a right and head off towards some point unknown. Not too far in we come across another relic: Well, we get down the road a bit further and Larry starts questioning our location and whether we are on the right trail or not. Obviously I can be of no help. Now, if you are ever wondering if you are lost and you see this out of your window, the answer is probably and you should probably turn around now: So we turn around and head back to the remnants of the half-track. We get back there and continue down Hole in the Rock Road. We get quite a ways in and we come to a giant slickrock monolith. The trail zigs then zags up the face and then over to an obstacle that we decided would prevent our forward progress. Could we have made it through and continued on?? Probably. The problem with doing things like that where we were is if something bad happens it can turn into alife and/or death situation almost immediately. I would guess we were 4.5-5 hours from the nearest town (not city) and probably six or seven hours from a hospital--just a hospital, not a tauma center. Being in places like this, with our tracks being the only ones in sight, keeps the adventurous side of me a little quiet. Had we been around home and with a few others and closer to civilization, I might have been a little more willing to attempt it, but not where we were. We decided to make this area our camp for the night. Larry was leading so he went up first. He zigged and then zagged to get up the face. It seemed a bit difficult making the turns on the face. I decided to give'r straight up the face. That was the ticket right there.
