Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 06-20-2016, 07:08 PM   #651
doublebeetx
Re: Power Steering Adapter Plates
Can you pm me payment info ? It's time for a bracket.
doublebeetx is offline   Reply With Quote
Old 06-20-2016, 11:45 PM   #652
Captainfab
60-66 Nut
I will send you a PM
Old 06-21-2016, 07:10 AM   #653
doublebeetx
Thank you ! PayPal sent
Old 06-21-2016, 11:37 PM   #654
Captainfab
60-66 Nut
Payment received and adapter plate shipped today.
Old 06-24-2016, 12:55 AM   #655
blakeb
I would like to purchase a power steering adapter. Please email me at blake_burkhart@yahoo.com thank you
blakeb is offline   Reply With Quote
Old 06-25-2016, 12:27 AM   #656
Captainfab
60-66 Nut
Email sent and payment received. Thanks
Old 07-01-2016, 12:38 PM   #657
reed62
reed62's Avatar
Originally Posted by Captainfab View Post
This is the power steering adapter plate that I have been making since 1993. It is of a little different design than the others on the market. With mine you don't need to drill out any threaded holes on the steering box. All four of the steering box bolts go thru the frame. Also there is no inner plate to deal with. I don't feel it is necessary for a 2 wheel drive truck. I've had this same plate on my '66 Suburban since 1993 and put just over 120,000 miles on it with no issues. When I've installed these, I stitch weld the plate to the frame for a little added strength. This isn't absolutely necessary though, since there are four bolts securing it to the frame. The price for this bracket is $55.00 plus $6.30 for shipping in the USA. Included is the bracket as shown and four grade 8 bolts and lock washers. To place an order and for payment information either send me a PM here on the forum or email me at captainfab454@hotmail dot com
For an additional part to go with this adapter plate, see page 6, posts #126 and #137
These adapter plates can also be used on the K series frames that didn't come from the factory with power steering.
Hey Captain,
I have a 62 Chevy C-10 that now has a 67 C-10 cross member setup up front. Will this bracket work with that combination?
reed62 is offline   Reply With Quote
Old 07-01-2016, 11:31 PM   #658
Captainfab
60-66 Nut
The front suspension and crossmember has no affect on the steering box mounting. The frame determines that. Scroll up to post #626 and click on the two links. That will explain the steering box kit that I currently offer for the '60-'62 frames. Let me know.
Originally Posted by reed62 View Post
Hey Captain,
Old 07-02-2016, 12:20 AM   #659
reed62
reed62's Avatar
And I need to notch the top of the frame to make it work? And this will fit any 73-87 C-10 or C-20 p/s box?
If so, I will take one for my 62 C-10.
Thanks,
Randy
Old 07-02-2016, 12:25 AM   #660
Captainfab
60-66 Nut
Yes you will need to notch the top flange of the frame as shown in the links. All '68-'86 C series (C10,20&30) and '87-'91 R (R10,20&30) series steering boxes are interchangeable.
I will send you a PM with ordering and payment info.
Thanks,
Randy
Old 07-06-2016, 10:33 PM   #661
niner1962
hey captain its time for a power steering plate can you pm me on the info?
niner1962 is offline   Reply With Quote
Old 07-06-2016, 11:34 PM   #662
Captainfab
60-66 Nut
I will send you a PM.
Old 07-14-2016, 10:52 PM   #663
niner1962
Received the ps plate .Looks great fast shipping .thanks
Old 07-22-2016, 05:16 PM   #664
SnS C10
SnS C10's Avatar
Hey captain I just sent your payment via paypal. I also sent you a PM. Thanks!
SnS C10 is offline   Reply With Quote
Old 07-22-2016, 11:19 PM   #665
Captainfab
60-66 Nut
Payment received and PM replied to.
Old 08-01-2016, 11:32 AM   #666
SnS C10
SnS C10's Avatar
Captain I got home from vacation yesterday at 6pm. I had the plate and stem/flange installed by 830. Happy to say my 64 is now officially a roller. Great product with clear instructions. Thanks!
Old 08-02-2016, 12:57 AM   #667
Captainfab
60-66 Nut
Thank you for the compliment
Old 08-02-2016, 10:52 AM   #668
mindofmango
I have a 1963 Chevy C10 inline 6 2 wheel drive half ton truck I am changing the original axles to 5 lug being drilled out at a machine shop I'm changing the rear axle bearings and want to know if there is a space between the bearing and Axle or should I put a one piece Timken saver bearing I also need your power steering adapter for a Saginaw rotary valve power steering gear box and I am also considering a 7-inch dual diaphragm power brake set up any thoughts on that conversion
mindofmango is offline   Reply With Quote
Old 08-03-2016, 01:11 AM   #669
Captainfab
60-66 Nut
Sorry but I don't quite understand your axle bearing question, but it sounds like your axles may be worn out? If so, I wouldn't bother spending the money to have them plugged and redrilled.
I have to question why you want to use such a small diameter brake booster.
I am just about out of time to build any more orders before I leave on vacation on the 8th thru the 25th. I would have to receive your payment by the end of tomorrow to be able to build and ship by Friday.
Old 08-03-2016, 05:23 AM   #670
5150
C10 Club Tennessee
5150's Avatar
Hey Cap,
I just bought a 64 service truck with manual steering and I want to add power steering to it. Currently it has a 4 speed on the floor so the steering column does not have a shifter lever. I'm going to install a 700r4 behind the current 250 so I will have to swap steering columns. Tell me what I need to accomplish this
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 08-04-2016, 01:35 AM   #671
Captainfab
60-66 Nut
I have never installed a 700R4, so I do not have any firsthand experience, just what I have read. If you do not want a floor shifter, then yes you will have to install a steering column that has a column shift for an auto trans. The biggest issue if, if your 250 has an original style carb, you will have to fabricate most everything to properly setup your TV cable. If your 250 happens to have a 4bbl carb, then you just need to purchase the TV kit from Bowtie Overdrives.
For the power steering, you will need one of my steering box adapter plates to mount the box to the frame. The difficult part of this, is finding the power steering pump, brackets and pulleys for a 250 I6. Factory brackets are getting harder to find all the time. It is much easier to simply purchase the nice aftermarket brackets made and sold by Davis Racing on ebay.
I won't be able to weld up a steering box adapter plate and ship it until I get back from vacation on the 25th.
Old 08-04-2016, 05:18 AM   #672
5150
C10 Club Tennessee
5150's Avatar
Thanks, I'm in no hurry. I knew most of that, but wasn't sure about how to adapt the TV cable to the original carb. Thanks for bringing that situation to my attention.
Bryan
www.gmtruckshow.com
Old 08-05-2016, 12:41 AM   #673
Captainfab
60-66 Nut
Getting the TV cable connected and the geometry correct is going to be the biggest hurdle. Someone on here posted the beginnings of their attempt at it, but I don't recall seeing an end result. I would contact Bowtie Overdrives and see if they have anything that might help with what you need to accomplish.
Old 08-08-2016, 12:45 AM   #674
Captainfab
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
Old 10-10-2016, 11:42 AM   #675
Clayherndon
Clayherndon is offline   Reply With Quote
