Old 04-24-2011, 06:59 PM   #651
Strodder
Daring to be Different
Strodder's Avatar
Re: Shrunken66Stroker's build thread.
I should have kept on reading. My camera does the same thing. I can't take a upside down picture.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-24-2011, 10:20 PM   #652
shrunken66stroker
shrunken66stroker's Avatar
I had a someone wanting more info on the steering column chop so I'm posting a few pics.
shrunken66stroker is offline   Reply With Quote
Old 04-24-2011, 10:34 PM   #653
paul63c10
thats some darn good looking work you have so far! but, hey i know this is a weird request but can you take a picture of your seats without the headrest on them? i am trying to figure if i want to get bucket seats and leave the head rest off or a new bench seat.
paul63c10 is offline   Reply With Quote
Old 04-24-2011, 10:44 PM   #654
shrunken66stroker
I think it's worth mentioning too that the 3" cut needs to be between where the bolts mount into the column. You need to retain all of the bolt holes for this to work correctly. The trim sleeve just needs about 2" cut off the bottom so it will slide down far enough to bolt back on to the column. Hope this helps.
Old 04-24-2011, 11:00 PM   #655
shrunken66stroker
I already pulled them out of the truck to drill the holes and weld the supports in the floor, repair the trans tunnel and a few other things. I'll probably have them back in the the truck either this week or next, so I'll post pics when I do. They're pretty flush with the bottom of the rear window when the head rests are off. If I remember right it's 1/4" either way. I hope this pic from last week helps.
Old 04-25-2011, 02:27 AM   #656
66 lwb cs
66 lwb cs's Avatar
Thanks`for the pics may go with a tilt wheel to solve my problem build is bad a$$ though
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
Old 04-25-2011, 10:19 AM   #657
Strodder
Strodder's Avatar
I used a tilt wheel from a Camero. The length fit perfect. It bolted right up to the steering shaft too. The only thing was I modified a 73 pedal assembly and bolted the column to that.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-25-2011, 07:46 PM   #658
shrunken66stroker
I like doing things the hard way Dennis. You should know that by now.
Old 04-25-2011, 09:37 PM   #659
Strodder
Strodder's Avatar
This way was a PITA. But didn't have to touch the column.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-25-2011, 10:24 PM   #660
shrunken66stroker
I made some 1/8" plates to reenforce the floor where the outside seat bolts mount and cover the holes where I drilled out the old mounts. I just need to make some for the inner seat/console mounts, clean up the under side of the floor pans and weld them in. Since the engine and trans were in I drilled and bolted the trans cross member. The bolts just happened to line up on either side of where the frame was welded back together after the shortening. After that I took the engine and trans out and filled the holes on the engine mounts that I'm not going to use. I just have to smooth them out.
Old 04-25-2011, 11:22 PM   #661
daverod
SSN 706
daverod's Avatar
Very nice I wish I could get my welds to look like that. Mine stick up more. I'm guessing more heat less wire or just slow down? Mine look more like Strodders.
daverod is offline   Reply With Quote
Old 04-25-2011, 11:59 PM   #662
shrunken66stroker
I wish I could get mine to look more like that too. Those are tig welds that my brother did. He left his tig at my house since we shortened the frame and I've only been using it for the last few months but I love it. I was scared of it for a while but started practicing and I don't want to use the mig anymore. My welds are getting better but they're nowhere near as nice a his. He was a welding teacher for a while at the union he's in, so I guess he's had a lot more instruction and practice than either of us.
Old 04-26-2011, 12:03 AM   #663
Dinos63
chevy only
Dinos63's Avatar
nice work !! I enjoy seeing how you build stuff
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 04-26-2011, 12:07 AM   #664
shrunken66stroker
Likewise.
Old 04-26-2011, 10:08 AM   #665
Strodder
Strodder's Avatar
Greg those welds are beautiful.
Thanks for the nice words Dave. My biggest problem welding is, I can't see what I'm doing. My auto darkening helmet sucks. I should buy a good one, and not from HF. I also think my glass' has something to do with it. They get dark also. I guess I do OK since I'm self taught. What are you guys using, and what did you pay for a good helmet?.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-26-2011, 10:12 AM   #666
daverod
SSN 706
daverod's Avatar
I did'nt say anything bad about your welds. It's just said they don't look as nice and flat as his. I did 'nt know they were tig so that explains it. da. Your welds look very big and strong. I got my auto helmet from HF I think it the best thing I ever bought. There's better stuff? Tell me it's not so. My lens is getting kinda screwed up ma ybe I should get a new one.
Old 04-26-2011, 10:29 AM   #667
Strodder
Strodder's Avatar
I didn't take it that way Dave. Our welds aren't bad, as long as they are strong & have good penetration. I have a good grinder that makes them look better.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-26-2011, 10:53 AM   #668
Strodder
Strodder's Avatar
I just saw this. Pretty cool. I guess I'm not the only one that cleans up his welds. But these didn't need it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-26-2011, 11:45 AM   #669
shrunken66stroker
If I make anything close to that I leave alone and show everyone who comes over.
Old 04-26-2011, 12:24 PM   #670
Strodder
Strodder's Avatar
Yeah I agree they are way too pretty to grind smooth.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-26-2011, 01:40 PM   #671
chad64chevy
chad64chevy's Avatar
man really nice truck! can you show some more pics when you filled the seams on the cab? thanks! and strodder can you send me some more pics of your drip rails? thanks! the picture of the cab and drip rail looks like you just folded it over and filled it!! i like that, and the drip rail between the door and the window what did you do there?? once again really nice truck. i think i'm gonna use some of your ideas on my truck this summer!
chad64chevy is offline   Reply With Quote
Old 04-26-2011, 02:24 PM   #672
daverod
SSN 706
daverod's Avatar
That grinder was wierd there was no sparks. Or was that because it was Al?
Old 04-26-2011, 07:49 PM   #673
shrunken66stroker
Thanks! I basically loaded them full of wire and ground it smooth. I'm going to skim over it with filler when the time comes.
Old 04-26-2011, 07:58 PM   #674
shrunken66stroker
I fit and tacked the plates on the bottom of the cab. I drilled them and then bolted them in to see how they lined up. I didn't have enough time to do the inner seat and console mounts yet. Maybe tomorrow.
Old 05-14-2011, 04:47 PM   #675
shrunken66stroker
It's funny, looking back through my thread I saw when I posted that my son was born. Now he's out "helping" me clean up the garage. Soon he'll be a little road trip buddy and he'll probably end up owning the truck before I know it. Time flies.
1966, bagged, disc, long to short, stroker
