Old 08-13-2009, 09:36 PM   #651
Strodder
Daring to be Different
Strodder's Avatar
Re: Daverods project 66
BTW I meant *****, not BUTCH
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-13-2009, 09:40 PM   #652
daverod
SSN 706
daverod's Avatar
I know what you ment jest mesing with ya. Think I should level my frame?
daverod is offline   Reply With Quote
Old 08-13-2009, 09:43 PM   #653
Strodder
Strodder's Avatar
Duh that's the first thing you should have done.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-13-2009, 09:48 PM   #654
daverod
SSN 706
daverod's Avatar
Duh That why I have you. I just did'nt really see the point. Can't you just measure. Acually I just centered it on the c notch I had from before. Seemed to be quite a bit of room for error. Guess I'll go level it. Could'nt hurt. I can see why now that I've cut so much stuff off it.
Old 08-13-2009, 09:57 PM   #655
Strodder
Strodder's Avatar
Make sure the frame in front of the notch is level, and keep the rear of the notch level. Also check that the top of the notch is level too. You can also check for it to be square, buy measuring it across. (right side in front of notch to the left rear side of the notch. Do that on both sides, and your frame should be square. When your diff goes up all the way it arches. It might not be in the middle of the notch. MEASURE TWICE, WELD ONCE.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-13-2009, 10:04 PM   #656
daverod
SSN 706
daverod's Avatar
As long as it goes up all the way I don't care if it's in the center. I don't want to put everything back together just to see if it centered. I don't think I could tell anyways. I guess I could figure it with a string? Do you have to use lowering blocks to the axle all the way up. In the pic above it looks like thats as far up as it goes. The swing arms are hitting the frame?
Old 08-13-2009, 10:12 PM   #657
Strodder
Strodder's Avatar
But sometimes the axle tube can hit the side of the notch, and can make noise, or won't go down all the way because it's hitting. Believe me I seen a lot of butchered jobs that I repaired. Just trying to give you some knowledge about notches. I've done to many to count.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-13-2009, 11:17 PM   #658
daverod
SSN 706
daverod's Avatar
So if it's done right the swing arm should clear the frame and go up into the notch right? In the picture above it looks as if it hits on the frame? This would be corrected if he would have moved his notch alittle forward right? I'm all about butching. If the notch is moved forward it looks like the back of the swing arm would hit? "Make sure the frame in front of the notch is level, and keep the rear of the notch level. Also check that the top of the notch is level too". Unless it art then it does'nt matter right. Maybe art does'nt work very good ether.
Old 08-14-2009, 07:44 AM   #659
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Do you plan on using your trailing arms for your bags to sit on. Reason I ask is mostly everyone that bags a truck gets rid of the stock trailing arms because it will hit the frame. If they keep them, they either build a back half or Z the rear of the frame. You want your axle tubes to sit center in the notch so when you lower it it wont hit anything. What are you planning on running for link bars?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 08-14-2009, 08:57 AM   #660
daverod
SSN 706
daverod's Avatar
I was going to try to use my stock trailing arms but I guess not any more. I don't see how it would work without some big lowering blocks. The best thing would be to put the arms on the outside of the frame. I guess I'll be looking for some four link stuff. I saw SD has a kit but its $1100.
Old 08-14-2009, 09:34 AM   #661
padresag
why do the notches seem to be backwards to one another
ron
padresag is offline   Reply With Quote
Old 08-14-2009, 09:45 AM   #662
daverod
SSN 706
daverod's Avatar
ron
Because they are. I think it called art.
Old 08-14-2009, 09:49 AM   #663
MacAttack
283 Drama Queen
MacAttack's Avatar
Nah - I think your really meant butch.....
Freudian Slip: or parapraxis, is an error in speech, memory, or physical action that is interpreted as occurring due to the interference of some unconscious ('dynamically repressed') wish, conflict, or train of thought. The concept is thus part of classical psychoanalysis.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 08-14-2009, 10:10 AM   #664
Strodder
Strodder's Avatar
Here's a Triangle 4 link It's only $399.00
And a parrall 4 link for $499.00
This is there link
http://www.kplinks.com/home.php
This is one of the reasons I choose to put the 73 frame on the back half of my 65. There's more options for air bagging.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-14-2009, 11:59 AM   #665
jason65
Registerd User
jason65's Avatar
On the triangle 4 link isn't the spot where it welds to the top of the pumpkin a very weak point cause weld doesn't stick there very well?
jason65 is offline   Reply With Quote
Old 08-14-2009, 12:28 PM   #666
ruffrida2005
Jason yes and no, If you know what your doing you can make a very good weld. You have to preheat the pumpkin first between 300-600 and then weld. Most people dont know how and build a loop over it to attach the end links.
Dave one thing about our trucks is it's hard to 4 link because of how the bed mounts. If you dont care then you can put the links on top of the frame and then to the cent of the alxe. Remember that you have to have atleast 40* or your axle will move side to side. The best and maybe cheapest for you to do it go bag on 2x2 on outside of frame and a wishbone or watts link. If you wanna use round bar for the bags make sure that it's atleast 1.5" and .120 wall or it can bend. You should always have the lower bars adjustable. Just call up SD and let them help ya out. They make some really good links and it's good stuff.
Paul
Old 08-14-2009, 12:52 PM   #667
daverod
SSN 706
daverod's Avatar
I was thinking of making it easy. Seemed like a good deal they even threw in the bags. Sucks I missed the dead line. Still looking around. Sucks even more I'm taking next month off to go hunting so the money tree will be lacking buds. http://67-72chevytrucks.com/vboard/s...d.php?t=353118 I did get some pushrods today so all is not lost.
Old 08-14-2009, 01:04 PM   #668
ruffrida2005
If you talk to Jason personally and buy some other stuff from him,. He'll probably give you a discount. That's what he did when I bought my crossmember from him. One thing you need to tell him that you already have the notch. It's a good kit. I just dont have the money and I backhalfed my truck.
Paul
Old 08-14-2009, 01:34 PM   #669
daverod
SSN 706
daverod's Avatar
I just put all my junk on cl hopefully I'll be getting some $. I think you get 100 off if you don't need the notch. Tell me alittle about what you have for an engine.
Old 08-14-2009, 02:53 PM   #670
jason65
Registerd User
jason65's Avatar
Originally Posted by protrash64 View Post
.....how did lesbians get caught up in this????
Nothing wrong with a couple of them helping out now and then.
Old 08-14-2009, 03:24 PM   #671
Strodder
Strodder's Avatar
That SD kit looks really good. Not a bad price too.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-14-2009, 07:15 PM   #672
ruffrida2005
Well my engine is a 77 4 bolt main 350 out of a sub. Stock crank, bored .30 with flat tops. Stock head that was worked with 2.02/1.60 valves and Z28 springs that will take up to .500 lift. Comp cam 468 lift, Stamped roller tips. AirGap intake, Holley 750, Edelbrock valve covers, edelbrock 110 GPH fuel pump
Paul
Old 08-14-2009, 10:57 PM   #673
daverod
SSN 706
daverod's Avatar
Sweet just looking for ideas for my next.
Old 08-15-2009, 11:15 PM   #674
daverod
SSN 706
daverod's Avatar
Come on money tree!!! Maybe if I talk nice to it it will throw a few buds my way. Put my pushrods in, valves adjusted and intake on. Have to to go the store and get some miracle grow. Ah. To all feds, it's not a real tree. Or is it. Two weeks to get some $$$$$$$$$$$$$$$.
Old 08-16-2009, 01:44 PM   #675
daverod
SSN 706
daverod's Avatar
Any ideas what headers would fit good? Drip edges came right off three wacks. Found some nice rust.
