Old 09-16-2009, 05:49 PM   #651
JohnC
JohnC's Avatar
Re: Glock's new project: "Fred"
Originally Posted by glock35ipsc View Post
Gentlemen, we can rebuild him. We have the technology. We have the capability to build the world's first bionic truck. Fred will be that truck. We can make him better than he was before. Better, stronger, faster.
JohnC is offline   Reply With Quote
Old 09-16-2009, 06:08 PM   #652
Codys87
Codys87's Avatar
On your a/c issue, what if you used a compressor from an earlier vortec 5.7 like whats in the 96 model trucks and used the adapter fittings from this site...
http://www.nostalgicairparts.com/air...n-left-332.php
then had some hoses made to work? The compressor will bolt right up and the belt will work on it also.
85 SWB 6.0 swap/heads/cam/pistons/headers/4L60E/3.73 posi/one piece windows/working towards air bags
04 Avalanche/9 inch lift/wheels 20x12 with 35 inch tires
Codys87 is offline   Reply With Quote
Old 09-16-2009, 06:19 PM   #653
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Have you physically done this yourself? The 96 era 5.7 was a Gen II block, and the compressor was on a bracket on the upper left side. The bolt pattern doesn't look quite the same.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-16-2009, 06:28 PM   #654
Codys87
Codys87's Avatar
I haven't gotten as far as putting the adapters on yet, but the motor is in and the compressor is on. I also have the belt on the compressor right now so I could see if that was atleast right. When I get home I'll try and snap a pic and repost it so you can see what you think.
Old 09-16-2009, 08:01 PM   #655
glock35ipsc
That would be GREAT! If and when possible, I would like to see the adapter at least held into place too. Thanks!!!!
Bob
Old 09-16-2009, 08:20 PM   #656
Codys87
Codys87's Avatar
Heres the pics of my a/c compressor, but I haven't gotten the adapter yet. Honestly didn't know if it would work until I found your thread and found the link to the adapters on here. I have about 2 inches of clearance from the a/c compressor to the frame so I'm not sure why it wouldn't work. I am using the brp motor mount conversion kit though. But it looks like we both may have about the same clearance.
Let me know what you think. I was going to order the adapter tonight.
Last edited by Codys87; 09-16-2009 at 08:23 PM. Reason: didn't copy photos correctly
Old 09-16-2009, 08:24 PM   #657
glock35ipsc
I'm bbq'ing right now, but that looks like it will definitely work!!! I'll be back later on.
Thanks!!!!!
Bob
Old 09-16-2009, 08:28 PM   #658
glock35ipsc
With that flat adapter pointing back, 90* fittings will point them up with little if any interference with the frame.
You say it bolted right up to the AC bracket?
Dude, I think you just solved a major problem for all of us here!!!!
Bob
Old 09-16-2009, 08:38 PM   #659
Codys87
Codys87's Avatar
Cool I was hoping I could help out with all the help I have gotten from everyon else. Yeah the compressor bolted right up. I've been piecing my motor together and when I got the compressor I didn't even realize I didn't get the one that comes on the 5.3's until I already had the motor in and was comparing the setup to my avalanche!!!
Old 09-16-2009, 08:55 PM   #660
glock35ipsc
It looks like the flash washed it out, but is there a part number on the compressor? And you know for sure it is off a 96? This is fantastic, with that flat block and 90* fittings I can't see anywhere this would cause a problem.
Do you have a build thread on here?
Thanks again!!!
Bob
Old 09-16-2009, 09:20 PM   #661
nlped
nlped's Avatar
Dumb question, but is that a much different compressor, or is the motor just sitting higher in the frame? I was looking at your pic, Bob, from post #522 vs. Codys87's and it kinda looks like the motor sits a bit higher. Don't blast me if I am wrong
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-16-2009, 09:23 PM   #662
menace121978
menace121978's Avatar
whoa, i'm i reading this right???
a compressor off a '96 gen II small block bolts right up to the ls motor and clears the frame rails?
how is the compressor quality compare to the newer style?
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-16-2009, 09:40 PM   #663
glock35ipsc
Well, anything is better than the ones like I have.
Bob
Old 09-16-2009, 09:47 PM   #664
glock35ipsc
I think you are right, the upper compressor bolt on his looks to be above the frame rail, where I had to angle mine to clear the rail to get the bolt in the hole.
BUT..... and this is a big but , the manifold on the 96 compressor is flat and exits to the rear, whereas the 06 compressor exits up at about a 45* angle. With the flat manifold block of the 96, a pair of 90* fittings could be ran straight up.
Bob
Old 09-16-2009, 09:50 PM   #665
glock35ipsc
Then again.....
Compare the height of my heater hoses above the frame (barely seen in the top of the pic) to Cody's.
Cody, if you would please, could you measure from the top of your frame to the bottom of the heater hoses? I'll measure mine here in a little bit.
Bob
Old 09-16-2009, 09:56 PM   #666
joe231
joe231's Avatar
looks pretty close by eyeballing it....
CHEVY ONLY
Old 09-16-2009, 10:22 PM   #667
Codys87
Codys87's Avatar
Measuring from the top of the frame rail to the bottom of the heater hose is right at 2 1/2 inches. But I am using a different motor mount set up too.
Give me a day and let me check out and make sure this compressor is the exact same as the 96. Problem with mine is that when I was cleaning it the part number from the sticker rubbed off!!! unless there is another spot on the compressor I could check for a part # I need to go to the parts store and compare some stuff. This compressor looks just like the compressor on my dads 96 Silverado, but with no part # I don't want anyone else to go out and buy one until I'm for sure.
Old 09-16-2009, 11:08 PM   #668
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Wow, this is really turning into an educational experience for all. Bob, you my friend should get an award for build thread of the year.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-16-2009, 11:14 PM   #669
glock35ipsc
Mine is right at 1.5", so you are an inch higher. I still think it might work. But I'm not going to worry about AC until spring, so we have some time to figure it out. Or at least, I do.
OK, Dennis is in need of a pic fix, so here we go:
Bob
Old 09-16-2009, 11:17 PM   #670
nlped
nlped's Avatar
Lookin' Good Mr. Kotter!!!
Carter
Old 09-16-2009, 11:20 PM   #671
glock35ipsc
Thanks dude! I'm blown away that it's at almost 700 posts in just two months! And there's not really that much BS'ing going on. But there has been a TON of great LS swap info brought out in this thread. It will definitely make to task of drawing up a 73-87 LS swap guide a whole lot easier!
Bob
Old 09-16-2009, 11:34 PM   #672
Codys87
Codys87's Avatar
Let me just start off by saying that your build is awesome! It looks so neat and like it came from the factory that way. Very nice!
And after searching like crazy because I don't want to disappoint, I finally found the compressor that I have. It's not a 96 style after all, because one bracket mount is different, but it actually came on the 99-02 5.3.
Two part numbers I found are:
Delphi - cs20010
Delco - 1520413
Also if your heater hoses are 1.5 from the frame rail that would mean you should have a little more room to put the adapter in, right?
Old 09-16-2009, 11:40 PM   #673
menace121978
hahaha! thats sweet Bob. i felt something move below my belt line when i seen that overhead view! i feel better now
this thread is chocked full of great info and pics! excellent job buddy.
"Dennis the Menace"
Old 09-16-2009, 11:53 PM   #674
glock35ipsc
LOL @ Dennis! Thanks man!
Cody - you did not dissapoint brother! Thanks for getting that info! And I think you are right, since mine sits lower I should have a little more room between the block/fittings and the under side of the frame rail.
I'm laying in bed on the Blackberry right now, so I'll check out those part numbers tomorrow. See if I can find who has the best price.
G'nite all!
Bob
Old 09-17-2009, 08:20 AM   #675
JohnC
JohnC's Avatar
Yeah this is a very resourceful thread for LS swaps. If anything it is the iconic one. Soooo much information.
