Old 02-10-2013, 04:25 PM   #651
1980GMC
1980GMC's Avatar
Re: "The Ayatollah of Rusty Hole'a 1987 SWB 6.0 4L80E
Saw an add on Kijiji with what I think is your box on it. Are you partin it out?
Wes
1980 GMC Sierra SCSB-2WD
1986 Chevrolet C10 SCSB-2WD
1980GMC is offline   Reply With Quote
Old 02-10-2013, 08:14 PM   #652
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Yes & no.
Work has been light this winter so I've sold a few things (car, ski-doo & Avalanche) and bought a truck (03 GMC) to share with my wife.
I'm also going to list my '79 GMC this spring and look at moving to Calgary. So in the meantime I've got to downsize & have been selling parts I'm not 100% happy with.
I recently sold the cab & now the blue dash and door panels Chuck recovered for me as I wasn't 100% happy with them either. I'm going to get Connor to do some up for me as soon as I can locate another set at the wreckers.
I'm still working on smoothing the cab firewall, it's going slowly as I only seem to do a little bit each week.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-10-2013, 08:42 PM   #653
old yelr
How do you like the quadrasteer?
old yelr is offline   Reply With Quote
Old 02-10-2013, 09:30 PM   #654
Gordonr1973
Home Built '87
I like it. I never owned a truck from this era before & I'm pleasantly surprised.
The rear end does help steer it, but the wheels don't turn as far as the front by anymeans.
Gordon
Old 02-10-2013, 09:55 PM   #655
Greenlee
Greenlee's Avatar
Looking good Gordon! Still can't believe you started over.
Greenlee is offline   Reply With Quote
Old 02-15-2013, 09:45 PM   #656
|ow|ife
|ow|ife's Avatar
damnit now I'm hooked on this build. And subscribed for updates. Gordy, guys like you make guys like me feel like slackers no matter how good our work turns out...
Keep it up!
it's not what you buy, it's what you build
use your skills, not your wallet
|ow|ife is offline   Reply With Quote
Old 02-18-2013, 08:55 PM   #657
Gordonr1973
Home Built '87
Keep it up!
Thanks guys!
Lowlife: if you do your own work or as much as you can you have all my respect no matter how it turns out, at least you tried!
If you drop off your truck at a shop with a bag 'o cash and a rendering, then I respect the guys at shop that do the work.
Just my point of view
Case in point, my cab isn't perfect, but I did it all myself so I'm to blame....and I can live with that!
Gordon
Old 02-19-2013, 02:49 AM   #658
Devillusion
Devillusion's Avatar
Looks great, wishing I could make some progress on mine. I'm at the stage where it seems like it is going nowhere but I'm hammering away at it daily. God I hate body work after a while...lmao.
Keep up the great work!
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 02-19-2013, 12:44 PM   #659
Slammed66
Needs a Big Block
Slammed66's Avatar
Man, I had a good look at your truck at super run , I was thuroughly impressed
I think your nuts for blowing it all apart again.
With that said, I can't wait to see how it comes together this time..
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 02-24-2013, 03:01 PM   #660
Gordonr1973
Home Built '87
Testing my gaps...needs alot of work!
Gordon
Old 02-24-2013, 05:08 PM   #661
Greenlee
Greenlee's Avatar
Can't wait to see how that hood looks with some paint on it.
Old 02-24-2013, 08:03 PM   #662
Gordonr1973
Home Built '87
I'm slowly getting to it!!
Maybe you might see some primer on it by Friday!!
Gordon
Old 02-24-2013, 08:17 PM   #663
Gordonr1973
Home Built '87
This post is to help out a few guys with aligning their door gaps by themselves....maybe someone has a better way, but this is how I do it:
- I first bolt the hinges to the door. I try to start off with the holes in the same spot as before but if you can't see where the bolts were, just try to center them to start.
- I then try to bolt the hinges to the cab....again trying to get the bolts in the same position on the hinge. You will see wear marks on the hinge where the bolt was tight to the hinge before if you haven't repainted them.
- You can think of the hinges as four points of axis:
1. door bottom can go in or out (bottom hinge on door)
2. door top can go in or out (top hinge on door)
3. door bottom can go left or right (bottom hinge on cab)
4. door top can go left or right (top hinge on cab)
So, as you can see in the pics, I try to support the rear of the door by the handle to the ceiling and the front of the door by the hinge spring to the ceiling. I use ratchet straps as I can get pretty small increments of movement with each click of the ratchet strap.
- I try to get a nice line up and down at the rear of the door to the cab to start....you might have to adjust #1 and #2 for that.
- Remember that the final "flushness" of the rear door line to the cab is going to be set by your door latch bolt
- I then look at the line on top of the door & adjust #3 and #4 for that
- I don't really care about the size of the line at the bottom of the door to the rocker too much, if the line on top of the door is good, the line at the bottom of the door should be good.
- In any case, more people will see the line gap on the top of your door verses getting down and checking your bottom gap....but your bottom gap should be evenly gapped anyways so use that to check how 'level' your door is to your cab rocker.
Usually takes me a while to do this...when I get the doors decent, then I start on the fenders, then the hood. To do those is a whole nother story!
Gordon
Old 02-24-2013, 08:35 PM   #664
1980GMC
1980GMC's Avatar
Trucks lookin great! Are you going with the same pearl white as before?
Wes
Old 02-25-2013, 01:00 PM   #665
Gordonr1973
Home Built '87
I think so, I still have lots of the base coat left over.
I'm going to put all the chrome trim on it this time I think as well.
I have some parts coming tomorrow for my other one so it might be on the road this summer too (even though I might sell it). Will look alot like Squaredaway's truck. -- he has a great looking truck!!
Gordon
Old 03-04-2013, 05:32 PM   #666
|ow|ife
|ow|ife's Avatar
Great posts as always! WHen you get to gapping the fenders and hood, please post a blow by blow like you did with the doors!
Old 03-04-2013, 08:44 PM   #667
squaredaway
squaredaway's Avatar
Thanks, Gordon. I REALLY, REALLY can't wait to get back to North America... 1 more year!
1987 Silverado
6.0/4L80E
5/7 Drop, 20x8.5(245/45)/20x10(295/45) Coy C5s
squaredaway is offline   Reply With Quote
Old 03-05-2013, 07:17 PM   #668
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Great build! I wish I had stuck with the late model LS engine plan. I appreciate the door hanging post, and not as much for the lesson, but for the close ups of the sport mirror brackets. I'm about to mount mine and it's nice to see exactly where they belong!
I can't wait to see yours with some paint on it!
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 03-05-2013, 07:21 PM   #669
Gordonr1973
Home Built '87
Mike
Mike: the passenger door mirror is in the correct location, I'm going to move the drivers mirror further back towards the door handle as it is too far forward right now and it's blocking the vent window from opening!!
Gordon
Old 03-10-2013, 02:21 PM   #670
Gordonr1973
Home Built '87
Couple things are happening the past few days:
- Moved the rear bumper bolts forward 1.5 inches so the sport bumper tucks better (there is a pretty good thread somewhere of how to do this; it was done by the fellow with the SWB silver truck that races it at the track)
- and I am fixing the rusty rear quarter panel. It looked like it got slightly dinged several years ago and they bondo'd it back up.
Gordon
Old 03-10-2013, 07:47 PM   #671
Gordonr1973
Home Built '87
Couple more, pretty much done on this side:
Gordon
Old 03-14-2013, 12:43 AM   #672
Gordonr1973
Home Built '87
Connor emailed me a surprise tonite: I'll post more of the 2 dashes tomorrow!!
Gordon
Old 03-14-2013, 10:49 AM   #673
Gordonr1973
Home Built '87
More:
Gordon
Old 03-14-2013, 10:51 AM   #674
Gordonr1973
Home Built '87
And:
Gordon
Old 03-14-2013, 10:52 AM   #675
Gordonr1973
Home Built '87
And the black dash:
Gordon
