Old 05-12-2019, 09:18 PM   #651
sdwolff98
Turning Wrenches Daily
Re: 1964 GMC 3/4 ton build :D
Annnnnnnnddddddd Lastly project nearing its finish few more things still left to do on the billet mirrors but they are flippin gorgeous!!!!!!!!!!!!!!! Still have to drill the passenger side door holes for the mirror. to mount that mirror in place will be using some aluminum rivet nuts. The driver side however I found some 5/16-18 reducer nuts so the mirror will mount in the factory spot. The bolts that came with the mirrors are 10-24. Note use the base seals he sends with them the factory ones are way to thin.
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 05-13-2019, 12:13 AM   #652
Captainfab
60-66 Nut
Nice progress
Old 05-13-2019, 12:56 AM   #653
sdwolff98
gitting there 1 step 1 piece 1 frustration at a time lol and then going back and redoing till I feel it's perfect in my eyes lol. bout to call this one the forever build CaptainFab lol
Sean
Old 06-16-2019, 05:42 AM   #654
sdwolff98
Well got the hood on all adjusted then this happens lol.. apparently got the wrong hinge set. apparently there are different weights to the chevy/gmc hoods earlier hoods are 30 some pounds lighter then the later hoods??? who'd a thunk that one lol. Luckily American billet has got my hinges to get the right piston on them should have them back next week sometime!
https://youtu.be/Jd-jh2C6tao
Old 06-16-2019, 05:44 AM   #655
sdwolff98
another things that been driving me nuts I have a GPS speedometer but also need a am/fm antenna. Well found something that may work with my speedhut gauges. Took awhile to find the adapter but its all together just waiting on the mag drill to get it mounted to the driverside cowl panel
Sean
Old 06-16-2019, 05:49 AM   #656
sdwolff98
last things I have been currently working on is getting the gas tank mounted inside the bed and the design for the cover. the toolbox idea did not pan out so back at it again lol. so far the tank is aligned nicely just got to work on the cover and the wiring/plumbing issues! I massaged my extra set of suburban fuel tank straps to hold the tank solidly in place to the support frame turned out nice. now to find the rest of the wood needed for the cover....
Sean
Old 06-18-2019, 04:21 PM   #657
sdwolff98
well getting ready to mount the bedsides got these lil beauties in hand for once that happens. Also once bedsides are on figure out the tank plumbing and wiring and get the done. after that keep working on the tank cover lol.. Got more oak in for the cover got the base boards done just need to do rest of the side covers for it. lots more to go but soon be able to at least drive around the block and check engine for codes. It was running rough the first few starts so maybe a miss fire? not sure yet will find out lol
Sean
Old 07-18-2019, 12:16 AM   #658
sdwolff98
getting closer to a test drive got the lokar drive by wire pedal wiring issues worked out. if you use their's pay close attention to the pedal plug wiring diagrams lol not noticing that caused a no pedal issue lol
https://youtu.be/yBQHJR5Gkjc
check it out soon in next few weeks take a test drive to check brakes and parking brake but making progress lol so tickled!!!!
Sean
Old 07-18-2019, 11:25 PM   #659
Captainfab
60-66 Nut
Sounds good Sean Is it next month that you are moving?
Old 07-18-2019, 11:56 PM   #660
sdwolff98
Hi Captain,
Yep August 31st is my last day here at work in the northwest. Flying down to Dallas Ft Worth for some job interviews next week and hopefully get a job offer so we can actively buy a house and move in first week of September!
Still having head light issues on smurf trying to work through them but getting a bit frustrated at the moment lol looking at mounting options as the standard buckets are not working with the lights I got from Dapper lol
Sean
Old 10-04-2019, 05:56 PM   #661
sdwolff98
Have not had time update what with the move back to texas and all. Will be working on updating here soon. Lots has happened some good some horrible. Looks like I will be learning to paint a friend is offering to teach me how. After the 8grand fiasco with the supposed trustyworthy painter I am few up and going to learn on my own. I was able to drive him around the block but apparently either have tuning issues or fuel issues its running really rough. transmission is acting funny as well /sigh Mechanic buddy from dallas will be coming down to plug in his scanner and see if we van figure things out sometime in October!\\Cheers Guys
Sean
Old 11-27-2019, 07:58 PM   #662
sdwolff98
Ok finally at a place I can edit and throw up some photos! Body guy was a waste of 8k and time as you will see in the pics. orange peel rough patches totally screwed on paint. I have a friend in Dallas that's going to come down and help me get this straightened out soon enough. Right now saving pennies for an exhaust system to get the engine lined out lol 2 sets of fouled plugs since o2 sensors are misreading at the moment lol
Sean
Old 11-27-2019, 07:59 PM   #663
sdwolff98
while I have some downtime I have a few things to finish up and fix lol. I got the cross overs finalized on the rear cab speaker corner panels and all wired up except for the speakers for right now.
Sean
Old 11-27-2019, 08:02 PM   #664
sdwolff98
I also recently finished up the tail light harness and have it ready. Just waiting on backup lamp housing and other parts to come in and get things checked out on lighting so pumped when I get this finished. Also crawled up under the truck as the transmission was bucking a bit and found out either A the crossmembers bolts broke off or B I forgot to put bolts back in it lol. Fixing that as we speak. After I get that dealt with going to re look at the Silverado parking brake issue. when the engine is in drive it rolls forward grrrrr…. So I either don't have them adjusted right or the cables are not tight enough. more to come on that one lol!!!!
Sean
Old 05-19-2021, 10:20 PM   #665
Captainfab
60-66 Nut
Here's a bump for Sean
Old 05-19-2021, 11:52 PM   #666
sdwolff98
Lol thanks Captain... I need to update this thread but so much going on I hardly have time to think right now!!!
Sean
Old 05-24-2021, 10:08 PM   #667
Captainfab
60-66 Nut
I know that feeling.......
Sean
Old 06-23-2021, 06:10 PM   #668
sdwolff98
Well its been awhile things in a few spots have changed. had to go back over a few projects till I was completely happy with them. Also things like carpet finally bit the bullet and had a shop do it due to the frustrations at the time. interior is now almost 90% there now. Currently working on getting a backup camera in place and wired in since I had a spare one laying around from another truck project that came into my life lol. but to start off with updates. Engine and transmission are working great.... Buttttttt the fancy racing trans cooler does not like 165 PSI from the allison pump. So that will be on the soon to fix list after I finish the interior installation. got a couple more things to finish there.
Sean
enjoy the pictures
Old 06-23-2021, 06:11 PM   #669
sdwolff98
more pictures. I went back and completely redid the speaker pods I was working on and they turned out excellent. Will be getting stereo cranked up a tuned in very very soon lol..
Sean
Old 06-23-2021, 06:14 PM   #670
sdwolff98
and carpet pictures as I said have had problems with every acc carpet I have bought so decided to take it to a shop in Longview texas and for 700$ they gave me an awesome carpet job. they went all the way up the firewall and in addition did the transmission high hump separate. That way if needed I can pull it to get to sensors on the allison transmission alot easier lol
Old 06-23-2021, 06:18 PM   #671
sdwolff98
and the console is finally specced in and working nicely. had to make some panel adjustments due to the thickness of the carpet setup but totally happy with all of it also gauges are in and working... Here's the thing with speedhut gauges... you have to use their shielded sensor wires.. :/ got everything all plugged into the my nice pretty home built wiring harness and was getting no readings from any of my gauges other then voltage. /sigh all fixed now using their ugly wires. now everything is working great except fuel gauge lol. the speedhut reads 30 as empty and 240 as full... GM silverado tanks are backwards from that so going to have to program the fuel gauge soon
Sean
Old 06-23-2021, 06:20 PM   #672
sdwolff98
also they cheap ebay headlights with additional driving light work very nicely.. grill is done and mounted on the truck. just need to get the head light bezels powder coated and installed. I love how the silverado grill emblems turned out....... which means if I get a set of the back lit ones I can plug them in on the truck lol... maybe more to come on that one still debating it lol
Sean
Old 06-24-2021, 07:54 AM   #673
350TacoZilla
Sorry to hear you got screwed over on the bodywork. Truck is looking good, lots of nice personal touches done.
350TacoZilla is offline   Reply With Quote
Old 06-24-2021, 09:50 AM   #674
88Stanger
88Stanger's Avatar
Truck is looking good!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 08-07-2021, 02:04 PM   #675
sdwolff98
Well been a busy critter last couple of months. Interior panels about finish just need a tweak or two. Was having a hard time finding a spot to mount the trailer brake controller so I got a lil fancy and just made a mount plate for where the old radio was located at. Turned out nice. The face panel for the console I need to redo the mounting brackets and will get to that here soon. oh don't that switch hanging out I will get to fixing that eventually. The switch does not work if fully seated in the housing grrrrr... flopping loose it works just fine lol. I can now say the electric spare tire winch is in full working capacity finally lifted to tire no issues. once I get my spare wheel done it will be up under the truck.
Sean
