Closed Thread
Old 05-31-2014, 07:22 PM   #651
JWSmith
Re: 100's of misc parts from the last 6 trucks parted out
Metal door Panels?
JWSmith is offline
Old 05-31-2014, 10:40 PM   #652
JWSmith
Also need tail light housing x 2
JWSmith is offline
Old 06-01-2014, 12:38 PM   #653
tll74
"Junkyard Dog"
tll74's Avatar
Originally Posted by diver View Post
hi tom,wtb auto.trans.mount for my 1967 k-20. going from 4 speed to auto and tilt colum for k20. THANKS BUTCH zip 30141
Butch are you wanting the rubber mounts that mount the cast iron adapter to the cross member?
Originally Posted by CATCHALLBLUE View Post
69 leaf spring 1 ton dually stake bed with power brakes
Probably could do everything except the rear section that connects just below the firewall on the RH side.
Originally Posted by JWSmith View Post
Metal door Panels?
Metal door panels, 25.00 each
tail light housings, 7.50 each
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline
Old 06-01-2014, 01:20 PM   #654
JWSmith
Pics of either?
JWSmith is offline
Old 06-01-2014, 01:22 PM   #655
69-72
69-72's Avatar
Happen to have a sway bar with brackets?
Zip code 58271
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline
Old 06-01-2014, 03:13 PM   #656
diver
hi,will the rubber mounts work on 4 speed trans. cross member?or will i have to put auto. cross member ? i do not know if 4 speed and auto.cross member are same.i wtb what it takes to put auto. in the 1967 k20.the auto.will be 350.THANK YOU SO MUCH FOR WORKING WITH ME.butch
diver is offline
Old 06-01-2014, 09:38 PM   #657
Youey
Do you have the full gas pedal assembly brackets, and the rod that goes to the carb?
Youey is offline
Old 06-03-2014, 12:54 AM   #658
tll74
"Junkyard Dog"
tll74's Avatar
Pics of either?
Sure..I'll post some soon.
Zip code 58271
2WD? if so yes. Complete with brackets 40.00 plus shipping. I'll get a cost.
Butch, I think they are. I have a true 67 4x4 K20 4sp truck to compare to. I'll let you know.
Yes on the pedal assy that mounts to the firewall. As for the rod are you 2wd or 4wd and what engine size?
Thanks, Tom
tll74 is offline
Old 06-03-2014, 12:05 PM   #659
Youey
350 motor , 2wd was a manual now automatic still has clutch pedal in it.
Youey is offline
Old 06-05-2014, 01:48 PM   #660
69-72
69-72's Avatar
Thanks, Tom
Did you happen to get a shipping quote for the sway bar yet?
69-72 is offline
Old 06-05-2014, 04:36 PM   #661
pimpston65
pimpston65's Avatar
are the headlights still for sale? are the T3's. also any 3 or 4 section telescoping antenna's left
pimpston65 is offline
Old 06-05-2014, 07:48 PM   #662
CATCHALLBLUE
CATCHALLBLUE's Avatar
Going to pass on the brake lines...found out they were not the problem.
Not sure i asked you this yet but do you have a power brake pushrod?
CATCHALLBLUE is offline
Old 06-06-2014, 01:44 AM   #663
tll74
"Junkyard Dog"
tll74's Avatar
pics for JWSmith.
tll74 is offline
Old 06-06-2014, 02:01 AM   #664
tll74
"Junkyard Dog"
tll74's Avatar
I will have in the morning.
35.00 shipped.
I'll check
sorry nothing on the pushrod
hi,will the rubber mounts work on 4 speed trans. cross member?or will i have to put auto. cross member ? i do not know if 4 speed and auto.cross member are same.i wtb what it takes to put auto. in the 1967 .the auto.will be 350.THANK YOU SO MUCH FOR WORKING WITH ME.butch
Butch, I looked at a 67 K20 with a 4sp and a 71 K20 with a TH350 and the crossmember and mounts look to be the same.
Thanks, Tom
tll74 is offline
Old 06-06-2014, 07:24 AM   #665
diver
do you have auto.tilt for 67 k20.zip 30141. thanks again for your time.GOD bless all who reads this. butch
diver is offline
Old 06-06-2014, 09:43 AM   #666
ZackD1212
ZackD1212's Avatar
Right Passenger side dash(defrost) vent and the tubing for it?
Cigarette lighter assembly w/ bezel?
Door to cab rubber seals?
Shipping 62234
Bagged 68 panel 5.3 4L60e
17 Tesla Model S 100D
03 Tahoe
ZackD1212 is offline
Old 06-06-2014, 06:20 PM   #667
tll74
"Junkyard Dog"
tll74's Avatar
Zip code 58271
Shipping is 29.76
tll74 is offline
Old 06-13-2014, 01:41 AM   #668
tll74
"Junkyard Dog"
tll74's Avatar
pic for cst204x4
tll74 is offline
Old 06-13-2014, 05:05 PM   #669
mx289
mx289's Avatar
Hi Tom.
Wondering if you happen to have a set of 4wd SB exhaust manifolds ?
Thank you sir.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline
Old 06-14-2014, 07:55 AM   #670
Elliot949
Elliot949's Avatar
I need all of the upper A-Arm Washers that go between the A-Arms and Frame... Mostly the Concaved Washer that is right next to the frame... Thanks...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline
Old 06-14-2014, 02:59 PM   #671
scrapmetal
Are the 67-68 armrests in pic 1 black? I'm looking for a pair.
scrapmetal is offline
Old 06-14-2014, 08:12 PM   #672
BlackIce
I'm looking for the rear left side taillight harness, 1 e-brake hanger hook,(the hook that holds the e-brake cable thats clip on to the chassis) and 4 row radiator retainers uppers and lowers shipped to 30331..
BlackIce is offline
Old 06-14-2014, 09:10 PM   #673
fastlane
fastlane's Avatar
Hey, got any of the following parts?
* front outer bumper brackets for 69
* full set of deluxe side lights
* power steering hose, pressure and return (for a 73 box) and the clamp that holds them to the frame
* cigarette lighter trim and socket (I have a decent lighter)
* E-brake guide (It attaches to the frame and the cable slides through it)
* License plate lamp
Got any guage bezels without a choke?
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!)
fastlane is offline
Old 06-15-2014, 12:02 AM   #674
firstgencamaros
67-68 2wd LH exhaust manifold original GM nice condition 65.00
Is this still available? It's on the first page. Pic 3. Doesn't say sold but it was a while ago. Please let me know. Shipped to 85233.
FGC
FGC
firstgencamaros is offline
Old 06-16-2014, 12:52 AM   #675
tll74
"Junkyard Dog"
tll74's Avatar
pics for Arrington01 and 67-4x4
Originally Posted by mx289 View Post
Hi Tom.
Thank you sir.
Yes, I do. 160.00 a pair shipped. Acid dipped and media blasted. Very nice pair. Will you be using a heat riser?
12.50 shipped on the concave washers.
No they are olive. 55.00 shipped on a nice pair of black ones.
Taillight harness is all one piece RH and LH. I have many that have been cut up from trailer plug addition. 15.00 for a LH half. 5.00 for e-brake retainer. 40.00 for the 4 core uppers, lowers, and cushions. 8.00 shipping
Not sure if I have that one still if not I have many others.
FGC
tll74 is offline
Closed Thread
