02-08-2015, 08:44 PM | #651 | |
Re: How about some pics of bagged 47-59
I like the bucket seats in the cab. I'm a foot taller than my wife so a bench seat won't work if I want to keep my knees. I've been looking at buckets and split benches. Buckets would give me all the transmission space I need for a LS motor and 4L80. Yours turned out great. Love the exhaust out of the front fenders. |
02-09-2015, 09:58 AM | #652 |
Wicked '57
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
02-10-2015, 05:09 AM | #653 |
Still got to put my bumper on, but this shot still came out pretty awesome. Had to share.
02-10-2015, 09:45 AM | #654 |
Yeah that's a pretty bad azz shot man
02-10-2015, 10:58 AM | #655 |
Very nice. would like to see more of it.
1950 3100 5 window |
02-10-2015, 07:32 PM | #656 |
Amazing picture!!!! Is the smoke from tires, fog, camera trick?
02-11-2015, 12:44 AM | #657 |
02-11-2015, 05:28 PM | #658 |
Some pictures of the interior would be nice. Who did the motor in Phoenix? I'm looking for someone to Hone and assemble my LS motor.
02-12-2015, 12:11 AM | #659 | |
The engine is a straight takeout. All I did was take it apart to paint it. That said, Diego at Desert Auto Works in Mesa, Az is my engine guy. He runs a repair shop but does engine swaps and LS builds also. He has 2 shop trucks, one is a beat up early 90s Chevy with a twin turbo LS and the other is an S10 also with an LS. I don't know which machine shop he uses, but he can do what you need. |
02-12-2015, 12:32 AM | #660 | |
02-12-2015, 11:07 PM | #661 |
02-12-2015, 11:51 PM | #662 |
02-13-2015, 08:31 PM | #663 |
We don't get fog in Seattle - it rains too much
Superbowl *snifs: waah: |
02-14-2015, 10:46 AM | #664 |
Here is my '57. It sits like this with a Jag XJ6 front crossmember and SS6 bags and out back is a torque arm setup from a 4th gen Camaro and 2500 bags. The rear has a very mild 2" c-notch. I did not want to raise the bed floor at all, because I race motorcycles and will use this to haul them and my gear. I succeeded in getting it this low without raising the bed floor.
I will be building a new frame out of 2x4 .190" tubing that will have the Jag IFS as well as a Jag IRS out back. That setup should allow me to lay the body down because the smaller frame will essentially be a 2" body drop and the IRS will allow the wheels to come up higher than the center section, allowing for a stock bed floor.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
02-14-2015, 01:42 PM | #665 |
Nice 57, how much more before it is on the street or is it already. 5.3 also, nice.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
02-14-2015, 06:27 PM | #666 |
A320 Pilot/USAF Retired
OneoffStroker--Love the look of your 57!!!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
02-15-2015, 10:06 AM | #667 | |
Thank You!!
02-16-2015, 01:40 AM | #668 |
Square
my 59 Gordo with front and rear porterbuilt
Squarebody Syndicate |
02-16-2015, 11:31 AM | #669 |
Beautiful truck Broey!
02-16-2015, 05:46 PM | #670 |
02-27-2015, 01:59 AM | #671 |
Couple updated shots from Lone Star Throwdown this weekend. Got the bumper put on and the bed floor in it. Although you can't see the bed floor in the pictures.
05-02-2015, 01:20 AM | #672 |
Gotta jump aboard this post. Beautiful truck Gordo. Mines still got a long way to go, but it's a driver in the works. Bagged and clipped,
05-05-2015, 10:27 AM | #673 |
When you guys are running low or aired out, how much can you turn the wheels? Or are you pretty much only able to go straight ahead? Thanks
05-05-2015, 12:34 PM | #674 | |
At first we had the suspension setup where I had almost lock to lock turning while laid out. It looked goofy with the front wheelbase so narrow compared to the back though so we moved the wheels out some. |
05-05-2015, 05:30 PM | #675 |
"BIGglaSS", I can go stop to stop without rubbing with 6" wheels and 70 series tires. It's all about the offset. With the correct offset you can do amazing things with the steering.
