#651 |
VA72C10
![]() Join Date: Mar 2008
Re: Project#2 67-72 Restoration's Shop truck
Had to take a pic of the new master when we FINALLY saw a fluid drop
New ece drop shocks New brake hose And a daylight pic with the caps on I forgot to post earlier...
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 05-20-2013 at 11:46 PM. |
#652 |
![]() Join Date: Jan 2012
any update on if you got those emblems and tailgate band shipped yet?
#653 |
I've never heard of any brakes being so hard to bleed, it doesn't seem right.
#654 |
VA72C10
Started off the day with several coming over to pick up parts. In between them I got the truck out and organized tools and needed parts. Found the 67 correct drivers outdoor handle I thought I had and got that installed. Then BMERDOC came over and helped get the front clip on ![]() Posted via Mobile Device
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#655 |
How about that! It looks like a complete truck again!! Lol nice work!
-Rus |
#656 | |
VA72C10
#657 |
VA72C10
Had to loosely throw the bumper on. Going to keep it outside tonight for the first time in months since its all buttoned up and no rain in the forecast.
#658 |
It never fails to shock me how much room there is in the engine compartment in these trucks, it just seems so bare compared to modern computerized trucks with all the latest options, it even makes that gen 1 small block seem extra small LOL
#659 |
VA72C10
Got a lot of little things done today that don't look like much. Got the lower 4 core mounts in and mounted the radiator. Will have to come back out for me to install the fan shroud. Painted up the shroud because it was previously painted and needed a fresg coat of satin black. Sprayed the radiator so it will match everything else. Started working on the ground straps.
Posted via Mobile Device Posted via Mobile Device
#660 |
VA72C10
Tons more progress today but doesn't look like much
#661 |
VA72C10
Pics
One of the few original battery trays I've seen with no rust. Looks like they undercoated it when they did the undercarriage and frame. Ground wires and a pic showing the hei and wiring and linkage. Posted via Mobile Device
#662 |
VA72C10
And a picture with the air cleaner I'll be using...had to mock it up real quick since the engine bay is almost done.
#663 |
Very nice! Super clean!
-Rus |
#664 |
man that motor looks saweeeeettt
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#665 |
engine bay looks great bud !!! I like the stock look !!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
#666 |
VA72C10
Thanks guys!
![]() Hope to get a lot further along this weekend and then get it over to Bmerdoc's shop for a final tightening of every bolt, safety check, and the air ride final install since I'll have access to a lift there. Plan to mock up location of the air ride components Saturday and get the rest of the wiring done and hopefully see if it's ready to turn over. Will wait to fire it up until Bmerdoc is here just to be on the safe side in case any troubleshooting is needed or an extra set of hands...
#667 |
VA72C10
No pics today because despite several hours of work there was no visual change. Got the wiper pump lines hooked up and run to the squirters...so I could mount the wiper cowl for good. Got that done and moved back to the wiring. Got the wires all hooked up and.....nothing....looks like there is a break in the wire that (purple) that comes off the starter and provides power to the main fuse block. I am going to have BMERDOC look it over before I start changing out wiring but that looks to be the case...everything else looks good and I verified I have good grounds.
Also lubed up the door and window mechs...the driver's regulator just spins at the handle (has since the first day) So i'll be replacing that. Passenger one seemed tight...until I lubed it up and let it sit for a bit. Now it works fine. Also lubed up the door hinges and vent window pivots. Everything works really well (other than the driver's regulator) and no squeaks either ![]() Got the air ride parts together and figured out the spot I want to put them. I am getting another tank because the one I got from Accuair has no mounting points on it since it's made for exo mounts.....I ordered one tonight with mounting brackets so I can bolt it to the frame crossmember at the rear. The Viair 400C compressor will mount to the back side of the frame and run right into the tank there.
#668 |
VA72C10
It's alive! Well...almost
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 06-06-2013 at 01:16 AM. |
#669 |
VA72C10
Here's a quick picture with the parking lights on. Still have to do some more in-cab wiring and the rear light harness (on its' way) but nice to see it with some power for the first time.
#670 |
VA72C10
It was cool to see the dash light up, battery voltage looked spot on, and the wiper pump was working (I had pushed it a while back so it ran for a second when I first turned the key on) Hazards work but turns don't (assuming since the rear harness isn't hooked up)
#671 |
Thats great man! You'll have this thing on the road for the new owner in no time!
-Rus |
#672 |
Thats great! Its looking more like I'll be down Saturday night. Use water ONLY for now when filling the cooling system until we can get it bled and verify its leak free!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#673 |
Lookin' good! New gig still cool?
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#674 | ||
VA72C10
![]() Quote:
Thanks, new job is very good. A lot of upside potential. If I had a little more time at home it would be absolutely perfect but every job has compromises. This week I will have no nights away and have been able to spend a lot of time catching up with paperwork and designs/quotes for customers, with my family and get a few minutes here and there in the garage.
#675 |
VA72C10
Got a new upper rad hose tonight. Brought one I had with a picture of where it didn't fit and guesstimated based on the ones hanging up. Found one that was supposedly a lower hose for some other vehicle and it looks like it was made to fit the truck going right up and over the fan shroud. Didn't have to trim at all...nice when a plan comes together
