Old 06-15-2017, 12:48 AM   #651
'63GENIII
'63GENIII's Avatar
Re: 1991 V3500 Project Heavy Hauler
Alright Buddy, it's been 10 hours now. I'm on the edge of my seat....
One other thing and I'm reluctant to admit it was 18436572. The darned firing order kept me from starting it for a week or so. The firing order is on the cap and it's different than the older ones. But I know you didn't make that mistake.
In retrospect, that's when I got good at tearing off that plenum! Lol
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 06-15-2017, 03:37 AM   #652
MTCK
MTCK's Avatar
Problem solved. There are TWO timing marks on the front cover. Don't use the one on the bottom. I was about 45 degrees retarded. Took it all apart, noticed the timing mark up high, confirmed valves on #1 were set properly and away we go.
I noticed my oil pressure is pegged at 3:00 so I think I need a new sending unit. I beat it around pretty good to get it to its new home. Maybe I'll take the top of the intake one more time before we go to get our pop up camper this weekend. I do t like not knowing my oil pressure...
Thanks for the help and suggestions!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-16-2017, 08:55 PM   #653
y5mgisi
Second Chance Program
y5mgisi's Avatar
From what i gather, its usually the oil pressure gauge that fails and not usually the sender. But thats just from some gathering around the internet and not from personal experience.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-17-2017, 02:47 AM   #654
MTCK
MTCK's Avatar
This one was actually the sender, but through no fault of its own. It got beat up a little bit going in and out of the truck with my various attempts at building the correct combination of fittings for it to fit. The electrical tab actually broke off the top, hence the open circuit. New sender is installed.
Also bed is wired for camper, mounts and pad are on and tailgate is off. Tomorrow is the day. Wired the lights from the rear using a 25' 4 wire trailer kit, and power and ground from my auxiliary battery with 10 awg wire and fuses at both ends.
-Marcus
Project Plow Truck
Old 06-17-2017, 10:20 AM   #655
Greenlee
Greenlee's Avatar
Sweet! Have a safe trip and post pics of the new camper.
Greenlee is offline   Reply With Quote
Old 06-20-2017, 03:34 AM   #656
MTCK
MTCK's Avatar
Where to start... I guess I should probably say that nobody got hurt, and the camper is awesome. Other than that... holy cow.
Hit the road early Saturday AM. My wife and son flew down to Anchorage the day before to do a little shopping and visit friends. Around 150 miles into the trip I noticed my trans temp starting to climb. With much drama I limped back home in 3rd gear at about 50 mph. I had to push the truck back into my driveway. Transmission is cooked. I knew this was coming but thought I could nurse it along a little further. The GPS had good vision on our ETA.
-Marcus
Project Plow Truck
Old 06-20-2017, 03:41 AM   #657
MTCK
MTCK's Avatar
Pushing this mission back was not an option. My and my wife's work schedules are not the easiest to align and the camper had been squatting at a friend's house for over a month. When I got home I rented a 2004 F350 crew cab diesel. It was the only long bed in town that was available.
I picked up some wire and plug ends from Napa and built an umbilical to run from the trailer plug up to the front of the camper. By noon I was back on the road. All in I did a little over 700 miles on Saturday.
More tomorrow.
-Marcus
Project Plow Truck
Old 06-20-2017, 04:46 AM   #658
watahyahknow
watahyahknow's Avatar
maibe buy a towbar and rent a bigger dually , that way you can get the whole combo back home
couldnt you just stop for the day and let everything cool off
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 06-20-2017, 08:36 AM   #659
Greenlee
Greenlee's Avatar
Damn. I am sorry to hear that. I clicked on here hoping to see pics of the old girl with the camper on the back.
These old trucks can test your patience at times. We have a camper and a boat and my old k10 was my only tow vehicle for the last few years. A fuel pump that I had recently replaced crapped out on me on a vacation with the boat. I ended up having to have the truck and boat towed off the highway. Then I had an electrical gremlin that would cause the entire truck to lose power. The last time it did it I had it towed home. As soon as I got it home, it fired right up. I actually think the old truck is pretty reliable and we just had some bad luck. Even so, I bought another vehicle I can tow with a few months ago because I was tired of hearing my wife ***** about it! The "new" tow vehicle is a 2012 Yukon Denali AWD with 6.2.
Old 06-20-2017, 11:21 AM   #660
MTCK
MTCK's Avatar
Yeah it's frustrating when you are counting on them to work and they don't. Keep reading though, new vehicles are not immune to problems!
Sunday mid day we headed over to pick up the camper. Getting it installed was fairly uneventful other than the mount brackets being too wide to clear the jack legs. Then the fun started. Plugged in my umbilical for lights, and no lights. The plug on the truck looked terrible and had about four different adapters between the truck and the plug. Two hours, a multimeter, two fuses, and a solder gun later the camper was hard wired to the truck.
-Marcus
Project Plow Truck
Old 06-20-2017, 12:32 PM   #661
'63GENIII
'63GENIII's Avatar
NOOOOOOOO! You broke one of my favorite bullet proof Square Bodies! Damn Marcus, that blows although I know how it feels. We are leaving tomorrow with the boat, kids and all the camping gear in the '63. My boy said last night "Dad, this thing is gonna run forever". I'm not normally superstitious but......
Hope you get the ol girl fixed soon. Have fun on your trip meantime and be safe!
Chris
'63 k15 long step
Old 06-20-2017, 01:06 PM   #662
MTCK
MTCK's Avatar
It fit. Loaded up the wife and kid and headed north. Filled the propane up and stopped at a new state campground just south of Denali. We popped the top, fired up the furnace and made our beds. It was great being warm and inside moments after shutting off the engine. This is the whole point.
-Marcus
Project Plow Truck
Old 06-20-2017, 01:20 PM   #663
MTCK
MTCK's Avatar
After some good rest, we grabbed some leftovers out of the fridge (compressor style, 2 batteries and a solar panel of unknown wattage), dropped the top and headed up the road. I was not that impressed with the 6.0 powerstroke's grunt and we only got about 12 mpg.
With about 140 miles to go (close to where I turned the chevy around), I noticed what seemed like a lot of exhaust coming out the tailpipe. I asked my wife to adjust the mirror and sure enough she was smoking. I pulled over half way through a construction site and smelled the odor of glycol. Great. I elected to try to make it about 5 miles to the next town so we could wait for the wrecker at a diner instead of a gravel pit.
-Marcus
Project Plow Truck
Old 06-20-2017, 03:14 PM   #664
'63GENIII
'63GENIII's Avatar
No way. Those 6.0s are supposedly great if they get the "bulletproof" kit which involves studding the heads. Guess that's why.
Tell me the story gets better Marcus
Chris
'63 k15 long step
Old 06-21-2017, 02:24 AM   #665
MTCK
MTCK's Avatar
On the drive to the diner, the truck stopped smoking so I kept an eye on the gauges and limped along. Twice the temp gauge started to climb, so I pulled over and added coolant. Temps came back down and every time I started from a stop it belched steam for a mile or two. Finally got home about three hours behind schedule and unloaded the camper. Rental ford is returned so I'm back to one broken truck and one great camper. Hopefully I can get it in for a rebuild before the big 4th of July weekend road and camping trip.
-Marcus
Project Plow Truck
Old 06-21-2017, 12:38 PM   #666
daddyjeep
daddyjeep's Avatar
The GPS part is too funny. Sorry to hear about the tranny issues, but that is a sweet camper.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 06-21-2017, 03:25 PM   #667
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Man, what an ordeal. That stinks about the trans but at least you made it back home with it. That's the best kind of truck. The one that doesn't leave you stranded. I'm betting the EGR cooler is toast on the 6.0. Pretty common problem. When I read you got an 04 I was like, yep, I see where this is going. 6.0's are good after you drop $3-5k on them. Then they get 15-17mpg and will live at 375-450hp pretty nicely. Nice to see you got the camper back home. I've had similar starts to a road trip and similar failures along the way. I feel for ya.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-21-2017, 11:47 PM   #668
Greenlee
Greenlee's Avatar
That camper is awesome. What a trip!
I hope you get the old Chevy up and going before your vacation. On the bright side, once you get the transmission rebuilt the truck should be pretty much worry free since you will have replaced or rebuilt the entire drivetrain.
Old 07-14-2017, 03:18 AM   #669
MTCK
MTCK's Avatar
Thanks guys. Rebuilt transmission shifts great. Leaves really hard now and wheel spin is an issue if I'm not carefull (totally empty obviously). The love connection is about to happen.
-Marcus
Project Plow Truck
Old 07-14-2017, 03:36 AM   #670
whitels1
whitels1's Avatar
Awesome man, glad you got her going!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 07-14-2017, 12:47 PM   #671
daddyjeep
daddyjeep's Avatar
Glad you got it going again. I am not real sure if you need to share pics of the "love connection". That could get a little personal.
04 1500 crew cab
Old 07-16-2017, 11:06 PM   #672
MTCK
MTCK's Avatar
The love connection was tight. If my tires were any wider I would have to do something to spread the front jacks. Rubbed quite a bit. This is t something you would want to do every day.
-Marcus
Project Plow Truck
Old 07-16-2017, 11:09 PM   #673
MTCK
MTCK's Avatar
This thing is huge. Cab over is about 8' off the ground.
-Marcus
Project Plow Truck
Old 07-16-2017, 11:14 PM   #674
MTCK
MTCK's Avatar
Stance is pretty spot on. Full fuel both tanks, full propane and water in the camper.
-Marcus
Project Plow Truck
Old 07-16-2017, 11:23 PM   #675
MTCK
MTCK's Avatar
Closed it up and ran some errands. Rides like a caddy. Can feel the weight. Trans never got above 180. Went fast, slow, even crawled around a bit.
-Marcus
Project Plow Truck
