Old 10-27-2021, 12:50 AM   #651
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC “Project Splice”
Alright, I was finally able to get rid of the "wave" that I was getting on the pillar. Turns out I was oversanding where the gas cap used to be. I also continued around the indents and even started filling inside of one indent. I added some new blocks to my collection as well to help with those small details.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 10-27-2021, 02:32 PM   #652
sakustoms
those are cool. where did you pick those up?
sakustoms is offline   Reply With Quote
Old 10-27-2021, 02:44 PM   #653
Kronald_70GMC
They are from Big Kid Blocks. I just found out about them earlier this year and I love their products. I got their door gap tool and initiation block kit earlier and I absolutely love them.
Kyle
IG: kyle_ronald
Old 10-28-2021, 10:36 AM   #654
sakustoms
Awesome. I will check them out when the time comes.
Old 10-29-2021, 01:38 AM   #655
Kronald_70GMC
The first recess section on the back of the cab is complete. The new mini blocks work awesome!
Kyle
IG: kyle_ronald
Old 10-29-2021, 08:11 AM   #656
sakustoms
Man you are really going all out. That's a lot of bodywork to be doing for an area you will never see when the bed is on. Unless you're running a flatbed. LOL
Old 10-29-2021, 10:44 AM   #657
Kronald_70GMC
Haha no flatbed. I don't know about never seeing it though. My dad's truck is all together and I can see the back of the cab pretty decently.
Kyle
IG: kyle_ronald
Old 10-29-2021, 11:21 AM   #658
sakustoms
Wow really? Most C10s I see the bed is so close to the cab I literally see the rounded back of the cab and a few inches in. Hmm. Guess I'll need to test fit the bed on my kid's truck before finishing bodywork. LOL
Thanks for the extra work.
Old 10-30-2021, 01:19 AM   #659
Kronald_70GMC
Haha I'm also just super picky. I have noticed that these trucks have very different tolerances from each other sometimes. Maybe it's just a Canadian thing.
Kyle
IG: kyle_ronald
Old 10-31-2021, 05:26 PM   #660
Kronald_70GMC
Getting close to done with indentations on the back of the cab. The first three just need a few small touch ups and they are done. The fourth needs a sand and probably a few touch ups and the fifth has one coat and will need another for sure and maybe touchups.
While I have been waiting for the mud to cure, I have been adjusting some other things that have been bothering me which included the roof rail right where the winsheild pillar meets it. I dont know what happened there but it was not pretty. It also looked nothing like the passenger side so I decided to grind out a bunch of excess metal leaving me with a small hole to weld up. I forgot to take a before picture but I assure you it was ugly.
Kyle
IG: kyle_ronald
Old 11-03-2021, 10:31 PM   #661
BigBird05
I have spent the last 2 hrs reading about your truck. Wow! Not being a body man could you explain to me what you mean by lay down or laying in wire? I think you are about 2 years ahead of me on your truck.
BigBird05 is offline   Reply With Quote
Old 11-03-2021, 10:36 PM   #662
Kronald_70GMC
Thanks for the read, it's awesome that people are interested in my project. Id love to help you out but could you be a bit more specific on what you are after? Are you referring to when I was putting a piece of wire along my rocker?
Kyle
IG: kyle_ronald
Old 11-03-2021, 10:44 PM   #663
BigBird05
Yes you were cutting open the rocker and adding wire.
Old 11-03-2021, 10:52 PM   #664
Kronald_70GMC
Yes so there were a few spots where the panels just weren't meeting up where they should have been so I would just slice it and then I would pull it the where everything lined up and sometimes I was left with quite a large gap. Some areas were around 3/8". So what I ended up doing is I picked up some lengths of 1/8" steel rod and I would use it to help me fill in those larger gaps. It was a bit of work because I would then have to make tacks on both sides of the wire until it was all smoothed up but it was better than attempting to bridge the large gap with just weld. Hope this helps.
Kyle
IG: kyle_ronald
Old 11-04-2021, 01:05 AM   #665
Kronald_70GMC
Couple more small touch ups to sand in the last two indentations and they are done. After that, I plan to block my cart up a bit to get it to a comfortable working height to fill the cab corners and rockers. Getting closer and closer to seeing some primer!
Kyle
IG: kyle_ronald
Old 11-04-2021, 06:58 AM   #666
BigBird05
Thanks.
Old 11-05-2021, 11:47 AM   #667
sakustoms
Looking good.
I used tig wire to help close up the door gaps and to expand and shape the one rocker.
Old 11-08-2021, 07:00 PM   #668
May70
May70's Avatar
Lots of sanding but looking good. Dreading that part.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 11-09-2021, 12:20 AM   #669
Kronald_70GMC
Thank you! It is alot of sanding but it is very rewarding to see everything form up and come together as one smooth piece. It's not as bad as it seems. Just tackle it one piece at a time.
Kyle
IG: kyle_ronald
Old 11-09-2021, 12:24 AM   #670
Kronald_70GMC
Well I finally finished up all those glorious indents. I even just about finished up the passenger pillar to the lower body line. Still clinging to that first can of bondo. I have enough for one more mix on the ol' oinion board. Next will be touch up of the door openings and then I'll lift the whole cart to work on the cab corners and rockers.
Kyle
IG: kyle_ronald
Old 11-10-2021, 12:18 AM   #671
Kronald_70GMC
Started the finishing touches in the passenger door jamb tonight.
Kyle
IG: kyle_ronald
Old 11-11-2021, 08:21 PM   #672
Kronald_70GMC
My Big Kid Blocks are showing me more areas where my old blocks just weren't cutting it. I'm getting a much better result this time around. Everything is coming along nicely.
Kyle
IG: kyle_ronald
Old 11-12-2021, 09:34 AM   #673
BigBird05
Now that I have found this thread I am reading everyone. Are you going to be painting it yourself? If so tell us amatures every step and the produces you are using.
Old 11-12-2021, 11:12 AM   #674
Kronald_70GMC
Haha I will be painting it myself but I'm a while from paint and certainly no expert. I will share everything that I know about painting once I get to that stage and hopefully it will help some others. I'm glad your following along and everything I do will be posted here.
Kyle
IG: kyle_ronald
Old 11-12-2021, 09:00 PM   #675
Kronald_70GMC
So I have been waiting for some larger casters for my cab cart to go on sale and they finally have! I got these 8" 1200 LB bad boys for 25$ a piece today, regular 60$ a piece. For sure overkill but I wanted more height anyway and the locks on the old casters were pretty fubar'ed. Also being only 3", they were not fun to get back up onto my rubber garage floor when I'd move the cab to the other side for cleaning. Now if only the last dude didn't weld the damn things on. Turns out that a Sawzall with a good blade cuts them off pretty decently. Now the worst part is that I've already sacrificed 2 drill bits to the metal gods and I was already low on the things to begin with so I guess this will have to wait until I can get more bits.
Kyle
IG: kyle_ronald
