Closed Thread
Old 06-19-2018, 08:54 PM   #6876
Metaldoc
Metaldoc's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by weq92f View Post
Haven't gotten that for yet! It should as it's the long pump and the cover is dented inward.
-klb
Sorry man I thought it was pushed out towards the water pump. Your good.
Metaldoc is offline
Old 06-19-2018, 09:23 PM   #6877
Redneck Rydes
Redneck Rydes's Avatar
When we use to use cam buttons,they had needle bearings in them and we welded a piece of steel on the inside of the timing cover so it would not where a hole in it.
Redneck Rydes is offline
Old 06-19-2018, 10:59 PM   #6878
VWNate1
VWNate1's Avatar
Question Re: Cam Shaft Install
? Did you really install it sans lube on the lobes and bearing surfaces ? .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-19-2018, 11:12 PM   #6879
weq92f
weq92f's Avatar
I used permatex ultra slick engine assembly lube on it. You can see it if you look real close at the image. I'll hit the lobes again before final assembly and startup.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 06-19-2018, 11:38 PM   #6880
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Cool .
You had me worried for a moment there .
-Nate
Geezer
VWNate1 is offline
Old 06-22-2018, 04:41 PM   #6881
KeepRMovin
KeepRMovin's Avatar
Well it didn't happen today, but last week! Brought home my first C10! Couldn't be more exited, and have been diving into this forum for a while now, finally have something to post about!
1969 C10
Freshly rebuilt 383, still learning about the motor and the truck itself. Pretty new to this world! Body is in great shape, zero rust. Fresh undercoat/seal and paint.
KeepRMovin is offline
Old 06-22-2018, 05:04 PM   #6882
BRL
BRL's Avatar
Originally Posted by KeepRMovin View Post
...1969 C10...
...um where?
Just kidding, looks real nice!
Welcome to the forum!
BRL is offline
Old 06-22-2018, 05:23 PM   #6883
KeepRMovin
KeepRMovin's Avatar
Originally Posted by BRL View Post
...um where?
Haha, Thanks! I was trying to wait until I got some good non parking lot pictures, but I couldn't hold out any longer
Old 06-22-2018, 05:29 PM   #6884
BRL
BRL's Avatar
Oh, to me it looks like a 67/68 hood, a GMC grill, and a more modern stepside bed (which I like).
Yep, more pictures is good!
Very cool!
BRL is offline
Old 06-22-2018, 05:40 PM   #6885
KeepRMovin
KeepRMovin's Avatar
Very cool!
Good eye!
It is a modified 1969 GMC C10 I guess, the bed is an 80's stepside, not sure on the year of the hood. I'll definitely get some more pictures up, love all the knowledge on here!
Old 06-22-2018, 07:24 PM   #6886
palallin
We put my truck's front end up on jackstands today and pulled the front drums and brake hardware. Tomorrow, I'll install new wheel cylinders and rubber lines as well as all new hardware and shoes. I also have a Master Cylinder on order; if it gets here, it will go on, too.
I've had problems with the passenger side sticking, so I am replacing everything but the hard lines.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline
Old 06-22-2018, 09:18 PM   #6887
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Originally Posted by BruceKoukalaka View Post
Here are the pics of my truck, I'm not sure if it is a '69 or a '70. Maybe someone can determine it by the VIN.
Welcome to the boards from Saskatoon. Your truck is a 1969 and I've attached a serial number decoder for you.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 06-22-2018, 09:35 PM   #6888
Andy4639
Old member
Andy4639's Avatar
I finally broke down and cleaned the 67 Ramp truck. I washed it off cleaned the inside up good. Vacuumed it out and wiped all the windows with cleaner then rain x!
Looks much better oh and fixed the cig lighter and installed my 2018 HRPT front tag.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 06-23-2018, 02:01 PM   #6889
BruceKoukalaka
Thanks for the decoding, I wasn't sure what I had until I saw this, Now I know mine's a 1969 Chevy C10 that originally had a V8, (I thought it had a 6 mated to the 4 speed.
BruceKoukalaka is offline
Old 06-23-2018, 09:48 PM   #6890
palallin
OK, well today went reasonably well. I managed to replace both wheel cylinders and front hoses. Those old hoses were in bad shape, and I doubt much fluid was moving in them.
Replacing the wheel cylinders requires removing the hubs, so the outer bearings got a cleanup and regreasing, and the engagement gears were all inspected and reset.
Replacing the hoses ended up requiring the removal of the hard lines and the junction block inside the frame on the driver's side--what a pain in the rump.
Take my advice: if you ever have your front clip off or the engine out--or, better yet, both--replace those hoses! It would be a LOT easier to do unimpeded by such inconvenient parts as the power steering pump, the fuel pump (I had to disconnect the fuel line), and so forth!
Your hoses probably need replaced anyway. Mine sure did.
TOMORROW: actually fitting the brake shoes and attendant hardware and, I hope, the new master cylinder.
palallin is offline
Old 06-23-2018, 11:27 PM   #6891
Drummerboy
Drummerboy's Avatar
I picked up some 15x6 steel wheels so I can run steelies on with my new disc brakes.
Drummerboy is offline
Old 06-24-2018, 01:43 PM   #6892
weq92f
weq92f's Avatar
Decided to pull the pan to replace the gasket....
Bad idea... not enough room...
Now I own a 2 ton engine hoist!
-klb
weq92f is offline
Old 06-24-2018, 01:49 PM   #6893
Boog
laying low
Boog's Avatar
Oh but there are other uses for that hoist. I use mine several times a year at home. I don't pull and lift some of the things I used to.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 06-24-2018, 03:10 PM   #6894
KQQL IT
At the body shop.
KQQL IT's Avatar
Finally got my M/T challengers on.
New lugnuts are on their way the old ones really look bad, and my short center cap was to short in the back.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline
Old 06-24-2018, 04:30 PM   #6895
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Those engine hoists are neat .
Just remember to collapse the cylinder completely every time you're finished using it else the ram will rust and begin to leak, ruining it .
-Nate
Geezer
VWNate1 is offline
Old 06-24-2018, 05:20 PM   #6896
ohboy321
ohboy321's Avatar
I pulled my bench seat out today to fix a squeak behind it, and to take some pictures to see what I will need to fix it up over the winter. Found the tag that IDs it as a basic 69 (cab is a 67), and that it needs several springs replaced right under the drivers arse. Got the tracks sliding nice....fixed the squeak, put the seat back in and took it for a nice ride. Plus, today was Vintage Truck magazines "Drive Your Old Truck Day 2018", and I wanted to get out a few times....like I need an excuse
ohboy321 is offline
Old 06-24-2018, 09:23 PM   #6897
palallin
Day 3: Church, shopping, and rain all conspired to shorten the working time, so all we got accomplished today was the mounting of the brake shoes and hardware. I slipped the drums on just to make sure nothing gets jostled or rained on tonight.
Oh, yeah, and I reattached the fuel line to the pump.
Tomorrow (rain dependent): Master cylinder and bleeding. Oh, how I hope the penetrant I put on those rear bleeders works!
palallin is offline
Old 06-24-2018, 10:02 PM   #6898
VWNate1
VWNate1's Avatar
Exclamation Frozen Bleeders
This is a common problem, the solution is fairly simple :
Right after you spray the next shot of penetrating oil on the threads, *SMACK* the bleeder screw dead on with a hammer, the shock will wick the penetrant in and loosen the threads .
If you smack it off center or sideways, you'll snap it off so pay close attention here .
I'm sure you already know to only use a SIX POINTED tool on any bleeder valve ! .
-Nate
Geezer
VWNate1 is offline
Old 06-25-2018, 03:13 AM   #6899
Killer Bee
Killer Bee's Avatar
^^^ yep, they come in real handy.. had this fully welded hoosier about 25 years..
stripped and repainted several years ago with clark forklift hot yellow green so I can't lose it..
welded a handle bar on the mast with bycycle hand grips to make it easier to steer..
got a 12vdc 1gal barnes hydraulic power unit for it, just haven't hooked it up yet..
that D60 is about 500lbs, good portable hoist made short work unloading it recently..
Killer Bee is offline
Old 06-25-2018, 05:23 PM   #6900
NoStopN
NoStopN's Avatar
Originally Posted by VWNate1 View Post
Right after you spray the next shot of penetrating oil on the threads, *SMACK* the bleeder screw dead on with a hammer, the shock will wick the penetrant in and loosen the threads.
Words you never want to say around me. I could snap it off even using a plastic Playskool hammer.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Closed Thread
