07-13-2018, 06:27 PM | #6951 |
laying low
Re: What did you do to your truck today? Chapter II
Care to share the low down on the brake pedal swap?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-13-2018, 06:54 PM | #6952 |
Who Changed This?
Going to flush the cooling system. Changed the heater hoses, since they've been on there for 10+ years, and had cheesy shutoff valves in them that my FiL installed. I don't know why, since they were open and the heater core doesn't leak.
Looks like I need the kick panel vacuum actuator. This is for the flap that regulates inside or outside air for the AC. Anyone know a part number other than the LMC or other aftermarket vendor? It lives (and died) at the top of the heater core, just above the heater hoses. I'd like to get it done with locally sourced parts, but ain't having much luck finding one. Went to a local parts store, and the guy started looking through the vacuum advance pix for it.
07-13-2018, 08:43 PM | #6953 | |
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
07-13-2018, 08:51 PM | #6954 |
Test fit the rotor and caliper. Wilwood said these calipers would not fit with the CPP modular spindle. They fit like a glove! Buttoning this up tomorrow so it can go back on the ground for the first time in a couple of months.
07-13-2018, 09:03 PM | #6955 | |
im a rookie and i have an unconventional paint system. i bought a turbine spray rig from TpTool a year ago. the cap pressure is very low and i did not reduce the epoxy enough according to the guys i bought the sprayer from. the clear sprayed pretty orange-peely too. lots and lots of wet sanding. i actually enjoyed the experience, watching what looked like the moons surface smooth out to at least a 10' paint job. here is the 3 bottles i got. wool pad with the white lid, black foam with black lid and yes, you guessed it......blue foam with blue lid
07-13-2018, 10:04 PM | #6956 |
Today , I secured all the new fuel/ brakes lines to the frame , hooked up fuel line to fuel pump , from fuel pump tp carb.
Removed old manual steering box and prepped frame for new PS box. |
07-13-2018, 10:10 PM | #6957 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-13-2018, 10:35 PM | #6958 | |
07-14-2018, 09:42 AM | #6959 | |
i bought some Mequires a while back with harbor freight pads. i couldnt figure out which liquid to use. this stuff is a no-brainer. I'm sold on it!!
07-14-2018, 11:49 AM | #6960 |
The pedal pad is a Lokar product and very easy to install. I just pulled the stock pad and laid out and drilled four holes for the stainless screws supplied in the pedal arm.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
07-14-2018, 11:51 AM | #6961 |
Going to swap speedo gears to calibrate my speedometer today to actual speed
07-14-2018, 12:02 PM | #6962 |
Looked at the eBay ad over and over and over, waiting for it to make a long journey to me. Hoping it all goes well
Probably be next Tues. they say and its killing me, no sleep NSF |
07-14-2018, 12:09 PM | #6963 | |
Post up the add maybe? -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
07-14-2018, 04:17 PM | #6964 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
07-14-2018, 07:45 PM | #6965 |
Just got a call from the transporter, he picked it up today at 10 am and will be here Monday after noon if all goes well. He has one more pickup in Idaho with same delivery spot to here in Havasu, Az.
I will definitely post up some photos, shes a beauty to me NSF |
07-14-2018, 08:26 PM | #6966 |
Swapped in a 22 tooth gear vs. the 20 I had and now my speedo is dead on.
07-14-2018, 08:31 PM | #6967 | |
07-14-2018, 11:59 PM | #6968 |
Speedometer Gears
? Any chance of a link to the Vendor whom sells those colored speedometer drive gears ? .
Folks are always asking me where to get them and I lost the link when my old computer crashed and burned . TIA,
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
07-15-2018, 02:32 AM | #6969 | |
Re: Speedometer Gears
https://rover.ebay.com/rover/0/0/0?m...2F131761841557
07-15-2018, 07:33 AM | #6970 |
I just keep bolting on the chrome and stainless as it shows up, Old school !
07-15-2018, 09:35 AM | #6971 |
laying low
Dang grump! That's just too purty to actually use. Maybe a nice display model instead?
07-15-2018, 09:46 AM | #6972 |
Thanx Ned ! .
I see they're cheaper now too ! .
07-15-2018, 10:28 AM | #6973 |
I went to a local all GM truck show yesterday. Imagine what I took pics of most.
https://www.flickr.com/photos/882049...57671200461738
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
07-15-2018, 10:57 AM | #6974 |
There's one oddity in there that is worth a closer look...
Appears somebody dressed up a late model, single cab chevy truck in 67/68 sheet metal...
07-15-2018, 11:07 AM | #6975 |
Yup, that roof line stood out! "Smooth" is the one-word that came to mind if I had to describe it...
1968 C10 LWB Fleet-Wood, 2-WD, 327, 4-Bbl, Auto, 12-Bolt, Bone Stock. >POOF!< Sold 9/8/2018. New owner is local to Waynesboro PA and will take excellent care of her. He also owns a 69 Z28 SS Option car. 1998 Camaro SS, LS1, A4, 3.42. Free Tune - Stock 13.08 @ 106.55 >Lightening Strikes Again!< Sold 9/9/2018 she too will be well cared for as 1 of 45 produced in blue, with Auto and no T-roof. |
