Old 03-04-2009, 09:53 PM   #676
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: My 1965 build thread
Looks like your doing a great job. That gap you are referring to is where the wires will lay. The flange is where the weatherstrip attaches. I don't have a good pic of it being done showing the gap. Here is mine before surgery. You can see a wire running thru there and the gap. The spot weld go down in that area onto top of the inner rocker. I guess I should have took some better pix.
Alan's Classic is offline   Reply With Quote
Old 03-04-2009, 10:05 PM   #677
neto
neto's Avatar
Thank you Alan. Now just going to check my door gap before I weld it in place.
neto is offline   Reply With Quote
Old 03-05-2009, 12:19 AM   #678
Alan's Classic
Ya'll ever start on a project and half way thru it you ask yourself what the hell was I thinking? Well tonight was a perfect example for me. I went out with the full intentions of getting the column done so I can get it ready for paint. I did get the upper nuts tacked in place. i then took the column out to work on the nuetral safety switch. My thinking was I could duplicate the openings, so that is what proceeded to do.
I was taking step by step pix to share with ya'll. Once I got to this point is when it hit me..........That's stupid you dumb A$$. My thinking is I can cut out a square around the original location and move it up the column. The piece I cut out can fill the hole where the original one was. It will be alot cleaner and will allow me more access to the inner shaft so I can cut it as well. I will weld the piece I cut out tonight back in and start over. Don't ya'll think that would be better?
Old 03-05-2009, 12:50 AM   #679
protrash64
Resistance is Futile
protrash64's Avatar
Sorry, I dont follow what you are pointing out; you did a good job with the tape, however.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-05-2009, 12:56 AM   #680
Alan's Classic
Maybe this will help out. Weld the piece I cut out and start over by doing this.
Old 03-05-2009, 12:09 PM   #681
Strodder
Daring to be Different
Strodder's Avatar
Good idea Allan, but what do you have to do to the inner shaft make the switch work? Isn't there an easier way? You got me thinking now.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-05-2009, 01:14 PM   #682
70 Suburban
Rods
I would just bypass the nutral safty switch
70 Suburban is offline   Reply With Quote
Old 03-05-2009, 11:24 PM   #683
Alan's Classic
The pix will explain
I've seen 2 mishaps over the years due to that. It's not worth the risk of killing someone.
After I got my measurements and a plan this is what happened. I didn't take pix of the cut I made on the inner tube where the switch is activated. It looks almost like the original hole just in a different location.
And there is continuity in park. I tacked everything in place and checked with a meter before I weld everything up.
Old 03-05-2009, 11:28 PM   #684
Strodder
Strodder's Avatar
NICE
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-05-2009, 11:55 PM   #685
joe231
joe231's Avatar
nice work Alan!
CHEVY ONLY
Old 03-06-2009, 12:02 AM   #686
protrash64
protrash64's Avatar
I get it....sorry dude. I see whats up now; thats slick. Was the switch interfering with something? Your mount is clean too. My column installed by the PO has a cobbled up mount combined of the late(?) 70's column mount and the original. The column is also too short.
Old 03-06-2009, 12:34 AM   #687
Alan's Classic
NICE
Originally Posted by joe231 View Post
nice work Alan!
X2
I slid the column down (forward) 2". That put the nuetral safety in the firewall. There is a pic on the previous page. No need to be sorry. Thanks.
Old 03-06-2009, 12:39 AM   #688
protrash64
protrash64's Avatar
The slot on the inner cylinder wasnt registering to me. Probably because I havent torn apart a column before. I knew it worked mechanically.
Old 03-06-2009, 01:08 AM   #689
neto
neto's Avatar
Man I'm tired, just went through the whole thread again to find how you welded the rocker to the floor. I noticed you made holes in the new rocker. Did you use a spot weld bit? Every time I go through your thread I find something new I learned. This is like my third time I have gone through it.
Thank you.
Old 03-06-2009, 08:40 AM   #690
sdailey
The Few, The Proud
sdailey's Avatar
Alan,
The switch relocation looks slick. Good job.
Shannon
sdailey is offline   Reply With Quote
Old 03-06-2009, 09:49 AM   #691
4dranch
Shloooooong bed member #2
4dranch's Avatar
Originally Posted by sdailey View Post
Alan,
really nice work Alan,
And thanks for taken the time to share with us.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 03-06-2009, 10:22 PM   #692
Alan's Classic
Hopefully I have cleared up a mystery for you.
Thank you.
I used a spot weld bit to drill the holes on top of the outer rocker where it lays on the inner rocker. Maybe I should go back thru my own build . I might learn something or see something I forgot to take care of.
Alan,
Thanks X2 and your welcome.
Had a little time to shave the key hole and fill today. The pix are pretty much self explanatory.
I made the cut with a thin cutoff wheel and cleaner up with a grinder. (It's aluminum)
Put a piece of tape to plug the hole for the next step.
This stuff is great for bonding panels and have used it in some other circumstances, so why not try it here.
It is slow to dry. It needs at least 4 hours at 70 degrees, 24 to fully cure. Once cured it can be dressed down and maybe wiped with a thin coat of filler if needed.
Finished welding and grinding.
Went ahead and wiped it to clean it up a little more.
Old 03-06-2009, 11:12 PM   #693
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
lookin good
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 03-11-2009, 08:47 PM   #694
Alan's Classic
Originally Posted by jgh64pkup View Post
lookin good
Thanks Man
Not a whole lot going on here, just enjoying the beautiful weather. As most know I picked up another truck for the hood. I've got the rest of the truck in the classified section with a choice of one of my other 2 hoods. I've kind of got out of the groove. Trying to get back in the saddle. I think we have all been there. You decide to take a day or 2 off then before you know it it is a week later.
Old 03-11-2009, 09:28 PM   #695
Strodder
Strodder's Avatar
I know what you mean. I need to get back on mine.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-12-2009, 08:27 AM   #696
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
In my case... since september!
I did go stare at it for an hour yesterday... does that count?
Old 03-12-2009, 10:19 AM   #697
MacAttack
283 Drama Queen
MacAttack's Avatar
Alan, thanks for the in-depth photos and detail of what you’re doing. This effort will no doubt save many tears for a lot of folks later on and is a great example of why this forum is so important.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 03-12-2009, 11:36 AM   #698
4dranch
4dranch's Avatar
Mac.
David,
Daughters 66 truck:
Old 03-12-2009, 02:44 PM   #699
kizer
Its Deja Vu time again
kizer's Avatar
I hear you on the taking a break. Got cold her so I took a break for a month or two. Then right when I started getting excited it Snows for two days in the beginning of March. What gives?
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-12-2009, 09:46 PM   #700
Alan's Classic
Looking and thinking does count.
Mac.
Thanks Mac, I'm glad ya'll enjoy and get something from the pics
At least ya'll got some snow. I live 60 miles North of Atlanta. We didn't even get a flake. Atlanta got 2-4". It won't be long and we will be complaining about the heat.
Stayed tuned I'm fixin' to post some pix of what I got done today.
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
