Old 09-26-2016, 09:06 AM   #676
gotmotors
gotmotors's Avatar
Re: My long term 57 project
Thanks JJ but I can hardly keep up with one build thread.
Jim
My 55 build
http://www.trifive.com/forums/showthread.php?t=97044
gotmotors is offline   Reply With Quote
Old 09-29-2016, 02:56 PM   #677
RockinKees
RockinKees's Avatar
Doorpanels looks great Chuckdriver!
Looking forward to see the rest of the interior.
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 09-29-2016, 11:13 PM   #678
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Thanks!
Install pic's to follow tomorrow!
ChuckDriver is offline   Reply With Quote
Old 09-30-2016, 06:05 PM   #679
ChuckDriver
Well guys, I finally had some spare time to install the Altman door latches. It took some time to get everything lined up and adjusted, but now they work great. The doors are much more secure and don't rattle nearly as much as they did before. The cab feels much tighter too.
I went with the long panel option, it lays over the stock door panel between the raised ribs and wraps around the end. The instructions are good and easy to follow and the kit came with all hardware needed.
First cut was made after laying out the supplied template on the door panel. The first 3 pic's show the template and the panel after the cuts and with the latch loosely in place.
Then following the instructions I marked out the cut lines on the passenger door. The window channel touches the door, so you must be very careful making the top cut. There is also a reinforcement panel behind the door edge that needs to be trimmed away too.
Old 10-05-2016, 10:54 PM   #680
ptc
ptc's Avatar
Nice work as usual there Chuck! --- lookin good
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 10-05-2016, 11:00 PM   #681
Dan in Pasadena
Dan in Pasadena's Avatar
JJ don't fool around!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 10-06-2016, 07:19 AM   #682
dug224
dug224's Avatar
New door latches are on my To Do list. I'll be following closely on this...
dug224 is offline   Reply With Quote
Old 10-06-2016, 08:04 PM   #683
ChuckDriver
Here's a teaser shot of the interior work.
Old 10-06-2016, 08:11 PM   #684
Dan in Pasadena
Man, I REALLY like the color! I like how it's a deep Cardinal type red at least in the photos. JJ, can I ask if you know the material name and color number? Is it leather or vinyl? I'm pretty sure I'm using vinyl. Look SO good.
Old 10-07-2016, 07:52 AM   #685
Kim57
Kim57's Avatar
Real nice color.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-07-2016, 05:29 PM   #686
ChuckDriver
Dan, its vinyl, I'll try and get the info from the upholstery guy!
Old 10-07-2016, 05:29 PM   #687
ChuckDriver
Originally Posted by Kim57 View Post
Real nice color.
Kim
Thanks Kim!!
Old 10-07-2016, 06:23 PM   #688
Dan in Pasadena
Thanks! It's a rich looking color.
Old 10-08-2016, 03:15 PM   #689
BIGglaSS
BIGglaSS's Avatar
I Like the door panels. Keep us posted on the Altman latch progress, I may be doing the same.
BIGglaSS is offline   Reply With Quote
Old 10-08-2016, 03:38 PM   #690
Rude Dude
Rude Dude's Avatar
Looking good that red interior will really standout Rich
Rude Dude is offline   Reply With Quote
Old 10-10-2016, 09:39 PM   #691
ChuckDriver
All in all the Altman latches went it fairly straight forward. I did have to take the door panel on and off several times to get the right bend in the long actuating rod so that it doesn't bind against the door panel.
The biggest problem area for me was with the latch and striker pin. The pin has a hex head with sharp points. The problem I had is that one of these points was making contact with the back of the latch and was keeping the latch from completely closing. I could here metal to metal contact!
My solution was to open up the mouth of the latch giving it just enough room to work! I think if Altman made to sticker pin with a round head with a hex socket, like the older GM cars, it would be a cleaner install.
Old 10-10-2016, 11:54 PM   #692
Dan in Pasadena
Great work, JJ!
Old 11-06-2016, 11:31 PM   #693
ChuckDriver
Anyone seen a 60 Impala speaker grill laying around??
Old 11-07-2016, 03:25 PM   #694
RockinKees
RockinKees's Avatar
Maybe Tpimuncie??
He's got all the goodies
Or he may know where to find it?
Cheers!! Kees.
Kool Guyz CC
Old 11-07-2016, 03:36 PM   #695
59chev
59chev's Avatar
That looks great!! Did you integrate the speaker grill into the stock seat? If so, that seat will go perfect with the dash swap.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 11-07-2016, 05:48 PM   #696
ChuckDriver
Yep, I had a seat custom made using the 60 Impala speaker grill and the materials and pattern of the 63 Impala. It turned out amazing!!
Will try and post installed pictures later tonight!!
Old 11-07-2016, 06:02 PM   #697
Dan in Pasadena
Wow, that looks fantastic! It kinda looks like the factory seat but modified for the grill insert. Or is it entirely custom? Either way, it's gonna look SO good
Old 11-07-2016, 08:02 PM   #698
jcramsey
jcramsey's Avatar
That seat looks awesome...can't wait to see it installed! You've got good taste JJ.
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 11-07-2016, 08:36 PM   #699
oldman3
oldman3's Avatar
Good taste they JJ, looks super...Jim
oldman3 is offline   Reply With Quote
Old 11-07-2016, 09:34 PM   #700
Kim57
Kim57's Avatar
Seat looks great.
Kim
My build thread
