#676 |
Still plays with trucks
Re: What did you do to your truck today!
You should look into getting a starter from a 90 to 96 full size 4x4 truck. They are a little smaller but have a higher output than the older starters. The 4x4 versions have a smaller opening in the snout to help prevent debris from getting in there when off road driving. The 2wd versions have the typical large opening in the snout but are a little cheaper. About $60 at AZ with a lifetime warranty.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#677 |
S10's & Astro vans used the starters too from 88-95 on the S10 and 91-96 on the Astro plus full size vans too so if you are on a tight budget you can get one from Pull & Save for under $17 out the door.
#678 |
Redefining LowBudget
Now that AI'm back running on all 8.2 liters I made the right rear tire a little balder??
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#679 |
Kill Bill...et
Brake caliper hardware rebuild kit...$7, Trip to Ace for some grade 8 hardware for the front susp....$15. Now I can travel down the road with my mind at ease.
#680 |
^^who I am^^ what I say>
I put gas in it! Good god, that cost as much as the truck did.
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
#681 |
Cruzin
got it back on the road
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#682 |
Fixed my fuel gauge by replacing the float on the sending unit. The old one was full of gas.
-Scott- |
#683 |
Painted the bottom of the cab and going to prep the inside |
#684 |
Finished welding in inner rockers, floor patch, a pillar and fender brace on passenger side. Painted with por 15. Also painted under arm with por 15 while painting bottom of cab laying on floor. Didn't notice drips into shirt sleeve untill to late. Wife couldn't stop laughing. Now on to the cab corner and outer rocker.
#685 |
changed the oil and had helpers. installed new 1 piece driveshaft from driveshaft specialists, and put a new rear trans seal while i was at it.
#686 |
[QUOTE=btullis99;4150595]changed the oil and had helpers.
Very cool. I love it when my boys give me a hand. Didn't do a thing today but started it in the garage yesterday.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#687 |
Went outside thinking I needed a starter, just had a loose wire. So I loaded some of my guns up and spent some quality time at the range.
#688 |
![]() Join Date: Aug 2010
Worked on some Turbo Piping. Hopefully hear this thing run really soon.
#689 |
![]() Join Date: Sep 2008
installed outer inner headlight trim also rattle caned all my brackets.......
#690 |
Grandpa in the rustmobile...
Worked on some brake lines and got some free parts from a junked truck
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#691 |
Got my heater to quit working. It was 100 degrees outside today, and i drove about 50 miles with the heater blowing, that inspired me to fix it REAL quick.
#692 |
What?
Drove her around town.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#693 |
today I pulled my gas tank (under bed stainless steel) I had fuel pressure issues. found a rubber glove in the tank (no extra charge) the most crazy discovery I've made to date! Truck would run great! then all of a sudden fall on its butt & starve for fuel(only with 3/4 of a tank or more) go figure! anywho, thing works fanfriggintastic now & once more I love my truck! cheers, Pat
#694 |
![]() ![]() Join Date: Jul 2002
Installed my new fuel cell. Picked up a new rear sport bumper. Then the usual, sanding and prep for paint.
#695 |
really enjoy your little helpers! they grow up so fast! great photo, may you always enjoy the help! (take many pictures ) cheers, Pat
#696 |
It was a good weekend
![]() yesterday i changed the water pump and alternator and painted all my pulleys and inner fenders... Today i "isolated" my grill to stop some squeaks, cleaned up a little wiring, and I drove around the city lakes and scouted out some trim pieces
1971 C-20 350/350 |
#697 |
Replaced the upper and lower radiator hoses, the radiator cap and refilled her with Prestone 50/50. She had a senior moment late last night, got all hot and bothered and pee'd all over my driveway.
Cut out the passenger side upper seat belt anchor as the spot welds had broken and the upper anchor was rattling. If I knew before what I know now I would have just drilled above and below the nut and used those holes to plug/spot weld the inside support thingy to the sheet metal. Now, I have to weld the sheet metal back in, sand it, smear on some bondo, sand, repeat a few times and then repaint. -Steve
1969 Chevrolet 4x4 C10 Pickup |
#698 |
Got my front end aligned and my van ralleys put on .Still looking for 2 truck ralleys nearby .
#699 | |
'69 Chevy SWB
![]() Join Date: Feb 2009
I checked on line to see when my parts would be here from CPP.
![]() I can't wait any longer!! ![]()
Matt ![]() ![]() ![]() ![]() ![]() '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
#700 |
![]() Join Date: Jul 2009
Fixed my rusted core support. Used a piece of the bed support that I cut out for the blazer tank. worked pretty good. Yeah I know my welds are ugly.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
