Old 08-03-2016, 05:07 PM   #676
JG67
Re: How about some pics of Static Dropped C-10's
Originally Posted by Smoothride View Post
4.5/6
Can someone chime in on what kind of wheels these are? Size?
These look sharp and bad A$$ truck.
Thanks.
JG67 is offline   Reply With Quote
Old 08-05-2016, 10:11 AM   #677
knomadd
knomadd's Avatar
Those are Intro Magnum's.
http://www.introwheels.com/product/magnum/
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-05-2016, 10:13 AM   #678
JG67
Originally Posted by knomadd View Post
Thanks.
Old 08-05-2016, 01:51 PM   #679
Dad's72
Dad's72's Avatar
Originally Posted by C1ph3r View Post
got a question for you static dropped guys. i have a fairly steep drive way at the entrance. any of you guys have issues dragging your bumpers front or rear. i am afraid going this low static may cause problems getting in and out of the drive way.
i know its all relative and useless without pics. just curious.
im considering a 4.5 front and 5.5 or 6 rear.
May have to go bags rear id the drive way is an issue.
thanks.
I have a driveway like this as well. Anyone have experience with a steep driveway and a 4/6 drop?
Dad's72 is offline   Reply With Quote
Old 08-05-2016, 02:39 PM   #680
Dad's72
Dad's72's Avatar
thanks.
Old 08-19-2016, 11:51 AM   #681
ck5566
Originally Posted by C10LIFE View Post
If you live to tell your story from the 200 MPH trip then YES actually you do have a friend, his name is ***GOD***
ck5566 is offline   Reply With Quote
Old 08-19-2016, 11:59 AM   #682
ck5566
Originally Posted by RINC View Post
Stactic dropped owners are a special breed who dont need the crutch of raising the truck to clear an obstical that could have been driven around.
2X's for me
Old 08-19-2016, 12:35 PM   #683
Custom.Chevy
Custom.Chevy's Avatar
i may have uploaded to this thread b4 but thought i would share some more.
static drop. still to tall in the rear for my personal taste but its work in progress . not much clearence. running the tall 20" wheels with the low profile tires really helped compare to the weld wheels and aluminum eagles i had b4. wheels make a huge difference im constantly changing my mind on what i like im on my 3rd set of wheels with this truck.
instagram - @custom.chevy
Custom.Chevy is offline   Reply With Quote
Old 08-19-2016, 04:38 PM   #684
RDrancher
RDrancher's Avatar
How's the ride with the 20's compared to your 15's? Looks good by the way.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 08-23-2016, 01:06 PM   #685
Custom.Chevy
Its really the same in my opinion. once you lower the truck as much as i have, the ride is fairly stiff but still not bad. the lower profile tires dont seem to make an obvious difference other than i feel as if the steering got twitchy and more reactive to grooves in the road.
Old 08-25-2016, 08:37 AM   #686
Dad's72
Dad's72's Avatar
I have a question for everyone that did a drop with new spindles, springs, and shocks. Like the one I want to order from ECE 4/6 drop kit.
Did you do the rest of the suspension bushings and parts while you were at it? Just wondering because that would add another couple of hundred dollars. Making a parts list and wondering if this all needs to be done at the same time for a nice solid riding truck. Also for safety.
Old 08-25-2016, 12:37 PM   #687
knomadd
knomadd's Avatar
Honestly, I didn't do it on mine, but my bushings and ball joints were fine. I did change them out when I went to an air suspension since I completely replaced the lower control arms and did a full rebuild of the front steering components.
If your bushings and ball joints have seen better days and you're going to need to replace them anyway, it would be easier to do when you replace your spindles since you'll have to have it off to do the ball joints anyway. It's also a whole lot easier to do bushings with the control arms off the truck, so spindles would come off for that too.
If you have the funds, I recommend you do it all at once. And have fun with it!
-Duane
Old 08-25-2016, 02:42 PM   #688
68Stepbed
68Stepbed's Avatar
If it's not been done recently, it'd be a good idea to replace all that. I replaced it all when I did my 5 lug swap, but didn't when I added lowering parts since they were all recently new(~4 yrs old).
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-25-2016, 03:19 PM   #689
ghalperin
ghalperin's Avatar
I'm at the same place with my truck. I'm gathering parts for the front and rear lowering with a disk brake upgrade, due to the lowering spindles. My truck has 57K miles on it and although it's been maintained. Now is the time to replace the 50 year old bushings and ball joints, since everything will be apart. I went with Moog on those items. I'll replace the steering linkage, if I see any wear. I haven't even looked at the rear arm bushings, but I should replace those as well, due to their age.
Afterwards I plan on driving it a little harder. Plus, the 396 is going to double the torque, HP and weight over the inline 6.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline   Reply With Quote
Old 08-26-2016, 03:36 PM   #690
Dibdob62
Dibdob62's Avatar
Just finished fitting a 4.5/6" ECE Drop kit, running 275/60/15 tires on 15" Cragars.
Dibdob62 is offline   Reply With Quote
Old 08-26-2016, 05:18 PM   #691
gringoloco
A guy with a truck
gringoloco's Avatar
Dig it! Even more so with the classic UK plates. I bet it's a head turner over there
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-27-2016, 05:32 AM   #692
Dibdob62
Dibdob62's Avatar
Thanks, Yes I get a lot of smiles and nice compliments when i take it out
Old 08-27-2016, 07:50 AM   #693
RDrancher
RDrancher's Avatar
I love the classic Cragar look, and your truck looks perfect.
Old 08-27-2016, 10:51 AM   #694
Dibdob62
Dibdob62's Avatar
Thanks, I would love to get my hands an some Rallye Wheels but they are few and far between over here and the price to ship them over is crazy actually same goes for some lower wood grain trim
Old 08-31-2016, 07:05 PM   #695
blackice087
Originally Posted by 68racer View Post
I really like you setup here! how much did you drop the truck and size tires did you go with?
blackice087 is offline   Reply With Quote
Old 09-20-2016, 10:58 AM   #696
scrappydoo2k2
scrappydoo2k2's Avatar
DJM flip kit in rear, ECE 2.5" spindles and 2" drop springs in front.
scrappydoo2k2 is offline   Reply With Quote
Old 09-20-2016, 11:08 AM   #697
jlsanborn
jlsanborn's Avatar
Nice!! What size rubbers on there?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 09-20-2016, 11:19 AM   #698
scrappydoo2k2
The fronts are 255s on a 15x7 rally, while the rears are 275s on a 15x8 rally.
Old 09-20-2016, 01:46 PM   #699
Sixteen Tons
Sixteen Tons's Avatar
DIBDOB...... Well done man. That is a great looking truck. Bet you get a lot of looks tooling around Ole Blighty in that !!!
Wanda - 1969 C/10 LWB 250 I6 3OTT
LWB>SWB
Sixteen Tons is offline   Reply With Quote
Old 09-20-2016, 05:28 PM   #700
Qwk
Qwk's Avatar
Bell Tech 4/6...
My LS/T56 C10 build...http://ls1tech.com/forums/conversion...t56-build.html
Qwk is offline   Reply With Quote
