01-11-2015, 06:20 PM | #676 |
Re: Rat repair.
Well the onley other is three phase
Just wire the two hot leads as u would any 220v circuit And the ground wire is ground! |
01-12-2015, 03:38 PM | #677 |
Re: Rat repair.
For 3 phase power you need 3 hot wires and ground. most houses are single phase. you can get a phase converter for the 3rd phase. they make rotor or static type and match to the power of the motor you are running.
01-12-2015, 04:16 PM | #678 |
Re: Rat repair.
Ya I made this one for my bald or grinder typ. It is simple plug and play
01-12-2015, 05:18 PM | #679 |
Re: Rat repair.
I will not buy a heater if its 3 phase, i need to plug it into my welder outlet..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-12-2015, 07:01 PM | #680 |
Re: Rat repair.
01-12-2015, 07:43 PM | #681 |
Re: Rat repair.
That's just a phase O-Matic Rotary phase converter that are hardwired so I can just plug my three-phase equipment into it and I plug it to 220 extension cord from the welder and all the other equipment
01-12-2015, 08:31 PM | #682 |
Re: Rat repair.
Do you still have the drain pointing to the center of your floor? It looks like a toe stumper. But the compressor look real nice. What CFM is that compressor? George
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
01-13-2015, 06:30 AM | #683 | |
Re: Rat repair.
17.8@90psi 17.7@100psi 17.2@175psi
01-13-2015, 11:02 AM | #684 |
Re: Rat repair.
You could contact the manufacturer of some of these heaters and get their wiring recommendations with your criteria? Might make deciding easier or show you models you had not considered yet.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
01-13-2015, 02:08 PM | #685 |
Re: Rat repair.
This link explains what i'm talking about with a 220 3 wire VS 4 wire, houses are all single phase and businesses are 3 phase, so if its a "Garage heater" it has to be single phase.
I did find a place selling the New Air G73 and it shows 3 wires coming out of the back of the unit. I did email one place but no reply as of yet. http://www.nojolt.com/Understanding_...circuits.shtml
01-13-2015, 04:22 PM | #686 |
Re: Rat repair.
Heated garage is the way.
01-14-2015, 12:52 AM | #687 |
Re: Rat repair.
good luck with the heat. no need here in Florida for heat. only AC
01-17-2015, 12:51 PM | #688 |
Re: Rat repair.
Why are you using electricity? Is natural gas not an option? I heat my wood shop (built into hte back 1/3 or so of the garage) with electricity. It's generally more expensive than gas, and even for my little insulated wood shop, it's definitely not cheap. I live in town, heat my house with natural gas, and simply haven't ponied up the cash and time to run a line out to the garage. Maybe that's your case, too???
That being said, any heat in a garage is better than no heat, even the more expensive electric heat. The car/truck side of my garage is not insulated and still has open trusses. I've used LP to heat it on occasion with a big mutha convection heater, but I pour through the LP, barely get the chill out of the garage, and magnify the affect of the beer I'm consuming while out there due to the heater's consumption of oxygen....
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
01-17-2015, 05:48 PM | #689 |
Re: Rat repair.
i love the little 45k btuh natural gas unit in my garage, but i had gas right there for the h2o heater so it was a no brainer. i dont know as i would have gone to the trouble of running a line if it wasnt. actually, now that i know i would have. but i shopped for electric units as well. like you said any heat is better than cold fingers.
01-17-2015, 08:21 PM | #690 | |
Re: Rat repair.
My garage is about 460 sq ft the walls are R-11 on the outer two walls with the exception of the garage doors but i'm hoping to get them replaced with insulated units this year. the ceiling is 8' and its insulated about 1' deep, above that is my upstairs bedroom. I hqave tried a kerosene heater but cant deal with the fumes, plus with the bedroom upstairs i have concerns about carbon dioxide. The good news is that it rarely ever gets below mid 20's and all i want to do is try and keep the air dry so when i do some body work i won't be fighting any potential moisture problems. I would also be to string up a plastic barrier down the middle to protect out bikes from any potential over spray that may occure, i had a little talking too last summer about over spray on Megs helmet...Woops! I spent a lot of time looking at different units and decided to buy the King unit thru Home depot, i figured if i had a problem with it i could just return it to them instead of having to ship it back. I ordered it a couple days ago. http://www.northerntool.com/shop/too...FQpsfgodpUMAbA So in the mean time i admittedly havent been working on the truck But i have been concentrating on planning some stuff to be done to my bike for riding season, a big bore kit and different cam and some other improvements. Plus i'm adding a different rear fender, saddle bags and a new paint job. I'm letting a local independant shop do this stuff for me but my time has been spent doing the planning and decision making on what gets done.
01-20-2015, 02:52 PM | #691 |
Re: Rat repair.
Well, i received my King Model# KBP2406 heater, went to Home Depot and bought 25' of SO electrical cable, a 30 amp male plug and a couple other items to get the heater hooked up and mounted to the ceiling on the outside wall about 15' away from and facing the garage door.
My first impression is kinda disappointing, both in heat and airflow, i was expecting more for a 220V heater, but it is quiet. This morning my thermometer said it was 29 degrees outside right now its about 38 per weather.com. I turned the heater on and went back in the house for my coffee, after 1 1/2 hours i went back out to check, the house door is about 15' away from the heater in the other stall, the air was warm down to about 3' level then it was pretty cold. i walked over to the other stall and about 10' in front of the heater (right next to my air compressor) it was warm to about chest level which is right in front of the heater as its angled down, but the air gaps on the garage doors are just too big, you can feel the cold air coming in from the door. any closer to the door and the heat just dissipates. Basically the heat is circling in the back half of the garage because the leak's around the doors. Once i get the doors replaced it should make quite a difference. Right now the heater is on the highest setting on the built in thermostat, it hasn't cycled off at all yet. it does have an overheat automatic shut off tho which is one of the reasons i chose it.
01-20-2015, 05:34 PM | #692 |
Re: Rat repair.
That heater would work in my garage real good. I have 2 small Daton heaters that plug into 110 outlet and in about 2 hours it is warm enough I can work in my T-shirt. I do have an insulated garage door that seal good and I did install a bottom seal at my side door. All walls insulated with R13 ceiling is R30.
01-20-2015, 06:09 PM | #693 | |
Re: Rat repair.
01-21-2015, 12:59 PM | #694 |
Re: Rat repair.
That is going to make a big difference. A good seal on all sides of the garage door will help keep the heat in. Our garage has a 16' tall ceiling and we've got 2 large ceiling fans to push the warm air down to 1st floor level (not to mention the thermostat mounted 30' away by a man door). When we are out there the fans are running full speed. Once you get the heat to stay in the garage you might consider an extra circulating fan or 2 in the right place should help winter or summer.
01-21-2015, 01:47 PM | #695 |
Re: Rat repair.
Not sure what doors you are referring to but if it is the overhead door that is not insulated a friend of mine got some insulated inserts from Menards that worked pretty slick. They were similar to batting insulation.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
01-21-2015, 05:32 PM | #696 | |
Re: Rat repair.
01-21-2015, 05:34 PM | #697 |
Re: Rat repair.
Nope, garage doors actually, the ceiling is insulated tight. Thanks for the suggestion tho, they are always welcome!
01-21-2015, 05:45 PM | #698 |
Re: Rat repair.
Insulation mats that go in panels of the overhead garage door sorry for confusion
01-21-2015, 05:57 PM | #699 |
Re: Rat repair.
Oh I got ya, thanks!
01-23-2015, 12:53 AM | #700 |
Re: Rat repair.
I got the top and sides of one door weather stripped today, bought the rubberised roll of stuff that ya gotta nail every 2-3 inches, it works but its time consuming, the only other stuff Home depot had was like a squeege attached to a long plastic piece, it would work if i pulled all the 1/2 X 2' wood trim around the roor and replaced it with 1/2 X3", too much work for something i may end up having to replace later. I'll get the other door tomorrow.
The bottoms are going to be another story as both doors seem to have sagged in the middle a bit, plus the floor is crowned up in the middle of both doors too, so they are solid against the floor in the middle and up about 1/8 to 1/4" on the sides. It did have worn out rubber bottom seals when i bought the house back in 89, but i don't know if i can make them latch if i put new stuff on the bottoms, will find out soon enough. Edit: It took me forever but i found out that Northern Tool sells a 3' and 6' X 3/4" air hose for compressors so i got it ordered too.
