11-08-2017, 06:11 PM | #676 |
6>8 Plugless........
Re: 71 4X4 Frame off Restoration
I wish I would have went bigger than 19gal but the thing got expensive enough after 2 mods to the original design. Haha Maybe someday, I'll actually put it in.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-08-2017, 09:29 PM | #677 |
Nice, I should have went with a k20 tank instead of a C10 tank, would have been easier to fit up and probably a bit bigger too.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-10-2017, 04:50 PM | #678 |
Will you have to do any frame mods for the 26 gallon tank to fit.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
11-17-2017, 11:47 PM | #679 |
The big brown truck final stopped at my house and delivered my fuel tank. I has been years sense I received a box with packing peanuts.
11-17-2017, 11:51 PM | #680 |
It's awesome looking tank.
11-18-2017, 12:31 AM | #681 |
Very nice! I despise those dumb packing peanuts.
11-18-2017, 09:52 PM | #682 |
The peanuts stick to everything, but that tank is worth it, like to see more on the tank.
Mudman.
11-19-2017, 08:59 PM | #683 |
got some working done on my truck Saturday afternoon I installed flex exhaust section on the right side.
11-19-2017, 09:04 PM | #684 |
Today spent the day installing flex exhaust pipe on the left side and installing the fuel tank. No modification to the frame or cross members. I used the rear cross member to support the back of the tank and made a front mount out of 1" square tube 1/8" wall thickness. I'm going to add strap in the middle to complete the installation.
11-20-2017, 11:04 AM | #685 |
Getting closer all the time!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
11-20-2017, 04:22 PM | #686 |
Looking really nice! You are using up that space wisely. I have no where near the room under my bed with the hitch and suspension etc.
11-21-2017, 12:55 PM | #687 |
Hello All
I have question with setting up fuel lines for LS engine swap. I have confirmed that I have returnless fuel system so I ordered a fuel filter Regulator from corvette. does it matter where the filter regulator is located. |
11-22-2017, 11:07 AM | #688 |
The pump and filter should be as close to the tank as realistically possible. I put mine on the frame right under the door, with an isolater so I didn't hear the pump run while in the cab
11-22-2017, 11:24 AM | #689 |
notchbackgta
My pump is in the tank. I'm talking about Corvette fuel filter with regulator built in. |
11-22-2017, 11:48 AM | #690 |
I would guess somewhere accessible and away from high temps? It's after the in tank filter/pump so being able to replace it if necessary and any heat concerns. Looking forward to hearing this beastie run!
11-22-2017, 11:54 AM | #691 |
11-22-2017, 01:41 PM | #692 |
Ok I can mount the FR in the frame rail by the shock and have it accessible for access if needed. Thanks
11-23-2017, 04:50 PM | #693 |
Yesterday the big brown truck dropped off my fuel filter regulator so I installed it in the frame rail and ordered the rest of my fuel line and fittings.
11-23-2017, 04:58 PM | #694 |
While waiting for my fuel line and parts. I started working on the parking break brackets and ran into a snag with the speed O cable. Looking at what Advanced Adapters Web site. It looks like I have or order the ATLAS II SPEEDO HOUSING Assembly and gear. Not sure why they did not add it to the transfer case when I bought it as part of the kit. In the top view it goes where the round red plug is
11-23-2017, 04:59 PM | #695 |
I wish every body Happy Thanksgiving time for me to clean up get ready to go to moms house.
11-23-2017, 05:33 PM | #696 |
Happy Thanksgiving to you too!
11-25-2017, 01:06 PM | #697 |
Looking good!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
11-25-2017, 11:31 PM | #698 |
I worked on completing some mounting brackets for my exhaust, fuel tank and parking break. Went to bolt on the flange for my parking break and it was locking up after tightening up the nut and the flange would stop turning. Ended up the mounting bracket was not pushed up tight to the tail housing of the T-case. finally figured it out after 2 hours of ripping everything apart. The brown truck delivered some of my fuel line and fitting so I started on plumbing the fuel system. waiting for the rest of the fittings to finish it up
12-01-2017, 04:23 PM | #699 |
Well after 3 deliveries from the brown truck I finally got my fuel lines connected up and have 5 fittings to return to Summit. I found out early this week Advanced Adpters installed the wrong tail housing on my T-case. hopefully they will trade me for the right one. I need one for Variable speed sensor for newer Chevy LS engine. Part Mike who I got my parking break from was smart enough to set up the disc break to adapt a sensor to but it is another $110.0 delivered. I going to hold out for AA see if they come through.
12-18-2017, 07:18 PM | #700 |
Working on fixing 4 BOO BOo's on my truck the last 2 weeks.
1 fuel tank filler pipe in the wrong direction. Can't blame anybody but myself. I changed the direction at the last minute. shouda left it the way it was. 2 T-case tale housing not set up for variable speed sensor. Talked to Advanced adapters several time to get it corrected and the new housing they sent me does not fit in the back of my T-case even after heating up the case and cooling the tail housing. 3 rework exhaust X pipe to clear drive shaft. 4 oil pan oil sensor and slave cylinder for the clutch crashing into each other. had to pull out my friend card to get some help fixing these items. 1 welding the fuel tank filler in the correct direction. 2 tail housing have it drilled and tapped for the VSS. 22X1.5 thread. 3 raise the exhaust X pipe so the drive shaft will clear the X pipe. 4 moving the oil sensor to the left side of the oil pan by welding a piece of 3/8" thick aluminum to the side and taping it for 18X1.5 thread. |
