07-29-2018, 12:50 PM | #7051 |
Re: What did you do to your truck today? Chapter II
Fixed the horns and signal self canceler Bought a new turn signal switch but didn't like the modern 4 way button and using an adapter to my wiring. So I took parts from the new one to fix the original. Just needed the spring under the horn contact and the spring for the self cancel. New springs and all is good.
07-29-2018, 09:41 PM | #7052 |
1. Finished installing the transmission controller and wiring. 2. put the seat and carpet back in. 3. Glued the rear view mirror bracket on three times. ( It came off twice when I went to put the mirror on), ( 90 degrees and raining here today ). 4. Then I started taking out the plywood bed the PO put in, so I can rebuild the differential, install a top mount rear sway bar, and install a real wood bed.
1968 SWB Step Side, Big Block, 4L80E , Running! |
07-30-2018, 01:03 AM | #7053 |
How did I get this OLD!
Degrease and power wash the engine bay of the “Redheaded Stepchild”. Next is to detail in anticipation of the up coming 327 rebuild.
http://67-72chevytrucks.com/vboard/a...1&d=1532926760
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
07-30-2018, 07:21 PM | #7054 |
Bought a $20 Nissan truck car cover for my 69 off Facebook🤣 does the job.
07-30-2018, 11:17 PM | #7055 |
I bought one at Walmart on sale with a crushed box and I never put it on, but then again I've never washed my truck.
Do it, Do it right, Do it right the first time |
07-31-2018, 10:38 PM | #7056 |
Hauled the bug home from getting the electricals fixed. It now has lights. Once I finish the interior and flip it, time to get the body work done on the truck to paint it.
07-31-2018, 11:01 PM | #7057 |
Finished LS swap...
08-01-2018, 12:08 AM | #7058 |
Removed the box to freshen up the paint on the frame. Dimpled and test fit the power steering box prior to frame paint.
http://67-72chevytrucks.com/vboard/a...1&d=1533096343
08-01-2018, 08:37 AM | #7059 |
Frame Painting
Looks like a good project, how will you prepare the old surface to re paint it ? .
TIA,
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
08-01-2018, 12:26 PM | #7060 |
Blue flame adjustable and a BFH?
08-01-2018, 09:16 PM | #7061 |
New bearings on the drivers side rotor. And new tires all around. Amazing that they looked great on the outside but in the back side cracked like all hell. But the DOT code was the 42 week of 2010 so they were done. Should have looked when I bought it could have knocked a little off the price
08-01-2018, 10:31 PM | #7062 |
Yes. 2 applications for a precision fit lol.
08-02-2018, 07:34 PM | #7063 |
I knocked off all but one old mount from the flatbed. The last one is welded in multiple places & I need to buy a cutoff wheel.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
08-03-2018, 12:54 AM | #7064 |
70+ ( Old Skool Club )
I didn't do anything to my truck but was on the way home and the City had blocked off a main intersection for road repairs so I went down a back alley and lo and behold there was 68/69 GMC with a canopy sitting in a back yard with 90's Lincoln in fornt of it. Wife was with me so I'll go do some investigation when I'm alone and yes I'll get pics..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-04-2018, 06:36 PM | #7065 |
As promised he is the pic..
08-04-2018, 09:10 PM | #7066 |
Well, you've heard about the YouTube videos about the adult dog getting a puppy to play with....I bought Raymond a youthful stepbrother/daily driver today, a '98 Silverado Z71 XCab....no pics now, but will have soon
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
08-04-2018, 10:18 PM | #7067 |
finally found a tricky vacuum leak, with the advise of so many folks on this amazing board!!!
thank you all!!!!, for everything
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
08-05-2018, 12:33 AM | #7068 |
Prep and primer, more prep and more primer, repeat...
08-05-2018, 12:37 AM | #7069 |
Went to check the cam lash and found it would not move at all without deflecting the cover. I have not a clue what might have caused this. Cover comes back off and it will be adjusted again. Gasket was destroyed so now I have another set of waterpump gaskets and a front seal! Yay!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-05-2018, 01:22 AM | #7070 |
Got the "Stance" right on the "Shop Truck"~~Still much to do~~~~~
08-05-2018, 10:33 AM | #7071 |
Nice!!!!!!!
08-05-2018, 10:37 AM | #7072 |
New ride & Blue ride pic as promised....really happy with the '98...need to diagnose a warm engine hesitation & all will be good in the hood
Getting Raymond's timing chain & gears replaced will take care of that nasty disturbance in the force, as well
08-05-2018, 02:26 PM | #7073 |
08-05-2018, 02:28 PM | #7074 |
thank you!!!!
drove it to church this morning
08-05-2018, 02:54 PM | #7075 |
Not today but Thursday I met my buddy from Illinois at the Street Rod Nationals in Louisville Ky. Had a real good weekend. His saddle colored 68 with the old topper is very cool.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
