08-08-2018, 07:48 PM | #7101 |
Re: What did you do to your truck today? Chapter II
Thanks . Amazing what 40$and a little elbow grease can do.
08-09-2018, 07:28 AM | #7102 |
08-09-2018, 08:41 AM | #7103 |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-09-2018, 03:50 PM | #7104 |
I turned mine into a barricade to keep people off my new driveway. It's orange, so that works, right?
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
08-09-2018, 05:31 PM | #7105 |
I cut them from an old tread mill track and lined my fuel tank straps with it. Make sure you add some ground straps from the frame to the bed. Looking good, when do you get the engine back?
Do it, Do it right, Do it right the first time |
08-09-2018, 07:19 PM | #7106 |
Fresh new Concrete ~ SWEET ! .
I just washed mine again last night and am sad looking at the cracks and how it's settling below the side walk.... -Nate Last edited by VWNate1; 08-10-2018 at 02:42 PM. |
08-10-2018, 11:32 AM | #7107 |
Is that the Holley Mid mount Holley system? It looks so good.
I am about to do a 5.3 swap into my Blazer. I am so tempted to use the Holley system.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
08-10-2018, 01:14 PM | #7108 |
How did I get this OLD!
Good call on the ground straps! I cancelled the rebuild on that engine last week. Going to go a different route on the CST. 5.3 LS/4L60E. So I'm pulling the 327 out of the CST to put in "The Readheaded Stepchild". It had a recent rebuild and has LT1 double hump heads & and a new duel exhaust system as well as power steering. I expect the CST will be a 4-5yr build as my honey has me on a strict allowance. I have a lot of parts to get started. Time to photograph, remove, clean, paint, bag, tag, shelf. Lol
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
08-10-2018, 02:19 PM | #7109 |
Who Changed This?
Changed the oil this morning and noticed that the power steering reservoir is loose on the fender. Before I just tighten the bolt up, I'd like to see a picture of it properly mounted. There is only one bolt attaching it to the fender, but it has two nuts welded to it. I'm thinking it's not mounted in the right place. GM wouldn't use a bracket like that and not have two bolts in it, methinks.
08-10-2018, 02:50 PM | #7110 |
Post Whore
doing some simple wire rerouting as inspired by Lucky Costa of Mobile Tech Lucky. this is where I run the red and purple wires from the starter right into the hole in the firewall right by the starter instead of dragging them across to the bulk head connector, and I do the same for the brown alternator wire and the pink ignition wire run them through another hole in the firewall and into the cab, makes the engine bay look so much cleaner
08-10-2018, 03:22 PM | #7111 | |
I love it, dont love the circumstances of why it was replaced. But hey, that's what we pay for insurance for.
08-10-2018, 07:52 PM | #7112 | |
08-10-2018, 08:20 PM | #7113 |
I believe his truck is a big block. Big blocks had remote resavoirs.
08-10-2018, 08:48 PM | #7114 |
Who Changed This?
Yup. After looking at pictures all over the place, it looks like it is in the right place, but if the reservoir mount has two welded-in nuts, it puzzles me as to why there aren't two holes in the fender. That's the way it is shown, but for other years there is a mounting bracket that has the reservoir standing off of either the fender or the radiator core support. I dogged the single bolt down gutentight. That's going to have to be it for now. My FiL did all kinds of hacks to the truck, which I am slowly backing out, like all the power wires he ran under the carpet for some aftermarket geegaws.
08-10-2018, 09:12 PM | #7115 |
The bezel turned out nice, what kind of paint did you use on the needles? Just curious
because I want to do mine.
Aaron |
08-10-2018, 09:52 PM | #7116 |
" My FiL did all kinds of hacks to the truck "
Don'cha just love DPO & DPM bodges you keep stumbling across ? .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
08-10-2018, 11:02 PM | #7117 | |
Who Changed This?
Re: " My FiL did all kinds of hacks to the truck "
The only time I made a "blacksmith repair" was on a Sunday, when one of my friend's (drunk) dad drove over a long series of pylons on the freeway and trashed the shifting mechanism and valve body on his Nova. He brought it to me, and I managed to use a punch, hammer and files to get the parts back together so that it would shift from the lever inside the car again. I gave him a list of the parts that needed replacing, but I don't know what he ever did with it. The required parts and an explanation of why they were needed was clearly spelled out on the work order. He may have been my friend, but it protected all of us when the terms were completely spelled out.
08-11-2018, 01:00 AM | #7118 |
Today was a milestone, I can start building the truck. Had the frame, cross members, A/C brackets and some other powder coated for the first run. $1150, and well worth it, better than new.
Dropped the axle off for the once over too. They're setting me up with a 1-piece shaft. Guess I better order some suspension huh? Going deep into the pocket this month
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-11-2018 at 01:06 AM. |
08-11-2018, 04:13 AM | #7119 |
Bodge Repairs
@Steeveedee :
I say 'dang previous owner but it's essentially the same thing..... easily 1/2 of the repairs I did as a Journeyman mechanic involved some sort of first un - doing some ill considered bodge repair . You're right the person doing halffast repairs is legally liable but proving who made the mess is difficult . I mostly worked on older vehicles during my long career so I got to see more bad repairs and patches than do most . OTOH, I learned a lot about field repairs at the same time.......
08-11-2018, 07:49 AM | #7120 |
Krylon fluorescent orange
08-11-2018, 08:00 AM | #7121 | |
Your going to need one of these when your done |
08-11-2018, 08:42 AM | #7122 |
I had the truck undercoated and a paint protection applied. No waxing till death do us part! A new set of snow tires and I'm ready, cause it's coming.
08-11-2018, 11:09 AM | #7123 |
08-11-2018, 01:11 PM | #7124 |
No kidding, that is beautiful. Chevelle in a plastic bubble.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-11-2018, 02:58 PM | #7125 |
It is trying not to catch LStuner disease
