Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-02-2017, 01:18 PM   #701
andytobinskb
Re: Power Steering Adapter Plates
Thank you for your knowledge. I will be ordering one in the near future. Do you also make the steering linkage with the universal joints that i saw in the thread that you shared.
andytobinskb is offline   Reply With Quote
Old 02-03-2017, 12:58 AM   #702
Captainfab
60-66 Nut
No I do not currently make a collapsible steering shaft coupler with u-joints. I have been wanting to but just not enough time with working 80hrs/7 days a week every week every month.
Old 02-05-2017, 11:30 AM   #703
Tscustoms
I'm looking to purchase one of the brackets for my 65. I have sectioned my crossmember 2" and moved forward am inch. Will I be able to move the bracket the same to correct my steering
Tscustoms is offline   Reply With Quote
Old 02-06-2017, 01:10 AM   #704
Captainfab
60-66 Nut
With what you are doing, the supplied template will be of no use. I have no idea what you will need to do to mount and support the steering box adapter plate as I have never done anything like this.
Old 02-06-2017, 10:23 AM   #705
Tscustoms
Does the. Template line up with the factory holes for the non power steering box
Old 02-07-2017, 01:00 AM   #706
Captainfab
60-66 Nut
The installation template does reference the holes for the original steering box to position the power steering box.
Old 02-22-2017, 01:21 PM   #707
HugoV
Captainfab - I am sure this has been answered already but I am short on time this morning to search on your thread...
I have a power steering box from a 68-72 truck that I need to install on my 64' c10 2wd, will this bracket be the one I need in order to get that done?
If so, send me a message on where to send payment and how long it will take to get to me to 98059.
Thanks!
HugoV is offline   Reply With Quote
Old 02-23-2017, 01:24 AM   #708
Captainfab
60-66 Nut
All '68-'86 C/K series and '87-'91 R/V series steering boxes are all interchangeable.
Do you need just the steering box adapter plate, or do you also need the tube and flange?
I will send you a PM with ordering and payment info.
Old 03-06-2017, 05:52 AM   #709
spitfire980
spitfire980's Avatar
I have a 67 C10 and was i wondering if you can manufacture the required four 1/4" thick spacers for the power steering box to fit.
Since in my part of the world, cutting up the frame is in instant registration fail and the manufacturing quality isint the best in the world if i wanted to fab the spacers myself
spitfire980 is offline   Reply With Quote
Old 03-07-2017, 12:18 AM   #710
Captainfab
60-66 Nut
I will send you a PM.
Old 04-08-2017, 12:27 AM   #711
Captainfab
60-66 Nut
Here are a couple more pics of the tube and flange that many are not aware of. This is a simple way to connect the original steering column shaft to the rag joint if you do not have a drill press and a welder to make use of the original flange as shown in the installation instructions. The cost of this tube and flange assembly is $25.00
Old 04-24-2017, 11:09 PM   #712
Nootz
Capt, anymore plates for sale? Can I use on my 62 c10?
Nootz is offline   Reply With Quote
Old 04-24-2017, 11:13 PM   #713
Captainfab
60-66 Nut
I build and ship all of my products everyday including the steering box adapter plates. I already replied to your PM.
See post #626 regarding the '60-'62 frames
Old 04-25-2017, 04:40 AM   #714
Sinisterv10
John,
Once again, thank you for the speedy delivery on the parts. I am using the rear disc brake brackets on my sons 77 c10. Now i'm trying to make time to install the power steering gear box brackets on my 60 frame along with the trailing arm perches. The quality of your products excellent and and fitment is perfect.
Sinisterv10 is offline   Reply With Quote
Old 04-25-2017, 11:18 PM   #715
Captainfab
60-66 Nut
Thanks for the compliments and the purchase
Old 04-26-2017, 10:58 AM   #716
Brad54
Brad54's Avatar
Without going thru the whole gazillion-page thread on my phone, do you make an adapter for 4x4 chassis? In my case,
60-62.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 04-26-2017, 11:20 PM   #717
Captainfab
60-66 Nut
I do not make a steering box adapter plate specifically for the K series frames. I have sold many of these plates to customers that have installed them on their K series frames. Check out Les Otte's installation on his '64.
http://www.67-72chevytrucks.com/vboa...632508&page=6t
60-62.
Old 05-08-2017, 05:47 PM   #718
oldarky66
Captainfab,
I need one of your power steering adapter plates. Please send all necessary info at your convenience.
Thanks.
oldarky66 is offline   Reply With Quote
Old 05-08-2017, 11:29 PM   #719
Captainfab
60-66 Nut
I will send you a PM........
Originally Posted by oldarky66 View Post
Captainfab,
Thanks.
Old 05-10-2017, 01:38 PM   #720
oldarky66
Captain,
Mailed you the MO for power steering plate adapter this morning. Did this before seeing your latest pm so sorry it does not include my forum user name.
I'll post on here when I receive it.
Thanks,
Wade
Old 05-17-2017, 03:05 PM   #721
oldarky66
Captainfab,
Received my adapter plate today. Thanks for fast service and great product.
Old 05-17-2017, 11:42 PM   #722
Captainfab
60-66 Nut
Thanks for the purchase, I appreciate it
Old 05-18-2017, 11:20 AM   #723
pmeyers
Captainfab,
Just finished the brakes on my 62 C10 that has a hydraulic clutch - drum/drum. I want to add a booster using your kit including the mounting bracket and wilwood clutch cylinder.
I just picked up an early 90's Booster and master cylinder setup from a Chevy 1500. Bolts measure 3 3/8x 31/2 so booster should be fine. Wondering if I can use the mc that is already on it or do I need a different mc. Also from reading previous posts it appears that I can eliminate the proportioning valve since it is drum/drum? I can post a pic of the booster assembly if it would help. Will get my order in as soon as I am sure I have the right parts. Thanks for your help,
Paul
pmeyers is offline   Reply With Quote
Old 05-18-2017, 04:31 PM   #724
pmeyers
Posted to the wrong thread. Move it to the brake booster thread.
Old 05-30-2017, 07:23 AM   #725
OldChevy61
OldChevy61's Avatar
Capt. Will I have to do anything to the centerlink to use this system? Or just the plate, gearbox and pitman arm.
OldChevy61 is offline   Reply With Quote
