10-26-2014, 02:17 PM | #701 | |
Re: 69 GMC "Ol' Blue"
10-26-2014, 09:35 PM | #702 |
Made some good progress today on the fuel lines. I had initially installed the tank backwards, which I thought would be fine...obviously it wasn't. I'm ok with it though, because I think the tank straps turned out better this time around anyway.
This was mostly an experiment. I didn't think I could cut and flare these lines on the sending unit. Backwards Flipped All strapped up |
10-27-2014, 11:11 AM | #703 |
Beauty, looks really good!
What is that did you hear it? I think it's going to be a runner!! What's left some wiring for a test fire?
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
10-27-2014, 01:28 PM | #704 |
Still Learning
Nice progress.
10-27-2014, 08:02 PM | #705 |
6>8 Plugless........
Nice work. Backwards like you had it would help the fill tube, but not the angle of the tank. Nice work though. I'm putting a 38gal rear tank in my 95 F350, and it isn't nearly as pretty as your truck.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-27-2014, 10:22 PM | #706 | |
I think that really should be my next focus. I need to install my fuel filter, run some wires, and at least pressurize the fuel system to inspect for leaks. After all, I did flare some of these lines Thanks Mike! Thanks Ryan! Honestly, that was the whole reason I mounted it the way I did. I wanted the fuel filler on the driver's side. Oh well, I'm just glad to have that project 90% done. 38 Gallons?!?! That's gonna cost a fortune to fill |
10-28-2014, 12:56 AM | #707 |
tank look sweet. I install a 18 gal Camaro tank in my truck with rear gas inlet.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
10-28-2014, 10:13 PM | #708 |
sweet
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust |
10-29-2014, 12:04 AM | #709 | |
Thanks! |
10-29-2014, 04:46 AM | #710 |
If you were set on a driver side filler maybe find a welder that could turn the goose neck and re weld it? I say find a welder because after my filler neck pita with a mig i know a Tig would be a much better way to go.
Looks nice, just like it was made to fit.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-01-2014, 09:48 PM | #711 |
I agree drivers side would be nice but maybe you won't wait in line as much with it being on the right side. Seems like their is always a pump open at the Costco when I fuel our cars with pass side fill?
11-29-2014, 08:01 PM | #712 |
This is a very small update, but I finally have the fuel lines done.
11-30-2014, 12:06 PM | #713 |
One step at a time small or large is still one step closer to driving it.
11-30-2014, 12:22 PM | #714 |
Mike, looks awesome! I just got back into town and gotta get going on my final teardown of the control arm shafts.
PS. Why not run a hard line all the way to the tank? Is that possible?
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
11-30-2014, 12:26 PM | #715 | |
Thanks Jason! I guess you could run hard lines all the way to the unit, but I think the rubber lines serve two purposes. 1 - they are a bit more forgiving for alignment purposes, and 2 - they allow flex between the frame and the tank. Hard lines would probably end up breaking over time. Just my thoughts |
12-01-2014, 01:07 PM | #716 |
Good job Mike. What's left to fire it up, electrical? I'm guessing that you hear it run will give you tons of motorvation!
12-02-2014, 12:07 AM | #717 |
Thanks Brett! I have quite a few items to work on. Flywheel, clutch, figure out what starter I'm going to need, new exhaust manifolds, and then electrical...then it should roar to life
12-02-2014, 11:10 AM | #718 |
In that last picture, it looks like the filler pipe for your tank was laying right on the frame. Had to scroll up to another picture to see it was just the camera angle. Nice that you can check fuel lines off the list - looking good!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
12-02-2014, 09:55 PM | #719 |
Thanks Rick! Now hopefully I can get this whole flywheel/clutch thing figured out. That will be a big one checked off!
12-05-2014, 05:52 PM | #720 |
What are you thinking hydraulic or mechanical? You did move the motor forward for the gear splitter correct?
12-07-2014, 01:51 AM | #721 |
I'm going to stick with the mechanical setup. I am ordering rod ends and chromoly tubing to build a bullet proof clutch linkage, and I will need to modify the frame a bit to accept the Z bar, but I think I'll be in good shape there. Where I'm struggling now is to make sure I get the correct flywheel for the '91 engine and the correct clutch and pressure plate for the SM465 and starter that will fit. It's been kind of a challenge, but maybe I'm just over-thinking it.
12-12-2014, 11:28 PM | #722 |
Nice progress since last time I checked in, Mike.
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
12-13-2014, 05:21 PM | #723 |
Thanks Nick! It's coming along, but may be coming to a screeching halt come tomorrow. I have the opportunity to pick up a '73 Vette that is a numbers matching 350 4-spd coupe. The only thing that makes this car worth it is it's condition and the fact that it was a black on black car which was not offered as an option in '73, but there were about 30 of them that left the factory in black. It will end up being a quick flip (I hope) and the price is just too good to pass up.
12-14-2014, 11:40 PM | #724 |
Well, the Corvette deal fell through. It wasn't originally a black on black car like I hoped. It was silver when it left the factory, and that just wasn't worth putting this project on hold for.
So, today I finally figured out the clutch linkage situation. Since the engine has been moved forward 2 inches, it put the Z bar right into the side of the frame. I ended up making a bracket to move the pivot ball back and ground the frame bracket off so I could also move that back. This is a major hurdle that has now been solved! |
12-15-2014, 12:57 AM | #725 |
Nice job on the z bar and as for the Corvette...well just how things happen, truck need you more anyway.
