02-01-2017, 01:36 PM | #701 |
Re: My 78 K15 High Sierra build - Fish Tremble
I am running a manual. Maybe its not actually called a neutral safety switch, but there is a switch that attaches to the clutch pedal that I'm pretty sure will prevent starting if you haven't pressed in the pedal. I had a heck of a time finding a replacement for this which is why I ended up with an old NOS switch from ebay.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
02-03-2017, 01:30 PM | #702 |
Hey Rick. I bet that's your issue. My 72 Did not have one installed with my manual. It did come with wiring on the AAW kit, but I bypassed. You could also use this NSW wiring to add a security feature like switch or something obscurely located. This would ensure the truck is immobile unless you get in and flip the hidden switch. I also thought about putting a keyed switch somewhere that is accessible on the outside of the truck, but would allow you to essentially kill the truck when your away from it.
For now, I'm sure just starting and driving would be good. Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
02-03-2017, 02:00 PM | #703 |
If the switch turns out to be bad, I'll definitely just bypass for the time being. I'd guess to bypass I just need to run a jumper between the 2 sides of the NSS connector on my AAW kit.
That's a good idea about using it as a kill switch. I do have an external kill switch set up, but if 1 is good 2 must be better
02-03-2017, 02:06 PM | #704 | |
02-05-2017, 06:32 PM | #705 |
Turns out that the neutral safety switch was OK. Problem was that pushing in the clutch pedal shoved a bunch of unsecured wiring back, pulling the connector off the switch Truck starts fine with the key once I rearranged some of the wiring rats nest under the dash. I've still got to run AC ducts and do some insulating up under there so I'd been holding off cleaning that up. Also received the electric choke I'd ordered from quadrajetparts.com, but turns out the AAW kit doesn't include the correct 'L' connector, so had to order one and that project will be on hold til it shows up.
Also spent a bunch of time troubleshooting my backup lamps. Started at the switch in the SM465 and worked my way back. Should have started at the back - the bulb sockets that came with the AAW harness are pretty worthless. One of those deals where a) they don't want to hold into the taillight housing very well, and b) the bulb has to be in exactly the right spot to work. Flick the bulb a bit and it goes out. Ended up cutting those sockets out and using my original ones. Works fine now Got my kids to help and was able to get the hood mounted. Also learned how to unlatch the hood without damaging anything if the interior hood release handle doesn't work. Of course, it helps if you pull the "hood release" handle rather than the e-brake release I think the new rubber bumpers along the top edge of the fenders is holding the hood a little high. Hope that will settle a little over time. Also mounted the rest of the mouldings, so other than a little fiddling the exterior is DONE!!! Dang it's tough to find a good looking repro grille for these GMCs! Found one at Brothers that looks like the one already on my truck - in chrome rather than gray, silver or black that all the regular shops have. $90 sounded ok, so ordered but its on back-order with no estimate of when they'll have it. Enjoy the SuperBowl, and the time with family & friends even if you're like me and could care less about either team.
02-06-2017, 01:34 AM | #706 |
That looks amazing!!!
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
02-06-2017, 11:24 AM | #707 |
Looks great Rick! What a game, jeez louweez!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
02-08-2017, 07:20 PM | #708 |
Thanks! It's beginning to feel like its all been worth the effort
02-10-2017, 12:39 AM | #709 |
Fantastic
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
02-13-2017, 05:00 AM | #710 |
More than worth the effort, its beautiful!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-13-2017, 08:10 AM | #711 |
The truck looks awesome!
02-13-2017, 08:29 AM | #712 |
Thank you! Truck made it out of the shop, down the street, around the cul-de-saq and back on its own power this weekend. Twice actually. Pulling back into the drive when I spot my wife standing there glaring at me - how dare I make the maiden voyage without taking her along? So she climbs in the passenger side, takes a seat on the floor since I didn't have a second concrete block in there for a passenger and up and down the street we go
So the truck did ok. Doesn't want to stay running on its own until it gets fully warmed up. Couldn't get it to shift into 1st. Guess my stick rebuild needs a little tweeking. Brakes worked fine, but I didn't try any hard stops or from any real speed. Steering feels odd, no resistance at all to help hold the wheel centered, but that may just be something I have to get used to again. Also the front end is just eye-ball aligned for now. Clutch pedal feels like it has about 1 foot of travel - need to figure out whether adjustment is needed. But she runs and drives!!!
02-13-2017, 10:31 AM | #713 |
Very Kool!
02-13-2017, 10:46 AM | #714 | |
Enjoy....sounds like she's almost road worthy. Chris
02-13-2017, 12:04 PM | #715 |
Congrats that is too cool! All the quirks sound exactly like my 77 K10 with a SM465 pre fuel injection. Post fuel injection it all stayed the same except you can get in it and go on a cold start hahaha.
02-13-2017, 08:46 PM | #716 |
It's looking awesome Rick. You are so close, your first road trip is in sight!
-Brett |
02-14-2017, 03:33 AM | #717 |
It's a great day!
02-14-2017, 12:35 PM | #718 | |||
Thanks Brett!
Yes, it was - thanks! I've already decided that the concrete block is NOT going to provide a reasonable level of comfort for longer trips, so I've already torn down the old bench. I've got upholstery and new foam, but it looks like I'll also need some new springs. BTW, what are the odds that I'd be responding to 3 Brett's in 1 post?
02-21-2017, 09:35 PM | #719 |
Kind of late getting my update posted, but nothing terribly interesting. Not interesting can be very time consuming though! Spent several hours on a creeper under the truck cleaning up all the wiring for the taillight and fuel harnesses. Final routing now that I know the circuits work, cutting and re-splicing to length, getting the wires into conduit and securing to frame, etc. Hard to get good pics under there, so just a token. Also started connecting everything up for the stereo head unit connection. Got some work to do here still.
02-22-2017, 09:32 PM | #720 |
Fantastic work, I can use these as references for the future when I get this far along. Perhaps I missed it from an earlier post but what did you coat the transmission cover plate with? Keep up with the great non-interesting progress!
02-22-2017, 09:42 PM | #721 |
Thanks for checking in quadzero.
What you see on the transmission hump and the rest of the cab floor is U-Pol Raptor Liner. I'll go over the top of that with whatever sound deadener and heat insulation I come up with - still researching that.
02-22-2017, 09:59 PM | #722 |
It followed me home?
just started following along, looking good!!!
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
03-05-2017, 01:42 PM | #723 |
Thanks Adam! Only progress on small things last couple of weeks. I'm still trying to decide what products I want to use for insulation and sound deadening. Also, a few months ago I bought foam and upholstery to redo my bench. Come to find out, I've apparently got an 81-87 bench which is not the same as 73-80, so I'm on the hunt for a new bench.
I have done some work shimming the bed and working on getting better fit and alignment on my trim. Repainted the GMC in the tailgate band - came out much better this time. Also working on the stereo. Ended up getting classiccarstereos.com USA-630 so I needed to fix my radio opening. This was kind of a PIA and isn't too pretty but I think it will work. I'll have to do some paint touchup inside now. I didn't realize that the opening for the heat/ac stuck out beyond the dash bezel so far. I guess subconsciously I thought I had that much space when grinding and masking for primer - oops! Also mounted my corner speakers in brackets I got from member BigBlock73. I've made all the connections for the stereo harness, but the head unit isn't powering on so I'll be troubleshooting that this afternoon.
03-05-2017, 04:22 PM | #724 |
Really looking forward to the finished dash. Are you going to run amps as well?
03-06-2017, 11:35 AM | #725 |
Very nice!
