12-18-2017, 10:40 PM | #701 |
Re: 71 4X4 Frame off Restoration
That's why it's called a build, hey at least your on it and it's getting better a bit at a time, or two times, still cool. Happens to us all, well me at least too.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
12-18-2017, 10:43 PM | #702 |
Cant tell you how many times I had to back up and start over....do it again is my motto LOL!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-18-2017, 11:36 PM | #703 |
Them damn filler necks are a bit$#! Lol. Where are you putting the cap?
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
12-19-2017, 11:03 PM | #704 |
I had gas cap door from 2004 Suburban welded in the quarter panel.
12-20-2017, 12:01 AM | #705 |
6>8 Plugless........
There's always something especially when you're making great progress. At least you were able to use some of the friend cards. Usually those are always out going and not getting returned.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-20-2017, 01:06 AM | #706 |
Are you going to install the same door in you new bed sides or is that what you did to the new bed sides?
12-20-2017, 10:04 AM | #707 |
It's always something!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
12-20-2017, 11:07 AM | #708 |
the door was cut out of the first bed side and welded into the new one.
12-20-2017, 12:35 PM | #709 |
oh got you! I am thinking I should have just put a door. This taillight filler is killing me! And after I am done I am not sure how it will fill!!!
12-20-2017, 12:39 PM | #710 |
I have seen couple of other cars and truck with the filler behind the tail light done similar to what your doing.
12-31-2017, 09:29 PM | #711 |
Got my tail housing back couple days ago and reinstalled it with the variable speed sensor. my friend did a great job machining it.
12-31-2017, 09:34 PM | #712 |
Got my fuel tank back with the filler pipe in the correct location. I reinstalled the tank showing the filler pipe going out to the left.
01-19-2018, 10:42 PM | #713 |
I had my flexible break lines made this week and started to install them. Fitting good so far. Talked to my painter today he wants my frame to line up the paint lines in about week and half. can't wait to see it painted.
01-23-2018, 11:53 PM | #714 |
Advanced Addapters finally sent me a return shipping label so I can return the tail housing that did not fit my transfer case. should get $200.00 back. bought a tubing bender so I can make my hard break lines. hope it works for the 3/16 lines I have to bend up.
01-24-2018, 10:56 AM | #715 |
Yes, paint! Are going to leave the body on for the rest of the build?
01-24-2018, 08:35 PM | #716 |
I'm sure you're very excited to see color on it! Nice work on it. That is always nice to get some extra cash for parts,. There's always something else needed right around the corner.
01-24-2018, 11:56 PM | #717 |
02-05-2018, 04:06 PM | #718 |
Could someone confirm the bolt size for the back cab bolt to frame. I thing it's 7/16 14 thread. I don't have my cab at home to confirm. Thanks
02-27-2018, 03:40 PM | #719 |
I loaded up my truck last night so I can go to South Bay Drive Line to have my drive shaft measured and start building them. this is the first time my truck has left the house sense I tore it apart.
03-01-2018, 02:08 AM | #720 |
Hey David that is exciting. I can’t wait to see it.
03-05-2018, 02:18 PM | #721 |
I received a text Sunday I should be seeing some color on my truck by the end of this week. I have my fingers crossed.
03-05-2018, 05:14 PM | #722 |
landarts
That has to be a great feeling. All the work you have done is excellent on that truck and to finalize with some color is a accomplishment. Excited to see the new paint!
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
03-06-2018, 01:13 AM | #723 |
Nice can’t wait to see it!
03-08-2018, 01:27 AM | #724 |
I picked up my driveshafts Tuesday after work. Had to modify the cross member to fit the front shaft and started on the rear shaft. Have set up center bearing next.
03-09-2018, 10:00 AM | #725 |
Under Construction
nice work.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
