Closed Thread
Old 07-13-2013, 08:51 PM   #7426
Expat_dude
Expat_dude's Avatar
Re: What did you do to your truck today!
Vintage AC panel going in
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Old 07-13-2013, 08:53 PM   #7427
nlped
nlped's Avatar
^^^ I like that!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 07-13-2013, 09:12 PM   #7428
Harpie
Harpie's Avatar
I have that same control setup for mine and was thinking about doing something similar. What did you use to mount that in? I was thinking about a radio delete panel but that looks fantastic.
Harpie is offline
Old 07-13-2013, 11:04 PM   #7429
3drburb
Washed it, then painted the front bumper.
3drburb is offline
Old 07-13-2013, 11:44 PM   #7430
wreckedchevy
wreckedchevy's Avatar
I committed some more sacrilege and used a crown vic wire harness as a donor to make a new engine harness. not exactly a MisterB underhood cleanup but atleast it doesn't cut out when I hit a bump and I can finally get to those last two plugs :-)
does anybody out there know what the fuseable link running to the battery is suppose to be for? I looked at the wiring diagram can't tell what it's actually for, mine's always been disconnected. thanks
Before
After
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline
Old 07-14-2013, 02:30 AM   #7431
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
The Fusible Link is *supposed* to fry if you get a dead short in the primary hot wire , this in theory , prevents electrical fires from burning your Ship Of The Highway to the water line before you can call 911 .
The idea is to use the lowest value one you can that won't get hot and melt or go open circuit .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 07-14-2013, 04:14 PM   #7432
zellway
zellway's Avatar
Added some tunes to my suburban.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 07-14-2013, 04:34 PM   #7433
DaddyO
DaddyO's Avatar
Originally Posted by DaddyO View Post
Today I mounted a pair of 20 x 8.5 Coy C5 polished wheels on my 67.The tire size I went with is 255 / 40 / 20 Toyo Proxy ST II. In the rear I'm running a 20 x 12 with a 315 / 35 / 20 Toyo Proxy ST II.
.......pics to follow....
ON them 20s........
DaddyO is offline
Old 07-14-2013, 04:46 PM   #7434
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I am finally getting back to my 7deuce... I washed her for the first time in years and got her outside..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 07-14-2013, 05:16 PM   #7435
PAWS 72
PAWS 72's Avatar
ON them 20s........
good looking truck.
PAWS 72 is offline
Old 07-14-2013, 05:47 PM   #7436
dirtyjim
dirtyjim's Avatar
did a little work on my shifter for my 700r4, i reworked the original 4 speed shifter. i still need to extend it a few more inches, tweak the gate on it & make a shift boot.
i also picked up a cool looking speedo and gas gauge out of a buick la sabre from the junk yard along with a gauge style gear indicator, not sure if i'm going to use them on my truck yet.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline
Old 07-14-2013, 05:56 PM   #7437
'68 Short Step
'68 Short Step's Avatar
Installed my new drive shaft which solved all of my problems of the truck violently shaking at high speeds. So now it rides like a dream and I sped down the highway for about an hour.
'68 Short Step is offline
Old 07-14-2013, 07:25 PM   #7438
SuperC10Tex
SuperC10Tex's Avatar
"I'm a GMC butt man", I said it!!! Just put on all new tailgate trim and a new bumper on the 70'.....could not pass up the photo op.
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline
Old 07-14-2013, 07:56 PM   #7439
jhyder408
Thursday I put in new rear shocks, finished hooking up back-up lights, replaced and bled flex lines for brakes, painted doors to match the rest of my satin black truck, then Friday I took to our collector car appreciation day at my place of employment. The Filling Station.
I would post pics but it wont let me.
'68 C10 Step Side, 250 6cyl, converted long to short, work in progress
jhyder408 is offline
Old 07-14-2013, 08:09 PM   #7440
jhyder408
Old 07-14-2013, 08:13 PM   #7441
jhyder408
Old 07-14-2013, 08:35 PM   #7442
jhyder408
Originally Posted by jhyder408 View Post
also, last weekend I completed my 68 to 67 front clip change.
Old 07-14-2013, 10:00 PM   #7443
70C10Toejam
Hellasick
70C10Toejam's Avatar
Installed my $30 headlights from good guys.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline
Old 07-15-2013, 12:06 AM   #7444
xludan
Slapped some color on the 71
1971 C10 Cheyenne Super Build Thread Here: http://67-72chevytrucks.com/vboard/s...d.php?t=411867
xludan is offline
Old 07-15-2013, 12:34 AM   #7445
ItsRandy
ItsRandy's Avatar
Disconnected the vacuum advance and re-timed my truck. 10* btdc and left the vacuum advance disconnected (like GM told me to do) gives me 36* total advance just like I should have. Runs a bunch better.
ItsRandy is offline
Old 07-15-2013, 01:20 AM   #7446
jonny..2008
Did upper column bearing.
what a huge difference.
it felt like the new pump was going out.
first vid (18 sec is before with intermediate shaft off.
http://youtu.be/wnIfpohlFRU
second vid is after steering wheel off.
http://youtu.be/zgcOth6qeBA
fixed upper bearing.
http://youtu.be/A5pGUbyRyFI
and am i mentally disabled? or is there some magic trick to embedding a video here? or both?
i love every machine. even the ones i hate.
Current project (1959) fifty niner gmc fleetside:
http://67-72chevytrucks.com/vboard/s...70#post6514670
MY daily driver truck thread : http://67-72chevytrucks.com/vboard/s...d.php?t=544460
jonny..2008 is offline
Old 07-15-2013, 02:47 AM   #7447
FloatMonkey
FloatMonkey's Avatar
Washed the truck for the first time since I got it back from the body shop. Also got the wife to drive it around the block for the first time with the new fuel injection system on it.
FloatMonkey is offline
Old 07-15-2013, 11:28 AM   #7448
BugzC10
BugzC10's Avatar
Added a oil pressure guage...not in your usual location. I have a guage in the dash, but it only has graduation marks. I want to know he numerical number. I attempted to tee into the line that goes to the back go the block next to the dizzy, but no luck in finding a tee that would work. And I could not get the plug above the oil filter to budge, so I put it up front. I seem to be alway messin with some thing under my hood so I figured this spot would be perfect. I have pretty good pressure at idle...~25psi.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 07-15-2013, 12:14 PM   #7449
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Charged the Vintage Air system. Good day to do it. Hot day in Buffalo, NY. Hit 91-degrees.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline
Old 07-15-2013, 12:23 PM   #7450
in deep 72
in deep 72's Avatar
Cage in progress. Bout half done....Going to need to find a powdercoater soon.
It's not a certified cage as you can see. It's pieced together 2.5" 3/16 wall. It won't be as strong as contimuous tube, but will at least be able to mount the seats and belts to it. Better than nothing and all the tubing was FREE! Thinking it will get a bikini top eventually.
Yet to do, seat bars... 2 more runners along the top....and make pipe gussets where the side runners and the vertical hoops tie together.
in deep 72 is offline
Closed Thread
