09-08-2018, 11:45 AM | #51 | ||
Re: Help! What has happened here?
I bet that motor runs at least 100k miles with no other issues.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
09-09-2018, 10:07 AM | #52 |
Did the machine shop replace the stud as well ?
They did not charge you for any of the work ? |
09-09-2018, 03:23 PM | #53 |
Post Whore
Yes, the stud was replaced, new valve (#6 exhaust), new gaskets, different rockers, all valves removed and qualified at no charge.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-09-2018, 03:35 PM | #54 |
I would of thought they would of replaced the intake valve for #6 since that was the rocker/push rod damaged area not the exhaust.
What type of rockers did you say they installed ? |
09-10-2018, 12:42 AM | #55 |
Post Whore
Whoops! My bad it was the intake valve, not the exhaust valve. The rockers are later model self aligning 1:5 ratio rockers.
The engine is back together and running nicely. Smooth and no misfires! I spent about two hours filing the header gasket flanges and it has made a difference in the noise level inside the Burban. It would have been much easier to clean the flanges up at work, (Nice big belt sander there) but I didn't want to wait another day to get back on the road. Thanks again to everyone who contributed their time and knowledge to the thread!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 09-10-2018 at 12:53 AM. |
09-10-2018, 10:21 AM | #56 | |
Another possible option on header gaskets... I was guided toward the Remflex thick ones. For my headers my machinist recommended part number 2006. The rest of my front end is not yet together, but I plan to get it going in the next month or so and begin testing them.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
09-10-2018, 10:53 AM | #57 |
header gaskets at engine trick i have used and was shown years ago .
2 sets of basic felpro exhaust manifold gaskets . double them up and tighten down and good to go .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-10-2018, 05:15 PM | #58 |
Post Whore
The biggest issue with getting headers to seal is the fact that the flange surfaces ( The raised bead around the port that contacts the gasket) are very rarely flat and in plane with each other. If they are not true then you have to rely on the bolts to bend the flange plate enough to get consistent pressure around the flange surface to clamp the gasket equally around the port. Not likely in most cases.
Using a large belt sander to grind all four ports at once will get you the flat and true surface that will allow most gaskets to work. ( It can be done with a file and a carpenter's level that is longer than the header flange plate. With careful filing and frequently checking to make sure you are staying in plane you can get the same result. It just takes longer.) In addition it is good to have the width of the raised surface to be between 1/8 and 3/16" wide and fairly close to the same width across on all of the flanges so the gasket crushes equally on all tubes. This usually requires a couple of hours to get a pair of headers so they will be heartache free. The factory spent less that 1/4 of that time building them from scratch in whatever foreign land they like. I once put 10 hours into making a set of AMC dogleg headers work. They have about 19000 miles on the first set of gaskets installed. Oh look! Now I've highjacked my own thread.
