09-19-2006, 06:55 PM | #51 |
PROJECT 7DEUCE
Re: Trail Use - Blazer
Kurt does that thing have hydro assist or full hydro steering on it? Spool in the front is gonna break those u-joints you need ctms ot ox style u-joints with a good chro moly axle i dont know who you got the 4340s from but I hope they stand behind there stuff (btw warn does not)
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-19-2006, 09:44 PM | #52 | |
Upgraded the u-joints from stock but didn't go ctm's or anything more. Place called fourwheelsupply on line is where I found them. http://www.fourwheelsupply.net/ So what's so different than running a locker? Or a welded diff? Or even a limited when it's locked up and turning both axles? Why would you break more stuff with a spool? A locker does the same exact thing but does it mechanically. From what I've seen, it's the partial clip on the outer shaft that gives way, then thing's break from there. These 4340 axles have full circle clips to 'supposedly' prevent that. Even a selectable diff is locked solid when engaged, seems to me the on/off/on thing could cause more load and stress than just a spool if engaged at the wrong time. Interesting subject for sure, thanks for your input. Last edited by vtblazer; 10-08-2006 at 11:05 AM. |
09-19-2006, 10:44 PM | #53 |
PROJECT 7DEUCE
Kurt I was suggesting the hydro assist because with the front end welded or spooled it will be very hard to turn when when both hubs are engaged. The hydro makes it to where even fully locked you can still turn the wheel with your index finger. I am not agianst the spool set-up (my yota is welded front and rear)but with a spool the axle ears and u-joints become the weak links(fusible link)and when the joint lets go the ears on the axle shaft get beat up pretty bad and sometimes torn off the axle completely. When the full circle clips dont pop out the cross of the u-joint will usally snap in half..Here is a link for you to check out these are the axles I am running in my v-8 powered yota http://www.longfieldsuperaxles.com/ I am running the yota super set very $$$ but garanteed for life cannot beat that he also has the u-joints that are lifetime gauarantee.... Kurt what kind od hydro asist do you have??
09-20-2006, 06:17 AM | #54 |
Longfields rule for sure, I know other guys that run them.
I see that they sell the 4340 axle as well and call it the strongest axle out there. I'm sure that @ around 6000lbs, I'll be working the axles pretty hard. Getting a pair of ctm's is looking like a good idea though. Here's to the 'learning curve'. The ram assist is from PSC and works pretty freakin good but has had some issue's that I've had to iron out. 1) had to send the pump back due to not providing any real power at idle, they fixed it no charge but never said what was wrong, just returned it. 2) steering box leaks but again they covered it, sent me a new O-ring @ no charge. 3) the reservoir pukes until it's happy with the fluid level, no matter how good you bleed it out but that could be strictly from overfilling, dunno, never got any instructions with the kit. 4) not an issue really but alot of belt tension is needed to stop slippage, having a two belt pulley on there would be nice. (or go serp) Last edited by vtblazer; 09-20-2006 at 06:20 AM. |
09-24-2006, 11:18 PM | #55 |
PROJECT 7DEUCE
Kuet if you get those ctms make sure the axle company you go with will guarantee the axles you buy ..... I have the redneck ram hydro set-up on my yota from west texas off road works great and once all the air was outta the system it worked killer.. Just make sure you run power steering fluid and not atf in the power steering set-up as atf will eat the seals on the ram.. Let us know when you get the parts...
09-25-2006, 05:57 AM | #56 | |
Axles are here, waiting on the spool and clips but should see those this week. The blazer is up @ the shop already and dismantling will begin soon. I seem to have another long list of 'stuff' to get done before heading back down to Rausch Creek in October but nothing real major. Appreciate the input. |
09-29-2006, 10:38 PM | #57 |
PROJECT 7DEUCE
Hey kurt heres a pic of soemthing fun to do in your spare time when the front is locked up!!!
09-30-2006, 06:42 AM | #58 |
Nice!
10-07-2006, 05:52 AM | #59 |
Latest mods are completed.
* Spool * 4340 Axle set * Heavy duty u-joints. (not ctm's or yukon) * New front drive line w/1410 yolk, 1350 CV, 2-1/4" tube and a 12" slip. On a good note, when thing's were apart I found that the wheel bearing's on the drivers side were smoked... Last edited by vtblazer; 10-07-2006 at 05:54 AM. |
10-07-2006, 07:15 AM | #60 |
PROJECT 7DEUCE
New parts always rock kurt btw I got your pm last week just been busy ill shoot ya one back today...
10-07-2006, 03:09 PM | #61 |
10-08-2006, 11:17 AM | #62 |
PROJECT 7DEUCE
Hery kurt just to fuel the fire for ya!!!
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 10-08-2006 at 11:21 AM. |
06-13-2007, 07:18 AM | #63 |
Yet more updates...
(nice pics French) * TBI'd 383 stroker motor * Fuel cell w/internal pump * Serp set up Entirely different truck to wheel now with the injected motor! If your serious about wheeling hard, go injected or go home. So Frenchblue...think it's there yet? |
06-13-2007, 06:47 PM | #64 |
PROJECT 7DEUCE
Hell ya kurt its there.... I have not touched mine been reliving my child hood by getting all the $$$ toys I wanted as a kid......nitro car slot cars and now I m working on a train set to go around my shop....
06-13-2007, 07:10 PM | #65 |
The LuvShack Garage
Sweeeeeeeeet Pic Kurt
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-14-2007, 02:00 PM | #66 |
This was our mud/trail truck a few years ago. Moved the battery from under the hood into the bed behind the sidepanels w/ an access door. Then put remote battery terminals in the fuel fill door. This was very handy for quickly jumping off our buddies that kept wheeling with with dead batteries & alternators.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
07-07-2007, 01:21 AM | #67 |
Very interesting thread vt, anything new on this project? Of course I'd be interested in that family "cage" your working on! Thank's man, keep on wheelin!
07-07-2007, 04:56 AM | #68 | |
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
07-07-2007, 07:38 AM | #69 | |
Built some new rock sliders. Kind of a minor boat side really. Other changes are loosing the soft top and tail gate. Whatda' guys think? Loose the quarters and go tube in the rear? It's close already with the family cage. I could take off the quarters , remount my fuel fill, trim up the floor and be done. Pics of the rocksliders. Used up just over 20ft of 1.75x.094 DOM tubing to build em. Cut a up 5.5"s of junk metal to make room to fit them. (rusty/no good stuff) And the latest little secret is...going to 42's. |
07-07-2007, 07:48 AM | #70 |
The LuvShack Garage
"Luvs in Norwood, MO"
Leave the rears so it will still look like a BLAZER
07-07-2007, 08:43 AM | #71 |
Looks good, are you done YET, or more mods. Still up in the air on the rear quarters idea. J.
07-11-2007, 01:01 PM | #72 |
Sofa King. We, Todd, Ed.
Done yet? I dont think a serious-use 4x4 is ever done.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
07-11-2007, 01:08 PM | #73 |
07-11-2007, 01:18 PM | #74 |
Lookin good VT, Those rock sliders are pretty stout looking. When are you going to 4 link it and put coil overs on it? Can you get a picture of how you attached the roll cage to your frame behind the front seats? I see in the one pic how you did it at the front but can not tell at the back. Keep up the good work you have come up with some good solutions.
72 Blazer CST 383 stroker roller, fuel inj, t350,NP205, D60 front, 14b rear, detroit locker, 38 x15.50 mtz's, welds, cross over steering, custom cage,Line X Spray in liner, House of Colors Tangelo Pearl Orange |
07-11-2007, 01:19 PM | #75 |
Tell me about it. I'm waiting for the weather to cool off so I can start my "brakes" project. Its supposed to be 103 for the next 3 damn days. Not to mention, wheelin' in any kind of heat sucks....I guess I'm already starting to look forward to fall....
