Old 12-01-2006, 05:48 PM   #51
Jebb1978
Jebb1978's Avatar
Re: New project & forum jumper
Wow! That truck is gonna be wild!
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 12-01-2006, 06:48 PM   #52
Kabwe
Certified Car Nut
Kabwe's Avatar
great work man, I have the same engine you have. what trans are you running? 4l60E?
Kabwe is offline   Reply With Quote
Old 12-01-2006, 08:53 PM   #53
solidaxel
solidaxel's Avatar
I took the chassis to the exhaust shop last week. I will add some pics of the exhaust if these come out ok.[/QUOTE]
I am looking at the new Vortec also for my 53 project, are you using stock (what year&type) manifolds? Where are you running your wirng harness from the engine to computer
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-02-2006, 06:40 AM   #54
Hart_Rod
Hart_Rod's Avatar
Truck's looking good!
Hart_Rod is offline   Reply With Quote
Old 12-03-2006, 01:44 PM   #55
Kid
Kid's Avatar
been out of town for a while. Thanks for the comments
I will try to answer questions.
I hope to lay the running boards, but I don't have the tires bought yet, the back end of running boards won't touch the ground, but thr fwd end should.
I am running the 4L60E trans.
I found some 98 camaro exhaust manifolds that tuck real close to the motor, perfect fit. I am also using a new wireing harness from Speartech & rework computer located under the seat in the cab.
I will post some more pics as I start putting back together. I still need to spray on the Lizard skin insulation in the cab before re-assembly.
Kid is offline   Reply With Quote
Old 12-05-2006, 03:29 PM   #56
roj2323
cool build, i look forward to reading your updates.
ondrew
roj2323 is offline   Reply With Quote
Old 12-05-2006, 04:17 PM   #57
Kabwe
Certified Car Nut
Kabwe's Avatar
Hey kid
What year is your engine? Do you have the electronic throttle body (drive by wire) if so are you going to run it or switch it out to a cable driven throttle body? I chose to by a cable driven throttle body and scrap the drive by wire. When I brought my engine I was told it was the 2002 Tahoe Engine but after further investigation I found out it is a 2005 which gave me that drive by wire throttle body.
Old 12-05-2006, 08:13 PM   #58
Kid
Kid's Avatar
Kabwe, the motor is a 2004 out of a GMC Serria. I am using the drive by wire. I was concened that it would have some delay in it, but I have ran it and am very happy with the response it has. I did question this issue when I talked to John at Spertech & he assured me that there would be no "lag" & he was right, throttle response is damn near like a alcohol motor!l
Old 12-05-2006, 08:32 PM   #59
Hart_Rod
Hart_Rod's Avatar
I'm using the drive by wire also. How much was the harness and reprogram? Also, I would like to install cruise control, do you know if they can do that with drive by wire? Thanks,
Rob
Old 12-05-2006, 08:45 PM   #60
Kabwe
Certified Car Nut
Kabwe's Avatar
So I take it you have the electronic gas pedal assembly? Could you take a pic of that when you get a chance so that I can see how its mounted?
thanks
Old 12-05-2006, 08:48 PM   #61
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Kabwe View Post
So I take it you have the electronic gas panel assembly? Could you take a pic of that when you get a chance so that I can see how its mounted?
thanks
Here ya go.
Old 12-05-2006, 09:12 PM   #62
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks Hartrod, I have to look for a padel if I decide to keep the drive by wire, I just brought a cable driven throttle body off ebay for 58 bucks. I have to decide what I'm gonna do since I read you guys are keeping the drive by wire and like it.
Old 12-10-2006, 10:13 AM   #63
Kid
Kid's Avatar
Hart Rod,
John at Speartech charged me about $1150 for the new custom harness made to my specs & reprogramming the computer (included a new wire harness b/t the throttle pedal & box). Alot of money, but very good quality product. Took about 30 minutes to hook up & fired right up with no problems.
I just got back home Friday night & have been applying some "Lizard Skin" to the cab this weekend. I will try to post some pics along with a write up of my opinion of this product later.
Old 12-10-2006, 10:40 AM   #64
Hart_Rod
Hart_Rod's Avatar
Hart Rod,
Kid,
Thanks for the info. I called and spoke to John. I think that is the route I"m going to go. I'll probably have him modify the factory harness since it's only got 10 miles on it. I'm also thinking about buying some programming software and doing the computer myself. Seems like quite a few people are doing these LS1 conversionsm that it might be worth offering the service (cheaper than the $300 though). I've always wanted try it, this might be as good of time as any. BTW, what is lizzar skin?
Rob
Old 12-10-2006, 12:32 PM   #65
solidaxel
solidaxel's Avatar
Before you get too deep into Lizzard Skin take a look at Hy-Tech Thermal Solutions!!
FYI
LS 3 4L70E
Old 12-10-2006, 01:40 PM   #66
Hart_Rod
Hart_Rod's Avatar
Kid, can you post some pictures of your manifolds installed? Do you have the part number? What motor mounts did you use?
Old 12-10-2006, 01:44 PM   #67
Hart_Rod
Hart_Rod's Avatar
I also forgot to mention, John at speartech said that Cruise control was possible with the TBW (throttle by wire) .
Old 12-10-2006, 07:37 PM   #68
Sweet&LowPro55
Sweet&LowPro55's Avatar
Looks like you've got a kool project going !!!
http://i142.photobucket.com/albums/r...MyExtremeD.jpg
~ '55 Chevy Pro-Street P.U. Powered by 396c.i. ~
~ '01 ChevyS10 Extreme LS Ext. cab
~ '92 Camaro RS 25TH.Limited Edition Aniv.Convert.
~ '98 Dodge Ram Van 5.7 Litre
~ '98 E-Z-GO Golf Car ..Tony Stewart Edition
!! '69 Camaro SS..SOLD .. Still crying !!
Sweet&LowPro55 is offline   Reply With Quote
Old 12-10-2006, 10:18 PM   #69
Kid
Kid's Avatar
Well, I got finished this evening with the insulation. After much research, I thought I would try the Lizard Skin product. It will be some time before I will drive this truck to see just how good this stuff works.
I could not find any detailed info on this stuff so i am postig my thoughts of this product to let all deside what route they might want to go.
The product is expensive at approx. $526.00 with spray gun from Summit.
Another disadvantage is the "spray" application does create some overspray, so be sure to cover everything else up well, besides masking the project.
I put 5 coats of the "SC" (sound control) & still had just a little left over.
The "SC" bucket was 170.00.
The other bucket was the insulation & I got 4 coats out of it.
Total thickness after completion of both products was .080"
Bottom line, my opinion is this stuff better work damn good because it took me all weekend to get the job done. Not tomention the mess I have to clean up. I did my 68 with asphalt mastic sheet (dynamat) & 1/2" thick "jute" backing. This process was less than $200.00, took about the same amount of time, & alot less messy.
I will reserve my final opinion till I take the truck for a spin. I will post some pics of the instl.
Old 12-10-2006, 10:28 PM   #70
Kid
Kid's Avatar
this is the "SC" sound control after 5 coats, drying. Need to wait 24 hours before the next step
Old 12-10-2006, 10:34 PM   #71
Kid
Kid's Avatar
some pictures of the interior after insulation is finished, along with a close up of the texture.
Old 12-10-2006, 10:39 PM   #72
Kid
Kid's Avatar
here is a close up showing the thickness from some tape over a fire wall penetration.
total thickness is .080" with what appears to be .040" Sound control & .040" insulation.
Old 12-10-2006, 11:10 PM   #73
Kid
Kid's Avatar
Hart Rod,
I will try to find the part #'s for the manifolds. Here is a pic from behind that shows the manafolds "tucking" in to the motor real well. If you want some pics from other angles, just let me know & I can take some more.
I made the motor mounts cause I was not sure any others would fit where I wanted the motor to sit. I think the ones Street & Performance sells might have worked, but at well over $100.00 I didn't want to take the chace.
I made the pattern from card board, then cut the pieces from 1/4" plate.
They rest on stock 1984 "G" body rubber mounts
Old 12-11-2006, 09:07 AM   #74
Sweet&LowPro55
Lots of good fabricating there.Comming along good.Post lots of picturers!
Old 12-11-2006, 04:15 PM   #75
pgf545
pgf545's Avatar
Kid, How does the Lizard Skin do at covering up imperfections? I was thinking about doing that to my Camaro to cover some of the UGLY that I caused when replacing the floor pans, mostly weld seams. I am going to hit it with seam sealer before I do anything else. I was thinking about only doing the under side because there is going to be carpet on the inside. Let me know what you think.
Thanks,
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
