Old 09-16-2005, 09:20 PM   #51
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
i forgot the pics....i promise to post some on sunday
i have encountered another problem on the blazer, this problem existed before the swap though, i need to install an o2 sensor in the drivers side header...... the old one was a one wire nonheated sensor.....sense the new one will be clear down by the collector (full length headers) it really should be heated.......the question is this....how do i wire up a heated o2 sensor where there was not one to begin with?
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 09-18-2005, 10:22 PM   #52
sixty8c10
sixty8c10's Avatar
here's the pics as promised.....finished cleaning and painting the front end:
assembled and painted the eng:
installed the eng today:
hopefully, with any luck it will be running by thurs, but i have never had any luck.
Old 09-18-2005, 10:45 PM   #53
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
looking awesome man, you are making rapid progress. looks great!
milehightoyz is offline   Reply With Quote
Old 09-18-2005, 10:49 PM   #54
sixty8c10
sixty8c10's Avatar
just wish i could have got mine done as quick as you did milehigh, but i'm getting there.
Old 09-18-2005, 11:01 PM   #55
longhorn71
longhorn71's Avatar
Originally Posted by milehightoyz
any new updates on this project? im looking to do the same thing. ive got a 78 blazer that is super clean but its 4x4 and im allergic to heights so i want to make it 2wd? will a 2wd shortbox frame bolt right under this blazer?
I have a rolling frame if you are intrested for a 2wd blazer(it s an 81)
that blazer and truck look great
longhorn71 is offline   Reply With Quote
Old 09-18-2005, 11:09 PM   #56
sixty8c10
sixty8c10's Avatar
longhorn71-its a little late now, but thanx
Old 09-19-2005, 12:18 AM   #57
milehightoyz
mines still far from done. dont feel so bad, i do this stuff all day long. i admire your work ethic. keep the pics coming its looking awesome!!
Old 09-20-2005, 10:46 PM   #58
sixty8c10
sixty8c10's Avatar
sorry its been so long since i posted......last pic showed the eng sitting in the frame rails on the blazer.........i have been working rerouting the wires, and wiring up the o2 sensor........any way i am getting closer thurs when i get off i will finally be stabbing the distributer, mounting the throttle body, and radiator.......crossing my fingers and turning the key
Old 09-21-2005, 01:54 AM   #59
bbchevy
87 Wanna Be K30
bbchevy's Avatar
just a question... was the truck an automatic? if so, is the transmission tunnel going to be the right hight? i thought the 2wd auto cabs had a different tunnel... maybe im wrong
bbchevy is offline   Reply With Quote
Old 09-21-2005, 11:03 AM   #60
sixty8c10
sixty8c10's Avatar
yes it was an automatic, and the tunnel is not goin to matter as plans include a body lift.
Old 09-27-2005, 11:47 AM   #61
sixty8c10
sixty8c10's Avatar
hey everybody, cross your fingers, and tell rita thank you.......a tree has fallen on the pick-up....i have taken pics but cannot post them while at work.....and there is no power at my house.....it looks like it may be okay, but.... you really can't tell til you get you the tree off........secondly, a tree also fell on the pick-up's front clip.
Old 09-27-2005, 09:41 PM   #62
KShortell
KShortell's Avatar
Gee, man. That sucks.
I will say that all that effort you've put out is making me feel better about obsessing about a small amount of rust on the inside bottom lip of my rear doors. If you can do all that work in your spare time, I'll surely be able to getting around to fixing mine up.
Of course, I need to finish unpacking here at the new house first!
Stay safe and Godspeed to you and your family.
-Kevin
Semper Paratus
KShortell is offline   Reply With Quote
Old 10-03-2005, 12:38 PM   #63
sixty8c10
sixty8c10's Avatar
got power at the house finally....still no cable, therefore no internet, which means no pics yet....the pick-up only ended up with a cracked windshield and a bent steering column.....front clip damage is not to bad at all, got a crease in the front of the pass fender, bent on driver's rear, and the grille is cracked.......finally got the blazer running...and the saga continues.....as i said i got the blazer running(thurs evening)....topped of the trans, the radiator, and adjusted the timing....assembled and installed the front clip (fri afternoon), started it up to pull it out of the car port so i could wash it prior to going to the exhaust shop, put it in reverse; felt it shift into gear, then it died.....i have not been able to get it started since...the worst part is cannot find anything wrong with it.....i got spark (weak), fuel, and air...it was timed perfect, everthing still set where i marked it......all my diagnotstics have led to coil failure....anyone have any other ideas?
Old 10-08-2005, 05:10 PM   #64
sixty8c10
sixty8c10's Avatar
finally got my internet here's the pics from the windstorm (rita):
hidden in there somewhere is the p/u
another
blazer seemed unharmed
Old 10-08-2005, 05:16 PM   #65
sixty8c10
sixty8c10's Avatar
i replaced the coil on the blazer, got a better spark, but it still wouldn't start...looked as though it was flooding itself out....i ended up calling the shop to come and get it so they could hook it up to their diagnostic machine.
Old 10-08-2005, 10:44 PM   #66
Jebb1978
Jebb1978's Avatar
Don't get down man! I am not planning on doing anything as ambitious as this but I keep tuning in like damb a Soap Opera! You are my idol! It will run!!!! It Will!
Jebb1978 is offline   Reply With Quote
Old 10-09-2005, 09:47 AM   #67
koreric75
83C10SWB
koreric75's Avatar
that's awesome 68c10, looks like alot of work. it's taking me a whole weekend just to swap the front driver side fender out, i removed the wheel well and cleaned it up too.
Koreric75
2003 Suburban Z-71 4x4
5.3L
83 C10 SWB FOR SALE
350ci/700Raptor Jr
Picture&Progress Page
koreric75 is offline   Reply With Quote
Old 10-09-2005, 03:02 PM   #68
chevrunner21
thanks for the link to your project and it gave me a good idea and project of my own you helped me out alot and good luck with all your progress.
chevrunner21 is offline   Reply With Quote
Old 10-10-2005, 11:42 PM   #69
72CSTC5
72CSTC5's Avatar
Keep us updated not that I have read this entire thread. Good luck man.
72CSTC5 is offline   Reply With Quote
Old 10-12-2005, 10:50 PM   #70
bcauto
bcauto's Avatar
I hope that you can get it running, i plan to see it sometime...
bcauto is offline   Reply With Quote
Old 10-12-2005, 10:53 PM   #71
sixty8c10
sixty8c10's Avatar
welcome to the board...bcauto....believe me once i get that blazer going there are gonna be a few changes happening around here
Old 10-13-2005, 12:57 PM   #72
JustOneTruck
JustOneTruck's Avatar
Hey I gota say my hats off to you. I think your doing a great job working on the truck and showing us the photos. Thanks for keeping my days going through your posts . I feel like a kid standing at the fence where the construction site is full of heavy quipment roaring and moving dirt and all.
Hope your time frame permits a few long rides before your Jan 6 .
JustOneTruck is offline   Reply With Quote
Old 10-13-2005, 10:51 PM   #73
sixty8c10
sixty8c10's Avatar
i'm starting to get a little worried...the shop still has the blazer....its been a week and a half......i don't want to move foward on the pick-up til i get the blazer back......fear the bill from the shop may kill that build altogether
Old 10-13-2005, 11:34 PM   #74
Jebb1978
Jebb1978's Avatar
Have you gotten any sort of up date from them? I am going to guess that it is not a simple problem or you would have found it (based on the past 60 something posts it would appear that your not new at this). Do they have any idea what is going on?
Old 10-15-2005, 12:30 PM   #75
sixty8c10
sixty8c10's Avatar
only thing i have heard from the shop is that they have finally started to work on it.....due to the hurricane they have a back log, as most shops around here do, because they lost electricity for an extended period.....i know its not a simple problem, if it was i would be driving it now......i went through all the diagnostics i could with the means i have available to me, fixed the few problems i found to no avail....hopefully i will get an update from them early next week.... i just wish they would hurry up, my current dd needs brakes.
