Old 09-21-2005, 11:42 PM   #51
shifty
Questionable
shifty's Avatar
Originally Posted by 69 longhorn
2nd that.....I unclip the harness,& pull 2 pins, then it takes 2 stout, or 3 old guys to lift that (3/4 of that) front clip off!
Here's my next question: What's the easiest way to get this bastard back on without denting and scraping everything up? Should I take the tires off and put it on jackstands? Should I pull the steering column?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-22-2005, 08:53 AM   #52
69 longhorn
Yes, i would remove the front tires & the lower shaft(leave the column in place tho). if you enlist a few stout guys, it shouldnt be too bad. you might also remove the hood (if you havent already). it looks like a cool project....best of luck,69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 09-22-2005, 10:12 AM   #53
CPNE
Resident Curmudgeon
CPNE's Avatar
Except it's a 68, no detachable lower shaft!
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-22-2005, 10:41 AM   #54
shifty
Questionable
shifty's Avatar
What he said ^^^
That's why I'm saying I would remove the whole shaft.
Maybe if i bust out the rivet in the middle of the shaft (gotta do it anyways to re-fit the new power steering box) I can shrink it down (telescope it?) and slide in?
Open to suggestions if anyone has one. I'm realizing what a pain in the ass it will be to get back in now
heh
Old 09-22-2005, 10:57 AM   #55
CPNE
Resident Curmudgeon
CPNE's Avatar
No you don't. The stock truck PS unit is the same length as the manual unit. Trust me on this
Not sure if you've seen any of my trucks, but I don't worry about paint. However since you do, why not:
1. detach the column shaft from the steering box at the rag joint
2. free up column on inside of cab so that the wheel can be lowered to the seat. This involves a few brackets on each side of the firewall.
This should allow enough freedom of movement to swing the steering column shaft towards the engine and gain the needed clearance WITHOUT removing the column altogether.
Old 09-22-2005, 11:41 AM   #56
shifty
Questionable
shifty's Avatar
No questions.
I'd like to push my column in towards the dash so it's not sitting so far out. Should I bustthe rivet out and readjust anyway? Is there any re-welding of tabs involved to do this? It's a 3-on-tree column. Just curious.
Thanks for the pointers.
Old 09-22-2005, 04:12 PM   #57
69 longhorn
Oops, my bad! I wasnt paying attention to the yr! I think I would be tempted to drop the inner fender on the D side to help with reassembly. 69L
