Old 09-21-2006, 11:43 AM   #51
abadsvt
abadsvt's Avatar
Re: [PROJECT] FnLow 69
I am getting ready to build my frame and i had a couple questions. Why did you notch the front of the frame? I am talking about the radiator support mounts. Do you think you will have much of a bed floor when you put the bed back on? How much do you think you have to raise the floor up? Well thanks for the help!!!! JOSH
abadsvt is offline   Reply With Quote
Old 09-21-2006, 10:54 PM   #52
FnLow69
FnLow69's Avatar
I dropped the frame horns because I Z'd the frame.
How much bed will I have- not sure probly allittle more than half a stock bed depth. not sure on how much i will have to raise the floor i have to get a bed first.
Are you backhalfing the frame or are you doing a full frame build.
FnLow69 is offline   Reply With Quote
Old 09-22-2006, 12:25 AM   #53
abadsvt
abadsvt's Avatar
I am completely building the frame out of 2x6 and 2x4 tube steel. I have been trying to do my homework like crazy before i start but i already have the truck to a rollin chassis and i want to start building the frame. I am going to be using the stock chassis for measurments and a reference guide. I thought about just modifing the rear but i like to go all out when i do things. I don't understand what you said about dropping the horns cause you Z'd the frame. Maybe i don't understand what Z'd means. I have the back half all figured out but still working it out in my head about the front and the front crossmember. Can you please explain a little more about the benifits to Z'ing the frame upfront. Thanks Josh
Old 09-22-2006, 12:47 AM   #54
FnLow69
FnLow69's Avatar
well if your building a full frame you dont have to drop the frame horn, you just have to make sue that the fenders line up with the cab.
In a nut shell Z'ing the frame raises the crossmember and makes the frame the lowest part of the suspension. because the control arms hit the ground first on our trucks. the reason you drop the horns is so that everything lines up again. If there any thing i can help you with PM me and ill help you if i can.
justin
Old 09-22-2006, 10:44 AM   #55
big dump
big dump's Avatar
Your truck is looking great. Couple of questions, first, are you using the stock a arms in the front? What kind of bags are you using? Did you buy all the components separately or go with like the air ride kit? Keep up the good work.
big dump is offline   Reply With Quote
Old 09-22-2006, 11:27 AM   #56
abadsvt
abadsvt's Avatar
I think i finally understand how Z'ing works. Since you bodydropped the cab you have to do the same amount to the front mounts so like you said the front fenders stay inline with the cab. Finally that makes sence . I do have another question. How do you body drop the cab? Do you alter the mounts for the cab? You know like moving them down a few inches. Would the frame hit the cab?
I was debating on using all 2x4 tube steel for the frame or using 2x5 for the main channels and then using 2x4 for the front and rear sections of the frame. What do you think? Thanks for helping me out! Josh
Old 09-24-2006, 07:04 PM   #57
FnLow69
FnLow69's Avatar
no i running Air ride tech A-arms. Right now i have airlift bags, soon ill have slams. i bought the 3/8 starter kit form suicidedoors and made the link bars
thanks
Old 09-24-2006, 07:08 PM   #58
FnLow69
FnLow69's Avatar
As for as the dropping the cab i lowered the mounts on the frame 1". nothing hit exept for the firewall to floor seam, i just notched that.
As for the frame i would use 2x4x3/16" for the whole frame, that way theres room under the cab and frame andyou wont have to notch the seam.
Old 09-24-2006, 07:16 PM   #59
LowRodder
LowRodder's Avatar
Thumbs up Re: [PROJECT] FnLow 69
looks like one Bad A## project keep it up and keep the pics comeing
LowRodder is offline   Reply With Quote
Old 09-28-2006, 09:22 AM   #60
tofnlows10
looks good!
tofnlows10 is offline   Reply With Quote
Old 09-28-2006, 10:01 AM   #61
mrenj23
mrenj23's Avatar
Really nice work. I plan on doing all the same things (the Z and tunnel) to my 86 in the next couple of weeks. It'll be my first try on these kind of modifications myself.
mrenj23 is offline   Reply With Quote
Old 10-10-2006, 11:38 PM   #62
FnLow69
FnLow69's Avatar
UPDATE!!! 10/10/06
got both tanks and compressors mounted...
got the fuel cell mount finished and the rear air bag valves mocked up...
then pushed it out side for more pictures....
AND the modivation to keep going...
so what do you all think?
Old 10-11-2006, 12:06 AM   #63
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
bad ass man. Nice clean setup.
IvelDesigns is offline   Reply With Quote
Old 10-11-2006, 12:43 AM   #64
layedoutnoma
layedoutnoma's Avatar
very impressed... clean setup
Meticulous Fabrications
Milford Michigan
layedoutnoma is offline   Reply With Quote
Old 10-11-2006, 01:44 AM   #65
abadsvt
abadsvt's Avatar
WOW! It has been a while since i checked out your thread. Your doing great!!! I like where you put the compressors! I haven't seen that done yet. What gas tank did you go with? When do you think you might put the bed on? I am in the process of building my frame and can really appreciate all the hard work that went into that back half. Keep up the good work and also keep posting pics
Old 10-11-2006, 01:48 AM   #66
70-c10LWB
beautiful build man. i live in port orchard and would love to see it in person someday. anyways. awesome job
70-c10LWB is offline   Reply With Quote
Old 10-11-2006, 02:02 AM   #67
thekid54
Lookin' good man! Where are you planning to mount the rear shocks?
thekid54 is offline   Reply With Quote
Old 10-11-2006, 10:35 AM   #68
FnLow69
FnLow69's Avatar
thanks josh I hope to get my bed on mondayso more progress soon. also seen your build thread look very nice.
70-c10LWB- plan is to have it driving by Goodguys this summer
thekid54- im working in the shock location now i just need the get the shocks
Old 10-11-2006, 10:42 AM   #69
EZ4U2C
EZ4U2C's Avatar
That truck is going to ROCK.
God loved me so much he gave me John 3:16
Buy American and bring our jobs back home.
Trust what you believe in and believe in what you trust.
Don't blame the gun, Blame the person who made you use it!
1970 swb
2002 Harley Davidson Road King Classic
2004 Dodge 4x4
EZ4U2C is offline   Reply With Quote
Old 10-11-2006, 11:55 AM   #70
jimmydean
jimmydean's Avatar
That truck is the sweetness! I need a shop, damnit!
I can't wait to see it finished. Where are you in Washington? I want to see it when it's done for sure!
jimmydean is offline   Reply With Quote
Old 10-11-2006, 03:50 PM   #71
kylejamers
sweet
kylejamers is offline   Reply With Quote
Old 10-11-2006, 07:08 PM   #72
el curioso
el curioso's Avatar
veeeeeryy nice.
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 10-11-2006, 10:26 PM   #73
FnLow69
FnLow69's Avatar
Im in Gig harbor, just east of tacoma. It will be at Goodguy in puyallup this summer
Old 10-11-2006, 11:01 PM   #74
67chevy2wd
67chevy2wd's Avatar
Looks like you have put some hard work into it and it is starting to show, keep it up. BTW it look awesome.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 10-12-2006, 10:23 AM   #75
randomhero472
randomhero472's Avatar
looks great, what fuel cell did you use?
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
