Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-25-2008, 04:17 AM   #51
PA-IndianRider
PA-IndianRider's Avatar
Re: Slow And Low So Goes The Tempo!!!
WoW.... nice picture story..... especially NICE WORK ..... As I have said "over & over" it seems like I am never going to get to the point you're at. What makes things even worse is that I have parts/stuff collected for practically "every part" of our build. I just have to get the "time" (and some more bucks) to get things started.
My back (both upper & lower) and the daily driver ('80 El Camino) I just picked up is causing me lots of "physical" & "wallet" pain.... HA!!!
Hopefully before the weather gets bad I'll have the cab & bed off & begin work on the frame..... pictures to follow.....someday!!!
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 09-27-2008, 03:25 AM   #52
hotrod 80
mini truck racer
hotrod 80's Avatar
Lovin the anti-roll and a bump for progress pics . I also went with the Cola crank , but went 3.85 and lentz billets with JE's . I think my crank is set up for 1800 bob weight and pistons and rods ended up like 1755 or something . Yours should have great throttle responce . Once you get it lined out a safe 150 shot wouldn't even hurt that motor . it would take that for decades . Keep us posted .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-18-2008, 03:19 PM   #53
custom72c20
custom72c20's Avatar
Originally Posted by 57sailplane View Post
i have not had the motor dynod yet.. the parts are as follows.
demon 825 drag carb
2" 4-hole ported carb spacer
performance plus huricane intake
the 350 block is the high nickel 2 bolt drilled and asembled with splayed main caps. large water jacket holes pluged and drilled with 1/4 inch holes. water jakets have been rock blocked to freeze plugs.. decked, bored , magenifluxed and hot tanked..
heads are reher morison cnc ported and polished including chambers dart pro 1's. finished with hd milodon intake and exhaust valves toped with titainium locks and keepers. 1.6 to 1 comp pro magnum rockers. comp roller 635 lift 292 duration cam with corisponding valve springs for 1.6 to 1 rockers.
bottom end starts with all usa cola lightweigt 3.75 strocker crank. bought before they were bought out..
oliver billet rods with the 1500 hp rod bolts.. and ross custom pistons
compression should be right at 10.1 to 1
hp i hope will be in the 500 hp range with around the same amount of torque.
i built this thing with a lot of noss in mind. the weak link is the block. eventhough its been beefed up i dont think it will handle much more than 850hp...
i plan on running it on just the motor for the first year with maybe a 300 shot of nos the secound.. then i will probably step up to a dart block and turbos
i am taking it slow with the motor as i really dont want to blow it to kingdom come off the get go...
oh ya the primer is nasson 2k high build sanding primer... with there etching epoxy underneath...
Thanks for the info. I was going to build a 422 c.i. small block similar to yours but got a good deal on a big block. Good luck with the build.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
Old 11-30-2008, 09:19 PM   #54
57sailplane
57sailplane's Avatar
not showing off but i have a friend that could not find it so bringing to the top. thanks guys
57sailplane is offline   Reply With Quote
Old 11-30-2008, 10:48 PM   #55
71Dragtruck
71Dragtruck's Avatar
Go ahead show it off that's what this place is for.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 12-01-2008, 08:34 AM   #56
djracer
djracer's Avatar
Any new progress.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-07-2010, 05:29 PM   #57
noonzor
subscribed!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 02-10-2010, 12:43 PM   #58
AKoldstyle
AKoldstyle's Avatar
I like the build it has some of the same mods done 2 the dash as mine,except that my dash pad is shaved off and the radio is gone. I went the 598 bbc route. I was able to keep the stock frame,as my rear is still in the air. Nice work !!!!!!!!!!!!!
AKoldstyle is offline   Reply With Quote
Old 02-10-2010, 04:25 PM   #59
BossHogg69
motor exploder
BossHogg69's Avatar
thank you for bringing it up to the top, otherwise I'd have never seen it! Very cool build and nice craftsmanship!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-10-2010, 12:30 PM   #60
57sailplane
well guys,
i have set aside the project for a while. the body work needs done and so forth. the thing is is my wife is going to college and it has been very costly and times being tuff i thought it was in our best interest just to let her set. of course i will never sell here. she has been siting as i last worked on her and has not hurt a single thing other then i really want to drive her. so it may be another year before i get to her. i hope. the boy starts college this coming fall. but my wife should be done and i hope our income will be good enough to support one of my habbits..
anyways she the project named amy after my old pit bull will be done someday, just got to have patients..
later andrew K
Old 03-10-2010, 03:16 PM   #61
wheatlandbrawler
wheatlandbrawler's Avatar
ill wait for a decade to see this thing get finished, a true testament to what guys can do in their back yards..... amazing build!
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
wheatlandbrawler is offline   Reply With Quote
Old 03-11-2010, 06:06 PM   #62
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Yeah very cool build.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 07-31-2014, 07:30 PM   #63
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Just stumbled on to your build...
I dig it... A lot!
Nice work on the cage, and all the rear end fab work.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-31-2014, 07:33 PM   #64
57sailplane
ahh,
man,
its been a while since i posted on this thread. man i need to get back on this thing.
Old 07-31-2014, 07:40 PM   #65
GASoline71
GASoline71's Avatar
I hear ya.
I wrecked my truck back in March, and still haven't found the time to get after it. I have another frame to replace the bent one that has been reapinted and everything. Just need to start swapping parts.
Gary
