Old 08-17-2007, 02:30 PM   #51
vtblazer
vtblazer's Avatar
Re: Off-road Carnage
Good idea.
It fits in really well for me cause all the cordless tools I have for my business are Milwaukee. < correct spelling btw.
Meaning lots of batteries around.
One other note though is that the case it comes with is designed to carry three batteries inside it, I've never gone through em all in a weekend yet.
vtblazer is offline   Reply With Quote
Old 08-17-2007, 02:46 PM   #52
Burt4x4
Burt4x4's Avatar
hahah Thanks for the correct spelling, I have never been a good speeler hehe
Sounds nice with the case and batts!
"oh Honey, I know what you can get me for my B-day comming up! "
heheheee
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-17-2007, 03:27 PM   #53
Southedisto
River life......
Southedisto's Avatar
This pales in comparison to you guys, but this is it for me. Just started up slickrock in Tellico, on or two tries and it sounded like the clutch was coming apart. Fortunately, the sheetmetal dust shield somehow became pinched and bound up into the flywheel. I am guessing that the two tq mount bolts stripped out about the same time, because they were missing the next morning.
Southedisto is offline   Reply With Quote
Old 08-17-2007, 03:33 PM   #54
vtblazer
vtblazer's Avatar
trail repair is trail repair
Nice pic, love the jimmy!
Old 08-23-2007, 07:06 PM   #55
Zoomad75
K5Camper
Zoomad75's Avatar
I've been busy lately so I didn't get these up as soon as I would have liked:
This is my 12 bolt cover that got peeled back on a rock on our last trail ride. Just took a little blacksmithing with my BFH and a block of wood to flatten out. The Blue RTV really saved my bacon as the bottom of the cover was peeled out a good 3/4" from the housing. The RTV held the fluid in for the most part, just a minor drip every now and then.
Now I look at it in the driveway and it's leaking again! I either didn't get the bolts tight or the cover isnt as flat as I thought it was.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 08-23-2007, 09:24 PM   #56
hgs_notes
GEARHEAD
hgs_notes's Avatar
Chances are the cover is ok, but if there was any oil residue left on, it's just seeping through a bit.
hgs_notes is offline   Reply With Quote
Old 10-14-2007, 01:02 AM   #57
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Here is a little carnage from a buddies Toyota at the mud pit today.
By the way that was an NP208. Guess it is time to upgrade now.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 10-15-2007, 09:48 AM   #58
Burt4x4
Burt4x4's Avatar
Holyhell..looks like the damn thing fell out
Old 10-15-2007, 10:38 AM   #59
EFI70Blazer
Active Member
Yep, pretty much just scattered it. Everything else in the truck is upgraded except for this item. Has 1 ton chevy running gear, 350 with a TH350, and an NP208. He heard it starting to break, but just went ahead and ran it till he had nothing which lead to this situation he has now. He has a TH400 with an NP205 ready to go in it as soon as he finds the time to do it.
Mike T.
Oregon
70 GMC Jimmy 4x4
Old 10-15-2007, 12:24 PM   #60
Elwayno
I broke a lug off in Pismo the other day. Doesn't sound to bad but I noticed it on the highway. That one broke cuz it was the only one still tight. The rim was hammering back and forth on the other 5. Now the lug holes are a little dished. Needs two washers to hold it tight. Not sure if I can weld it up and remachine it. Anyone have some 6 lug Kelsey hayes/turbo style mag wheels in 15x10?
Elwayno is offline   Reply With Quote
Old 10-20-2007, 01:54 AM   #61
mudmizer
mudmizer's Avatar
No pics, but about 20 years ago I was running about 60 down a two lane road when the front end started shakin like mad. I pulled over to the side of the road, on a bad slope. I looked at the right front tire and all the stud bolts had broken off. The 40" tire some how stayed on the hub, just wobbled around but never slipped off the 6"s or so of the hub. I selpt in the truck and the next morning I stuffed logs under the front end (no Jack) and dug out the dirt under the tires. All I had was a lug wrench and a fencing tool. Took 3 studs and lugs from the left side and put them in the right. Dug out the log and eased 40 miles to home.
Another time I was working on the steering wheel and decided I need a part from the parts store so I stuck the wheel back on the spline (no nut) and headed to town. Well the shaft slid down a bit while I was on the interstate and came out of the steering wheel. OOPS!! Sooo... I eased on the brakes and luckely it went off to the right, away from traffic, into a shallow ditch.
Talk about the "nut behind the wheel" being the problem. Some how I'v managed to survive almost 50 years, couse there are a whole lot more stories like these.
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 02-11-2008, 10:01 PM   #62
vtblazer
vtblazer's Avatar
Hopefully with spring coming alone this thread will come back to life.
Not really a carnage pic but it'll work for a bump.
Last pic is just after the 'bent bumper' thang happened.
Old 02-11-2008, 10:47 PM   #63
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Kurt, That last shot is Killer
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-11-2008, 11:09 PM   #64
vtblazer
vtblazer's Avatar
Being the that I am, here's 'nother pic, different angle.
Old 02-11-2008, 11:14 PM   #65
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Old 03-03-2009, 02:51 PM   #66
vtblazer
vtblazer's Avatar
More rip-n-tear.
Old 03-03-2009, 08:49 PM   #67
Senator350
Senator350's Avatar
Originally Posted by vtblazer View Post
SUCCESS! Extreme Axle Sales sold me a used one for only $80 bucks!
Went from screwed to wheeling again in just over 2 hours.
It's true... Doug is a swell guy. Even met me on a saturday once.
Guys garage is like D60 playground!
OKOK... I can match your broken knuckle, and Seeing as it's only a D44, I'll also throw in a broken pair of U-bolts, and a dented cab.
Coming down a steep grade going a wee tad too fast... Ground was a bit of mush from some really recent rain, but that just makes everything more fun in my book. So, I was practically taking a right turn going down hill, and the right shoulder gave, and sent me spilling down the embankment. The only thing to stop my descent was a giant ROCK which my right front wheel hit directly. Bonk. Head off the cab, kinda BONK. Broken in the woods with my axle pushed back about 10" and a 35" flat
As for the best carnage... I have to say that it's an accumulated 7 junkyard mirrors ripped off the sides of my old '91 XJ. A cute little water crossing, then zig-zag up a near verticle hill in between trees (the trees always took a mirror or two)... It was all to get to this field which was practically made for BAJA style racing around the edge. Ahh those were the days...
I ought to get around to the starter and the PS pump on that old XJ...
RN U OVR
Senator350 is offline   Reply With Quote
Old 03-03-2009, 11:12 PM   #68
thirdstreettito
Resident of Here
thirdstreettito's Avatar
My 1/2" drive sockets were barricaded on the barn, so I figured my weight on my 3/8" socket wrench would be tight enough for the lug nuts...wrong. I was doing 80 and the front left wheel felt wobbly, so I turned onto my exit and all of a sudden had to pull over quickly. I got out, THANK GOD for the hub length! It kept my wheel on, all my lug nuts fell off of that wheel. Needless to say, my truck has been on stands for 4 weeks because we cant get one simple ring out of the hub to be able to replace the stripped studs!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-04-2009, 12:30 AM   #69
Blue_71
Bloo
Blue_71's Avatar
I dont have any pics at the moment, but on the K20s first trip out, i had a screw come loose out of the throttle body and go on top of the #6 piston. it managed to ruin the piston, and beat a hole in the head
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
