Old 02-12-2008, 02:57 AM   #51
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: project (sweet pea)
well a few updates.all the suspension is done.(just need brake lines). new u bolts installed,sway bar repainted and installed (new mounts and energy suspension bushings)...got the trans all scuffed and shot black and cleared ( it came silver) ...and i got all the parts i have been waiting to get....(Richard H) made a order and let me join in.(thanks Dude)...im thinking we saved alot on shipping... So for the most part i just got to get out there and get this thing done....i tell you if it really burns my arse...when i finally got everything i need...and its so frikin cold i cant do anything about it....its 8 degrees outside...there is no way im going to attempt to get the garage to a comfy level..................oh well there is allways next weekend...................Name:  sway bar close.jpg
Name:  trans cleared.JPG
Name:  all cab floor parts.JPG
Name:  cab parts.JPG
bad6772 is offline   Reply With Quote
Old 02-12-2008, 03:02 AM   #52
bad6772
bad6772's Avatar
few more............
Name:  door psngr.JPG
Old 02-12-2008, 03:23 AM   #53
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweeet !!!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-15-2008, 11:15 AM   #54
Richard H.
Spanked once
Richard H.'s Avatar
You may want to check into getting a "Pro" to help you with all them new parts you got there Butter Bean....
Richard H. is offline   Reply With Quote
Old 02-15-2008, 11:46 AM   #55
bad6772
bad6772's Avatar
LOL Thanks Richard H. Do you know where i might find one...? i am going to go get some steel and make a cab stand .....hopefully soon.............
Old 02-26-2008, 06:06 AM   #56
bad6772
bad6772's Avatar
Well some progress is better than none...i got my castors on today and welded a few support brackets...i think i am going to add some more....but its really strong at this point...it held me (6/2..280) plus the cab...felt very solid inside the cab no movement and i felt no flexing....it is a little taller than i had wanted...about 4 inches to be exact....(the height of the castors) but i think it will save my back....and when i get to the roof...i think i will cut a little out of it....Hopefully this weather will stay like this...so i am not just limited to wroking on this thing on the weekends...it does not make much sence to me to fire up the heaters with propane being so high....i did have the garage a toasty 60 degrees...with moving around and welding it was plenty hot...Anyways here are a few pics.........Name:  cab 1.jpg
Edit....putting the cab on the stand alone....was a major pain in the butt....i dont recommend doing it alone......even with mt cherry picker as my muscle...it sucked........
Old 02-26-2008, 06:07 AM   #57
bad6772
bad6772's Avatar
some cab stand pics..........Name:  stand 1.jpg
Old 03-03-2008, 03:30 AM   #58
bad6772
bad6772's Avatar
well few updates....got my hinges rebuilt today (both sides) and started to hang the doors to get some kind of fitment before i tackle the floor issues....they are going to need some tweaking for shure....more on the upper areas of the door than anything...i got things as close as i could with out breaking out the reamer bits....although they will be broke out i am shure...after an hour of trying to align the driver side upper..drilling out spot welds and moving the door posts i came to the conclusion it is going to need alot of work..so i decided i am going to try to use my originals instead...after i got it out completely and matched it ip to the original it will require alot of tweaking...i know my originals fit ..so im going to add the old with the new...( at least its not rust )...the passenger side is not as bad as the drivers side...but we will see once i get over there....i did hang the front fenders some what to get a idea of whats to come....they will also need some attention but thats to be expected...anyways..here are a few pics....i will be at it early in the morn and give it another 4/5 hours.....thanks for the compliments and encouragements ...
tonyAttachment 340982
Name:  lt 2 u r.jpg
Name:  lt u f.JPG
Size:  109.5 KBName:  lt 1.jpg
Name:  lt 2 u r.jpg
Name:  lt u f.JPG
Old 03-03-2008, 03:31 AM   #59
bad6772
bad6772's Avatar
more pics.....Name:  rt 1.jpg
Name:  rt door o.JPG
Old 03-04-2008, 06:29 AM   #60
bad6772
bad6772's Avatar
little time to spend on the truck today...( wifes B-day 26 ) But i was at it early bout 7 till 10....got the original upper door frame cut out and a rough fit...alot better fit than the Tri Plus doors by far....i wont do anything final to them till its time to shave the drip rails...but i wanted to get a good idea of how things would fit before i start on this side of the floor repair stuff i have and the rocker s...also got the dash cut and ready to smooth everything out.... well here are a few pictures.........of the little but some progress..........Name:  Left side 1.JPG
Name:  Left side 2.JPG
Name:  Left side 3.JPG
Old 03-04-2008, 06:30 AM   #61
bad6772
bad6772's Avatar
more Name:  Dash.3.jpg
Name:  new metal.JPG
Old 03-04-2008, 06:59 AM   #62
BurnoutNova
BurnoutNova's Avatar
what are you planning on doing with the dash?
BurnoutNova is offline   Reply With Quote
Old 03-04-2008, 07:01 AM   #63
bad6772
bad6772's Avatar
something to this aspect...,maybe a little different....but more the same.....Name:  redtruckpismo4.jpg
Old 03-09-2008, 07:31 PM   #64
bad6772
bad6772's Avatar
No updates today...this is usally my day for working on the truck...but i am on snow detail......Hopefully i will have some time to get out there tomorrow
Old 03-09-2008, 09:29 PM   #65
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Coming along nicely.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 03-10-2008, 06:34 AM   #66
corn
Looks like its takin shape. Good work!
corn is offline   Reply With Quote
Old 03-11-2008, 04:45 AM   #67
bad6772
bad6772's Avatar
Well after 5 hours in the shop i got the dash done...Really it was pretty simple to do...But the strange and awkward positions i was in, took up a little more time than i had planned...none the less it came out just like i had wanted it...I also got the new ignition bezel made ...but failed to take pictures.... I used a factory radio delete and put the ignition switch , lighter and Nos arm switch ...looks pretty good to me....just need to do some final welding and finish work ...Anyways here are a few pics ...Starting with...the panel i had to make...a coat of mud,followed by a coat of glaze. and some sealer...Name:  270 t.s.jpg
Name:  271 t s.jpg
Name:  272 t s.jpg
Name:  273 t s.jpg
Name:  275 t s.JPG
Old 03-11-2008, 04:47 AM   #68
bad6772
bad6772's Avatar
few more and my mock up dash....at this point i was just trying to make shure my lines were correctName:  276 t s.JPG
Name:  277 t s.JPG
Name:  278 glaze.JPG
Name:  280 primer.JPG
Name:  282 prime.JPG
Old 03-11-2008, 04:49 AM   #69
bad6772
bad6772's Avatar
and the last of them...Name:  283 prime.JPG
Name:  284 prime.JPG
Name:  285 prime.jpg
Name:  286 prime.jpg
sorry for the last two s quality ...the primer had not calmed down....yet
Old 03-11-2008, 08:41 AM   #70
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Look like it's coming along very nicely. You sure do good work. Could you hurry it up a bit though... I want to see some green paint on that bad boy.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 03-11-2008, 03:37 PM   #71
bad6772
bad6772's Avatar
LOL im telling ya Geoff..with the crappy weather, and the now pregnant wife my time out there is short lived. None the less i am hoping to get the cab done by the end of the month...in all reality if i dont...probably wont get to drive it to the meet....If the weather permits i will be starting to work on it after work..and not just forced to weekends or one day of the weekend....lol i keep staring at my paint cans ......i will post up a picture of the paint...i added a little something to it.....lol..........shhhhhhhhhhhh
Old 03-18-2008, 04:59 AM   #72
bad6772
bad6772's Avatar
small but needed work completed took a break from the cab stuff today and //got the engine cleaned and degreased with a little help from Longhorn Man....Thanks dude still need to clean some other things up and re-paint them from red to black...install the gear drive and plumb some lines.....the before pics are posted some where in here.....Anyway here they are.........Name:  eng 1.jpg
Old 03-18-2008, 05:18 AM   #73
jkaylor68gmc
jkaylor68gmc's Avatar
Love the build, keep up the great work!
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 03-18-2008, 07:26 AM   #74
BurnoutNova
i like that dash, very clean and different!
i dont follow where your ignition switch is goin? are you putting it in the wiper switch hole? i read somthing about a radio delete plate, but dont see it???
and about not having any time due to your kid on the way.... you better get out there now, you think your gonna get out there once he/ she is born? haha
Old 03-18-2008, 03:26 PM   #75
bad6772
bad6772's Avatar
thanks....yeah i keep telling my self that with the arrival of my soon to be child...i wont want to spend alot of time out there....but none the less doing a frame off and trying to do everything right in less than a year is not easy....especially when their is not a TEAM of people working on it....Just me...but i think i can pull it off...we will see....As far as where my ignition switch is going.....All i am going to say is that it is hidden and never will be seen. i will however get a few pics of the plate that i made...other than that .....thats one mod and location i am keeping to myself.....Sorry..................
