Old 11-14-2007, 03:59 PM   #51
jkade
jkade's Avatar
Re: 72 2wd Blazer: Project "Break Me"
Originally Posted by shifty View Post
what is that dash up there out of, anyway?
That is a 63 or 64 ford fairlane dash.
jkade is offline   Reply With Quote
Old 11-14-2007, 04:21 PM   #52
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by jkade View Post
I hope to be low I am thinking about running a back seat like below and having a trunk behind to to put luggage, battery, tank, amps, etc. The seat back will set up against the notch cover and the bottoms will be out in front like the blazer from the sema thread.
Attachment 314322
I like it. Furbird seats should work nicely- they're surprisingly comfy too...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-14-2007, 04:24 PM   #53
jkade
jkade's Avatar
I think it will look good, people won't be expecting to look in it and see the interior with the stock top. Should still have plenty of leg room also.
Old 11-17-2007, 08:57 PM   #54
jkade
jkade's Avatar
Well it's going to get c4 front suspension, picking up the 94 front parts tomorrow (pics this weekend). I was trying to work out a deal on the c4 dropmember that was going in the blazer that porter was building but I couldn't get a deal so I passed on that. Going to build a crossmember like a Art Morrison or a Jim Meyer out of some 2x4 tubing. It may not look as good as a dropmember but I won't have $3500 in my front suspension either. I think we can acheive the same results though.
Old 11-20-2007, 05:58 PM   #55
jkade
jkade's Avatar
Here are some pics of my c4 front suspension, I am waiting on No Limit to get back with me one of there c4 crossmembers before we start building one. I also have started welding and smoothing all the usless holes in the frame.
Old 11-20-2007, 11:55 PM   #56
Rokcrln
Rokcrln's Avatar
Personaly I would spend the $1400 or so on a dropmember. It has be designed for these trucks and works great. I can also build my own and have built several other types for customers but my 2WD Blazer will be running one of Nate's for sure. Just my .02
So what are you doing for rear suspention to try and match the front handling?
Kevin
LFD inc.
Rokcrln is offline   Reply With Quote
Old 11-21-2007, 08:07 AM   #57
jkade
jkade's Avatar
Kevin
LFD inc.
If the dropmember was cheaper I would buy one but I am not going to spend that kind of money on one. I am keeping the trailing arms out back and doing a watts link and a sway bar.
Old 11-21-2007, 10:26 AM   #58
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
How are you going to attach the watts link to the back of your 9"?
Tom Vogel is offline   Reply With Quote
Old 11-21-2007, 10:53 AM   #59
jkade
jkade's Avatar
Good question, I will burn that bridge when I get there.
Old 11-21-2007, 11:33 AM   #60
N2TRUX
Happy to be here
N2TRUX's Avatar
Personaly I would spend the $1400 or so on a dropmember. It has be designed for these trucks and works great....
Kevin
LFD inc.
You and several other competent builders see the advantages of the R&D that Nathan has done.
jkade- Good luck with trying to save money. There are some places that it's just not wise to cut corners. This is one of them.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-21-2007, 01:48 PM   #61
PBFAB.COM
PBFAB.COM's Avatar
One thought on the mounting for the watt's link... there are more advantages mounting the main pivot of the watts link to a crossmember that is fixed to the chassis, and the two end-links mounted to tabs/brackets on the axle tubes. Something to think about.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-21-2007, 08:16 PM   #62
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
!!!... o.k. ,you know, never thought of that.. Have yiu seen it done that way before? Or did you just think of it on your own. (good idea)
Old 11-21-2007, 09:02 PM   #63
PBFAB.COM
PBFAB.COM's Avatar
Not my own idea... read about it in several suspension design books. Makes sense though!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-21-2007, 11:14 PM   #64
Rokcrln
Rokcrln's Avatar
Not trying to sound like a smart ass but I am tired of people saying that I should spend my hard earned money on something I can't afford.
Thanks and I hope I have not offened anyone.
Sorry if I was pushing the DropMember it's just that you were talking about wanting one then it was a no limit set up. I did not know that you had friends that could help you build one. I would go that route as well but I am always that guy helping out his friends so it leaves very little time for my own stuff so I figure why re-invent the wheel. Plus Nates welds look way better than mine Make sure to show pics as you go along!
Kevin
LFD inc.
Old 11-22-2007, 01:18 AM   #65
smbrouss70
smbrouss70's Avatar
Here's one on a nova on the pro-touring board.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 11-22-2007, 07:32 AM   #66
Rokcrln
Rokcrln's Avatar
I must be a bit slow on this one. Why is one way better then the other?
Kevin
LFD Inc.
Old 11-22-2007, 08:18 AM   #67
jkade
jkade's Avatar
Kevin
LFD inc.
No I am not mad and I do change my mind a lot but I would like to have a dropmember and it would make it so simple. I can't spend the beans on that. I can make one, buy shock waves, and what I paid for my c4 stuff have about the same amount in mine as I would just the dropmember or it will be close. For the guys that can afford it go for it but I would have to save a couple of months to buy one and in that time I could ("we") build something.
Old 11-22-2007, 09:26 AM   #68
shifty
Questionable
shifty's Avatar
Hey jk, I just want to say, I understand your pain. I also looked at it, and it was too rich for my blood as well. I have no doubt in my mind that it's worth the money, but it's just not reasonable for me, my budget, or my truck - especially with me having a welder on-hand and friends that are much better at plans, construction, engineering and welding than I am.
On one hand I want to say, "hell yeah! that's great people will pay that much for it!" because it's great for the manufacturer. But on the other hand, it hurts because people paying that much sets the price on it, and that price setting is too much for my wallet and the wallet of the majority of us that are mid-level builders (primary buyer segment, IMHO). A $200-300 drop in price would put it closer to the "richness" of my blood so I could possibly justify it. This seems to be the case with a LOT of aftermarket parts for our truck (I have the same issues with a lot of ECE's stuff, especially their steel gas tanks).
I don't complain because I respect the manufacturers. I think it's great they can get top dollar and even more than top dollar on their product. I admit that I do feel a bit slighted or frustrated sometimes over it. I'm not a Boyd Coddington or Chip Foose, so it's not just a drop in the bucket for me to fork out for one. I guess the product *IS* intended for the hardcore customizer, and not the hobbyist (I think most of us here are hobbyists working on our life sized models).
I really wish manufacturers would come out with a cost-effective and/or economy product line for the average joe, you know, the people who make up more than half of the buyer market?
I'm digging your buildup thread, keep up the good work!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-22-2007, 09:51 AM   #69
PBFAB.COM
PBFAB.COM's Avatar
Kevin
LFD Inc.
It has to do with the rear roll center. The roll center is located at the center of the watt's link's pivot. If it's attached to the rear diff, the roll center will migrate up and down as the rear dif. goes through its travel. It will be much more consistent if it's attached to the chassis.
Not to hijack... just have to throw in my feelings on the Dropmember's price, which has been addressed in this thread. I base the price on my cost and margin that I need to make to stay profitable. If I could afford to sell it for $1000 I would be more than happy to. I understand that it's not in everybody's budget.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-22-2007, 10:12 AM   #70
Rokcrln
Rokcrln's Avatar
Ah I see said the slow kid from winters! So when attached to the body/frame the roll center will only move up or down as the body does. But when mounted to the diff it is all over the place with every bump and pot hole you hit. For us Cali boys that is alot of movement
Cool I have learned somthing for the day and now I can go back to bed and try again in the morning
Kevin
LFD inc.
Old 11-22-2007, 11:16 AM   #71
jkade
jkade's Avatar
I could budget and buy one but what that thing cost is a set of grey spoke 20's the way I look at it. Buying one would throw my project off about three or four months saving money for one. I know you guys may not like the no limit front kit but they are not out of the ball game yet, I am trying to work a deal out with them and to me it is no bid deal if it doesn't bolt in since it souldn't have to come back out anyways.
Old 11-22-2007, 11:17 AM   #72
jkade
jkade's Avatar
[QUOTE=porterbuilt;2456378]It has to do with the rear roll center. The roll center is located at the center of the watt's link's pivot. If it's attached to the rear diff, the roll center will migrate up and down as the rear dif. goes through its travel. It will be much more consistent if it's attached to the chassis.
That is some helpful knowledge.
Old 11-23-2007, 05:38 PM   #73
jkade
jkade's Avatar
I have been "playing" with photoshop, this is crappy and I am not sure if I like it but is the direction I am going.
Old 11-24-2007, 04:43 PM   #74
Rokcrln
Rokcrln's Avatar
Works for me! How would it look with a red windshield frame?
Kevin
LFD Inc.
Old 11-24-2007, 05:34 PM   #75
jkade
jkade's Avatar
I may like this look better.
