Old 01-01-2008, 05:00 PM   #51
monzadood
Re: my 48 s10 swap
you will enjoy the ride of your new chassis much better then the original. i recieved alot of greif when i decided to use a s10 chassis under my 51. i made my own mounts though.
1951 chevy truck
1983 gmc crew cab dually
1988 4wd suburban
monzadood is offline   Reply With Quote
Old 01-29-2008, 04:09 AM   #52
55dude
55dude's Avatar
Re: my 48 s10 swap
dude! it looks good. keep up the progress and you could be cruizing soon.
55dude is offline   Reply With Quote
Old 01-29-2008, 10:12 AM   #53
Lrall
Lrall's Avatar
Re: my 48 s10 swap
this is what we started with, flipped on the firewall to do the bottom, back, top, and some of the sides.
Had to fix the cab split, the floor was separating from the supports and such.
Also had to weld up the center mount(kit has 4 mounts, not stock 3 although it uses front stock mounts)
Nail gun, slide hammer, etc etc, TOOLS
practice...practice...first time welding...be gentle
instructions, this is partly welded i believe
and our SICK battery tray cover....huge metal shear + trim corners = perfection
Lrall is offline   Reply With Quote
Old 01-29-2008, 10:19 AM   #54
Lrall
Lrall's Avatar
Re: my 48 s10 swap
lots of nails, its honestly quite straight and nice now, we'll obviously use filler but im proud of how its going. I might be getting a 'built not bought' sticker for the back window
Old 01-29-2008, 10:27 AM   #55
jkaylor68gmc
jkaylor68gmc's Avatar
Re: my 48 s10 swap
lookin good!
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 02-05-2008, 11:02 AM   #56
Lrall
Lrall's Avatar
Re: my 48 s10 swap
Well, im sanding down all the spots the grinder didnt make pretty and then the body filler starts, im SO ready to be done with this cab. Ive got some stupid holes to weld up yet, i dont know how im going to fix them yet but itll get done. Just gotta keep moving....then comes mounting(i can let y'all know how that kit is) and then the FUN PART
Old 02-06-2008, 01:05 PM   #57
Lrall
Lrall's Avatar
Re: my 48 s10 swap
got all the holes welded up, tomorrow were going to 'convince' some dents w/ the torch and then filler
Old 02-09-2008, 03:58 PM   #58
55dude
55dude's Avatar
Re: my 48 s10 swap
really seems to be coming together. glad to see the pic's,how is the motor coming along?
Old 02-10-2008, 08:44 AM   #59
Lrall
Lrall's Avatar
Re: my 48 s10 swap
funny you ask, im going to pull the brackets and accessories off a truck tomorrow, single belt system with the one large bracket. Slowly but surely, big updates within the next month for sure.
Old 03-08-2008, 07:28 AM   #60
Lrall
Lrall's Avatar
Re: my 48 s10 swap
ok...3rd page is not cool. Ive got the cab in body filler right now...its very very close to being done. My goal is to have the cab mounted by next friday. Ill post up pics when it gets metal etch primed and mounted. Then ill be off for a week for spring break...btw body work SUCKS SUCKS SUCKS....i hate it haha. After metal etch prime we'll prime it and block sand it, then jam it with the gunmetal grey. Then comes motor, i guess there is an update. We bought new stock s10 motor mounts and bought the v8 conversion mounts from jagsthatrun.com and will be going that route. The mounts look to be very good quality. Then the 700r4 trans w/ corvette clutches(noob talk i know) and a new torque converter followed by a driveshaft made by yours truely(more like my autos teacher) and the driveline should be finished. Then ill probably put the front belt system on, radiator, trans cooler and wire it up. Then ill throw on the front clip, cut the inner fender skins for control arm movement and then the hood. We will also paint the firewall and fender skins black.
Old 03-08-2008, 10:06 AM   #61
55dude
55dude's Avatar
Re: my 48 s10 swap
hey! do they offer a photography class in your school? glad too see the progress on your truck. your right body work SUCKS! you know we will be waiting.
Old 03-08-2008, 10:09 AM   #62
Lrall
Lrall's Avatar
Re: my 48 s10 swap
lol...im mainly too lazy to upload them.....
Old 03-18-2008, 05:00 AM   #63
Lrall
Lrall's Avatar
Re: my 48 s10 swap
Old 03-18-2008, 05:24 AM   #64
jkaylor68gmc
Re: my 48 s10 swap
Outstanding ! Looking great, it seems like only a few years ago I was in high scool autobody building the old international, I think it has been nearly 5 years now. Keep it going!
1962 swb fleetside
Old 03-18-2008, 08:49 AM   #65
Lrall
Lrall's Avatar
Re: my 48 s10 swap
Friday i got the cab mounted(with some help from a couple autos classmates) The front went smooth as glass, the AD kit makes it soo simple, im sure on later trucks with the rear mounts its easy. We mounted the front and put the bolts through then moved to the back and squared it up. then i drilled up from the bottom and bolted it down. Next tuesday when i go back to class im goin to cut a little out of the seat frame and put a 'washer' of sorts in. Just to add stability and strength. I dont know how much you can see it but we(my teacher) metal etch primed the whole cab, then primed it(many coats). Then the bottom got painted gloss black. After i finish mounting the cab ill finish the body work on the doors then prime them, hang them and fit the gaps. Then block the whole thing. Then its MOTOR TIME
Old 03-18-2008, 06:48 PM   #66
55dude
55dude's Avatar
Re: my 48 s10 swap
looks like it's really coming together! at the price of gas (3.60) here a nice 6 cylinder might be a option unless you have something else for daily driving. gotta be nice when you got help like that.did you figure out the lock situation?
Old 03-18-2008, 06:53 PM   #67
Lrall
Lrall's Avatar
Re: my 48 s10 swap
BAH gas....lol its an extra truck. No way in hell am i making my hotrod with anything less than a v8. Ive got my taurus, gpa has his blazer and camry. We bought a 350 brand new from GM for 1700 so...it was a nice deal haha As far as the lock thing....i havent figured it out, its kinda buggin me too. I cant do much as all the latches and lock components are at the HS and were on break. i need to figure out how the pass side works and see if i can fab something up to make it work.....
Old 03-19-2008, 12:49 AM   #68
weldvair@embarqmail.
Re: my 48 s10 swap
Besides the 6 cyl uses as much gas as the 8.
Don Meyer
weldvair@embarqmail. is offline   Reply With Quote
Old 03-19-2008, 05:06 AM   #69
55dude
55dude's Avatar
Re: my 48 s10 swap
which 2 motors are you using for comparison?
Old 03-19-2008, 05:54 AM   #70
Lrall
Lrall's Avatar
Re: my 48 s10 swap
No offense fellas but take that to PM, ill have a TBI v8
Old 03-30-2008, 08:22 PM   #71
55dude
55dude's Avatar
Re: my 48 s10 swap
any updates?
Old 03-30-2008, 08:36 PM   #72
Lrall
Lrall's Avatar
Re: my 48 s10 swap
Well...i have one of the doors hangin in the paint room and the other needs about 5 minutes of sanding then its ready. So i will probably shoot those on monday. Then we will hang the doors and even the gaps all the way around. I finished up the doors this week, along with permanently mounting the cab, so kind of a slow week, but i dont work after school anymore so the updates should come more readily
Old 04-03-2008, 05:04 AM   #73
Lrall
Lrall's Avatar
Re: my 48 s10 swap
update: I metal etch primed then epoxy primed the doors and firewall monday night. Today we got the dash block sanded along with the firewall and i started in on the roof. The plan is to get the roof done, then hang the doors, set the gaps and finish blocking the rest of the cab and prime whatever i need to once(hopefully) more, sand that down and its done!! Ill have to get pics up of the doors and firewall, i also covered my frame completely in 3M plastic. By the end of next week my goal is to have this thing ready for motor!!
Old 04-03-2008, 07:08 PM   #74
55dude
55dude's Avatar
Re: my 48 s10 swap
at this rate summer cruzin is just around the corner. your truck is coming together and quite the pace,way to go!
Old 04-04-2008, 02:48 AM   #75
Lrall
Lrall's Avatar
Re: my 48 s10 swap
haha yea, it will be done by july...come hell or high water
