Old 01-18-2008, 01:53 PM   #51
greg64
greg64's Avatar
Re: Crewcab build
Originally Posted by PrerunnerRob View Post
It's kind of funny, I'm seeing more time making this section and the doors work right then I was going to have into my existing truck total!
Rob, I've got to say good on you for doing this project. When I look at these sorts of major changes, I think "oh lord, the amount of work....".
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 01-18-2008, 01:56 PM   #52
PrerunnerRob
PrerunnerRob's Avatar
Re: Crewcab build
Thanks! I'm worried, but not scared!
PrerunnerRob is offline   Reply With Quote
Old 01-18-2008, 04:23 PM   #53
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Crewcab build
I think you could virtually eliminate the filler panel in between both the front and rear doors, maybe cut the rear door an inch shorter(judging by how it looks in the factory photo) that will move the rear doors front post closer to the front door.
Then check out some other 4 doors, the 73-81 truck has about a 1 inch filler panel in it, a 55-6-7 chevy 4 door sedan has about a 3/4 inch filler in it..I think that the filler might be there in those to work with the different angles when opening and closing the doors..?
If you are able to, look some other 4 doors as well maybe the hinges from a 59- 60 passenger car, or a lincoln continental(could handle the weight)might work.
Also check out my post (# 16) in the 2008 world of wheels thread, I posted an idea about how to put a one piece window in this type of door...It might work.
If I ever find/get/make a crew cab, I would fix the post in between the doors, alot of work, but it looks better in the end.
Old 01-19-2008, 08:27 AM   #54
jonzcustomshop
1961 crewcab
Re: Crewcab build
here is for joe 231
this one, all the door pillars match the windshield pillar.
Old 01-19-2008, 11:10 AM   #55
PrerunnerRob
Re: Crewcab build
I like the 4 door angle, where they all match, it looks sharp!
I just got back from my shop, I did some layout of what it would take to roughly make the door work. I think I'm going to have to bite the bullet and get 2 more doors to cut up first, that way I can make my mistakes on them if I need to. Thanks for all the help guys, you are making this much more enjoyable!
So I figure if I get the front door angle set, I'm going to re-angle the back doors too, that way everything is neat and clean.
Old 01-19-2008, 11:31 AM   #56
hewlett2002000
hewlett2002000's Avatar
Re: Crewcab build
what ever you do, please dont cut up a pair of good doors unless your sure. use rusty ones for your test. i had a pair i would have gave you but i junked them, they had ALOT of rust. good luck and it looks GREAT so far. keep us posted.
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 01-19-2008, 11:53 AM   #57
PrerunnerRob
Re: Crewcab build
John
Thanks! I always feel bad about wasting something I can't replace, I think I might have found a pair of rustys I can work with locally.
Old 01-19-2008, 12:56 PM   #58
joe231
joe231's Avatar
Re: Crewcab build
Originally Posted by jonzcustomshop View Post
here is for joe 231
I bow to your chopping talent, we're not worthy
that is sooo sweet!! looks the best IMHO, thanks
Old 01-19-2008, 01:00 PM   #59
joe231
joe231's Avatar
Re: Crewcab build
as they say, every act of creation is an act of destruction.
look at it as a sacrifice for the greater good of a sweet project
Old 01-19-2008, 01:18 PM   #60
PBFAB.COM
PBFAB.COM's Avatar
Re: Crewcab build
here is for joe 231
It would look good with the back top edge of the front door and the top front edge of the back door corners squared... and then radius the top rear edge of the back door to match the front.
I think it would be easier to make the door mods by using two sets of doors, that way the window channels and top edge radii will all be perfect.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-19-2008, 01:29 PM   #61
PrerunnerRob
Re: Crewcab build
radii...nice!
Do you mean 4 doors total or 4 pairs of doors....I'm kind of confused at this point.
Hmmm, the 2 squared, 2 rounded would look slick!
Old 01-19-2008, 01:36 PM   #62
PBFAB.COM
PBFAB.COM's Avatar
Re: Crewcab build
radii...nice!
Probably get by with using a total of six doors. The four good ones you will end up with, and then pieces of the other two to splice in the sections of the window channels, door edges, and post sections where you're stretching and adding material.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-19-2008, 02:56 PM   #63
poorboy
poorboy's Avatar
Re: Crewcab build
I have a pass door that has a bunch of cancer that you can have to experiment with. I am also selling 2 drivers doors and 1 pass door if you need more material.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 01-19-2008, 11:53 PM   #64
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Crewcab build
If you need to look at some hinges...your welcome to look at the wifes '57 Wagon.....
Looking good man....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-20-2008, 12:06 AM   #65
Tim64
Tim64's Avatar
Re: Crewcab build
Hey John,
You got any pics of your wifes wagon? Sounds cool I'd love to see it.
Tim64 is offline   Reply With Quote
Old 01-20-2008, 08:54 AM   #66
kris's66lwb
resident wrencher
Re: Crewcab build
Originally Posted by joe231 View Post
Hey jonz, can you, with your chopping skills, match the angle of the rear part of the front door to the rear part of the rear door, so both doors match?
both raer angels are the same in the original cuz there both front doors just with the part that gose under the windsheild cut off
kris's66lwb is offline   Reply With Quote
Old 01-20-2008, 09:15 AM   #67
royo
royo's Avatar
Re: Crewcab build
Originally Posted by poorboy View Post
That one on ebay is nice. Here's a couple of the pics.
whats wrong with doing it the way they where made. besides the hinges. this one looks good!! it looks like it has 1 pcs window in back door too.
nickle and dime
royo is offline   Reply With Quote
Old 01-20-2008, 09:22 AM   #68
Rokcrln
Rokcrln's Avatar
Re: Crewcab build
Yep pic #2 is what I was trying to get at on page one I like what you are thinking with your layed out door you are drawing on BUT, keep in mind were your top edge of the door is in relation to the door hinge pivot. Any part of the door that is in front of that pivot point will swing inward when the door is opened and if this part of the door happens to be the top of the window post (pic #1) the door will bind up and not open. This is the reason for the filler pieces in most crew cabs. Also I have looked at the door hinges on a 65 (not sure if they are the same or not) that I was working on for a co-worker and I think they will work for a rear door if the jamb and door are set up right. On the 68 crew cab that I built I just used the stock burb rear door hinges and reworked the jambs and it turned out great.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-20-2008, 09:24 AM   #69
Rokcrln
Rokcrln's Avatar
Re: Crewcab build
Nothing, but this one is a 64-66 not a 63 like what he is working with. The doors are completly different! Even know this truck looks good it would look great if the pie section between the doors was smaller and paralell.
Kevin
LFD Inc.
Old 01-20-2008, 02:04 PM   #70
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Crewcab build
Originally Posted by Tim64 View Post
Hey John,
After all this talk about the pie section...if you look at the black one...the section between the doors does look like s#it !!!
TIM, I thought I had one, but I don't I'll snap a pic and post it.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-20-2008, 02:07 PM   #71
PrerunnerRob
Re: Crewcab build
Kevin
LFD Inc.
You hit the nail right on the head, I have been trying to make this work for the past few days, and that is the exact problem I run into. You have to mainain the door on or behind the pivot point, or it dives in when opened. I'm still going to try to see if I can pull it off without a filler, but I'm going to be making some cardboard doors tomorrow, and change the pivot point to see what the minimum filler is I will need. I could always suicide the rears, but I am just not happy with the operation and install method of the hinges I have seen.
Old 01-20-2008, 03:21 PM   #72
joe231
joe231's Avatar
Re: Crewcab build
You took what I said out of context, I was referring to jonzcustomshop's second photo chopped pic, not the original
Old 01-20-2008, 10:17 PM   #73
jonzcustomshop
1961 crewcab
Re: Crewcab build
You might also play with some different types of hinges, some that would swing the door out and back while it opens, they just might not fit on the narrow middle hinge pillar...
suicides might be the easiest solution.
Old 01-20-2008, 11:58 PM   #74
PBFAB.COM
PBFAB.COM's Avatar
Re: Crewcab build
X2
Think how cool it would look with this beast laying on the ground, and both doors open with only a litle B-pillar in the middle!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-21-2008, 12:14 AM   #75
TimE
Hey Y'all!!
TimE's Avatar
Re: Crewcab build
X3!
TimE is offline   Reply With Quote
