05-20-2008, 06:52 AM | #51 |
Re: The LS1 swap headers are done!!!!
Why would anyone want to move the engine so far forward in the engine compartment just to make these headers (or any other brand of headers)work? Seems like other headers could be used & tweaked where needed vs. having to reconfigure more than just the exhaust.
Am I missing something?
05-20-2008, 06:43 PM | #52 | |
This is just for the 73-87 guys and I would not want to move the motor further towards the front either, makes no sense. They fit fine on the 67-72's. I'm still trying to find a way to "adjust" the driverside to fit both generations. I think I might have to bribe someone out there to make changes on that side and send it back to me so I can adjust the fixture. Jamie |
05-20-2008, 07:34 PM | #53 | |
What is the interference issue w/a stock trans dipstick?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-20-2008 at 07:35 PM. |
05-20-2008, 08:34 PM | #54 |
www.73-87chevytrucks.com
Jamie,
I talked to you before when you wanted to wait for PCM to test his. I have access to my 73-87 AND I have access to a 67-72, both with LS powerplants. I don't mind cutting them up if I am covered. I can say that I tried ECE mounts on the 73-87, you DO NOT want to do this, It will force you to move your whole drivetrain forward, causing you to have to move the crossmember and get a longer driveshaft.... Look at this post for a comparison of the ECE over 3" forward, vs the plates. http://67-72chevytrucks.com/vboard/s...8&postcount=38 I also have access to 1" back mounts and I can swap them out and see if I can mod the headers to fit that setup on a 73-87, that way it would cover all mounts. More people will be inclined to move it back than forward in my opinion..
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
05-20-2008, 08:56 PM | #55 |
I've seen the 1" 'set-back' mounts. My mind considers "set-back" to mean move closer to the firewall. Does anyone know for sure if this is correct?
05-20-2008, 09:07 PM | #56 |
Yes that is what they are, 1" closer to the firewall.
05-20-2008, 10:10 PM | #57 |
05-21-2008, 01:05 AM | #58 | |
Your right on the the ece/73-87 senario, way too much to ask anyone to go through. This is the route we would all prefer. Jamie (951) 739-5900 ext.211. Call and we can discuss all the details. |
05-21-2008, 09:00 PM | #59 |
The 73-87 version is on the way!!!! If all goes well, this header (thy324y-c) will cover from 67-87.
Special thanks to Captkaos (Chris) for taking this on!!! |
05-22-2008, 01:04 AM | #60 |
Primary & collector sizing?
05-22-2008, 05:06 PM | #61 |
The primaries are 1.625", 2.00" secondaries and 3.00" at the final collector. A reducer is supplied to take the pipe down to 2 1/2" head pipes if desired.
07-09-2008, 12:05 PM | #62 |
Any word on the 73-87 headers yet?
07-09-2008, 01:41 PM | #63 |
07-09-2008, 02:00 PM | #64 |
Didn't PCMCobra volunteer?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-09-2008, 02:10 PM | #65 |
07-09-2008, 03:20 PM | #66 |
Jamie is looking for a truck with an LS motor that he can fabricate a new set for the 73-87 trucks. The 67-72 set will not work with 73-87 trucks.
This is the Thread (in the 73-87 board) he started looking for a truck to work on. http://67-72chevytrucks.com/vboard/s...d.php?t=295052
07-09-2008, 07:10 PM | #67 |
I did volunteer to test fit, but I have never even held a welder, so I can not make the "corrections". Sorry I am "welding impaired", lol
Jamie, I emailed you several weeks ago, never heard back...
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
07-10-2008, 12:35 PM | #68 |
08-25-2008, 11:06 PM | #69 |
Can you get these headers with a "v" clamp collecter. What are the headers running a guy. I see someone already asked about Canadian shipping. If possible can you give a quote for a set/kit (bolts and gaskets) for a 68 chev with shipping to T4L 0A2 Alberta. I tried emailing off of the website but never heard anything back.
Thanx. Trevor tk-mpl@shaw.ca |
08-31-2008, 05:26 PM | #70 |
I'd take a set as well.
Maybe we could do a Alberta Group buy and combine shipping???
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
11-03-2008, 10:34 PM | #71 |
Amateur Rust Fighter
Jamie, are these prices still good? I was hoping the stainless F-body Hookers I have had sitting here for a couple years (bought for my '02 Z28 but not yet installed) would work, but they simply will not clear my CPP mounts. The stock LS1 ('99 Z28) manifolds won't clear, either. I'm torn between buying different mounts at ~$235 or headers at more than twice the price. Despite the pics posted here using CPP mounts, I'm concerned about spending all that money and finding out the new headers won't clear, either. Not sure if the pics attached will help answer my concerns but just in case....
Thanks, Brent
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) |
11-03-2008, 10:49 PM | #72 | |
R/
11-03-2008, 11:43 PM | #73 |
I'm having troubles finding long tubes that will fit without hanging too low. We have a 4 bolt 350 with a muncie 4 spd. trans. Got any ideas anyone??
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
11-04-2008, 01:39 PM | #74 | |
Just call Nick at 951-739-5900 and he should be able to take care of you. Be sure you tell him that you are a member of this site and that you have been speaking with me. Since the headers were designed on a truck with cpp mounts, I don't think you will have any issues. Jamie |
11-04-2008, 11:30 PM | #75 |
Thanks, Jamie. I'm gonna assess my financial situation (just went back to work Monday after being let go from my old job on 10/21) and then decide if I can take the plunge.
