Old 10-26-2008, 11:00 PM   #51
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Rear bag mounting pics please
I used the 7" version. They are a little bigger than the Slams, but not by much. I don't know how they would do up front- my truck is static front/bagged rear...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-27-2008, 08:31 PM   #52
slammed65stepside
65 C10 STEPSIDE
66 C10 3" CHOP CAB
55 BUICK ROADMASTER
07 F150
07 22 Ft FOUR WINNS
slammed65stepside is offline   Reply With Quote
Old 10-27-2008, 09:58 PM   #53
orange71
http://sportruck.com/events/blood-drag-2008/i32.html Here is the rear setup of my truck
orange71 is offline   Reply With Quote
Old 11-23-2008, 01:53 AM   #54
Dustin07
Stirrer of the Pot
I forgot about this thread...
anyone else have more pics of bagged rides utilizing the stock trailing arm setup instead of the 4-link and wishbone setups we see more often?
Dustin07 is offline   Reply With Quote
Old 11-23-2008, 05:12 AM   #55
Bazooka
Keepin it old school
Bazooka's Avatar
Originally Posted by tk-mpl View Post
Hey gringoloco, which dominators did you put in. The 2600's look pretty big for the front....
The Dominator 2600s are equivalent to the Slam RE7. Alot of people Use the slam RE7 on all 4 corners so you should be okay.
I will be using Dominator 2600s on all four corners. My truck is at the shop right now...
Bazooka is offline   Reply With Quote
Old 11-23-2008, 01:35 PM   #56
mycool72
mycool72's Avatar
I have doms on mine, between the factory arms and frame, one bolt from the bottom, two from the top-works great
mycool72 is offline   Reply With Quote
Old 11-23-2008, 03:19 PM   #57
tk-mpl
tk-mpl's Avatar
When you guys mount the front bags done you weld in the buttom cup or just let it move around??
Thanx
Trevor
tk-mpl is offline   Reply With Quote
Old 11-23-2008, 04:09 PM   #58
joe231
joe231's Avatar
the lower cups float, or you wouldn't be able to remove the bags later.....
well maybe you could through the hole in the spring pocket
CHEVY ONLY
Old 11-23-2008, 05:37 PM   #59
Dustin07
Stirrer of the Pot
my lower cups are welded in and I bolt them through the bottom of the a-arm.
Old 11-23-2008, 06:14 PM   #60
hotrodhomi
hotrodhomi's Avatar
Thanx
Trevor
Mine floats in there just like the spring did.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 11-23-2008, 11:24 PM   #61
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Mine float in the A arm as well. I actually cut 1" off the bottom cup and like it. I will be doing the rear airride install this spring, when I swap my GMC over to a Chevy frame.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 11-24-2008, 12:33 AM   #62
tk-mpl
tk-mpl's Avatar
Thanx guys. I think I got everything figured out. Got the rear C-notched and bagged, done right this time, and the front all done. Just got to get the air managment system, $$$, then I can bolt all this stuff in place..
Old 11-24-2008, 12:47 PM   #63
Dustin07
Stirrer of the Pot
Hey TK- can you post some pics of your new setup? thanks bro-
Old 11-24-2008, 12:59 PM   #64
tk-mpl
tk-mpl's Avatar
I haven't got it all mounted yet, but specifically what would you like a pic of. I mocked up the rear, just didn't bolt it up.
Let me know whatcha need.
Trevor
Old 11-24-2008, 01:19 PM   #65
Dustin07
Stirrer of the Pot
I'd like to see a pic of how how your bags are mounted, how you are running the airline, and how big your notch is...
Sorry for the laundry list... LOL. I'm trying to decide on how wild or mild to do my brother's 62. I have it mocked up for a pretty mild job for now, but am contemplating more.
Old 11-24-2008, 01:49 PM   #66
tk-mpl
tk-mpl's Avatar
I posted a pic of the rear in post #47. I haven't run the lines yet, cause I don't have the funds for the air management system I want yet. I have a basic c-notch bolted in with air lift dominators (2600's). The rear diff hits the bed floor before the axle tube hits the c-notch bumpstop, have about 1" before it'll hit. So I will more then likely cut the bed floor out abit..
Old 11-24-2008, 04:13 PM   #67
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
www.***************** has some good deals.
Old 11-24-2008, 06:34 PM   #68
tk-mpl
tk-mpl's Avatar
Ya, I know... I want the auto pilot kit.. Spent all my money on powertrain and still not done..
Old 11-25-2008, 07:27 PM   #69
FELON'S
FELON'S's Avatar
I was stoked to find this thread...Im putting bags in this weekend. I also have trail arms (C20) with Dominator's all the way around...Im lookng for a wiring diagram from battery to two compressors...
FELON'S is offline   Reply With Quote
Old 11-25-2008, 07:56 PM   #70
screwballl
Tonawanda 454
screwballl's Avatar
no C-notch here, just some bags on my R2500 that look like they may have been original (or maybe not)...
I think it may be original because there are no springs, it is just leafs and bags... I do know they work well although they are manual fill, no automated air pump...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 11-26-2008, 12:27 AM   #71
scotts62
One day...
scotts62's Avatar
Yeah i bet they do! looks like you can hold some weight with that setup!
Scott
93 crew cab build
Project 62
Old 11-26-2008, 11:46 AM   #72
pocketpool
here's mine, slam re-7's
pocketpool is offline   Reply With Quote
Old 11-26-2008, 11:48 AM   #73
pocketpool
more.
Old 11-26-2008, 01:28 PM   #74
tk-mpl
tk-mpl's Avatar
Hey Pocketpool, nice set up. Good pics-thanx.
Trevor
Old 11-26-2008, 06:30 PM   #75
Dustin07
Stirrer of the Pot
I guess I was specifically hoping to see mounting hardware and what not. I did see your other post. It looks like guys are just running a single bolt through the middle of the trailling arm, but I was confused on that because of the "I" shape of the beam. I'm going to play with it tonight and hopefully get these things in and done before Friday.
