Old 10-30-2008, 01:10 AM   #51
Momboy007
Re: frame swap for a 4x4
Hello Grendel,
When you say there is a 1 " differnece in the middle of the frame between a 2x4 truck and a 4x4 truck, will it matter if I want to convert my truck from 2x4 to 4x4?
Thanks,
Rick
Momboy007 is offline   Reply With Quote
Old 10-30-2008, 07:21 AM   #52
FormerMember
FormerMember is offline   Reply With Quote
Old 10-30-2008, 04:20 PM   #53
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Originally Posted by padresag View Post
I did measure the depth of my frames and the 2 x 4 was 6" deep(about 10" behind the frt cab mount) and the 4 x 4 was 8" so there is a 2" difference between the frames
ron
And both of these are 1/2 tons, right? Just curious, thanks Ryan.
Dieselwrencher is offline   Reply With Quote
Old 10-30-2008, 04:38 PM   #54
padresag
yes
ron
padresag is offline   Reply With Quote
Old 10-30-2008, 04:40 PM   #55
prg machine
prg machine's Avatar
so are the 3/4 4x4 frames taller\?????
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 10-30-2008, 04:49 PM   #56
padresag
Originally Posted by prg machine View Post
so are the 3/4 4x4 frames taller?????
I guess that no one could be bothered to measure it
ron
Old 10-30-2008, 05:32 PM   #57
Jtrux
I'm a poor spectator
Jtrux's Avatar
I've got it in my head now that i'm gonna convert my 2wd chevy frame with rear leaves to 4x4. I need to call Kurt at DIY and see if his FGB52 spring hangers will work. Nothing too radical but cool none the less.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-30-2008, 05:41 PM   #58
FormerMember
Old 10-30-2008, 09:59 PM   #59
prg machine
I guess the question is: If side by side 3/4 ton or 1/2 ton 4x4/..........................is one taller in the channel height than the other or both the same height???
383 .040 over
Old 10-30-2008, 11:14 PM   #60
og350
og350's Avatar
where would you like a measument from? let me know i have a 71 3/4 4x4
og350 is offline   Reply With Quote
Old 10-30-2008, 11:17 PM   #61
padresag
I took my measurement about 10" behind(towards the rear) of the frt cab mount
ron
Old 10-30-2008, 11:41 PM   #62
og350
og350's Avatar
ok i will try to get it measured tomorrow after work.
Old 10-31-2008, 02:33 AM   #63
prg machine
okay, I'll measure my 69 K-20.
The reason I ask is if there is /was a diff between the 3/4 or the 1/2 K trucks. and a diff between those to the 2wd same trucks
383 .040 over
Old 10-31-2008, 04:38 PM   #64
Jtrux
Jtrux's Avatar
Originally Posted by grendel View Post
They will work. I did it.
With the 52" springs, you don't have to mess with the e-brake bump out. Tell him I sent you.
Yeah i'll tell him. Hopefully get started real soon. Need to get the truck out of storage first.
Old 11-02-2008, 11:13 AM   #65
FormerMember
Old 11-03-2008, 07:47 PM   #66
og350
og350's Avatar
ok so sorry it took me a few days but the frame and my 71 3/4 4x4 is 6" from top to bottom of the rail all the way under the cab. hope that helps
Old 11-03-2008, 10:55 PM   #67
prg machine
I will be off this Friday and can go measure then it is dark before and after work and raining right now.......................seems like the 69 K-20 I have is also 6 inches if i was to guess.
383 .040 over
Old 11-05-2008, 07:56 PM   #68
Dieselwrencher
Some great info here on the frame height differences. I thought there was an inch difference between the 2x4 and 4x4 versions, but sounds like there's two inches?
On my Longhorn frame, which I think would be the same as a camper special leaf spring rear susp truck, there is only 3/8 difference in frame channel heighth according to these measurements. As Padresag posted his 4x4 3/4 ton frame is 8" high at 10" behind the front cab mount. My Longhorn frame is 7 5/8" From top of flange to bottom of flange 10" behind the front cab mount. So maybe there is an inch difference on the coil spring rear 3/4 ton trucks?
