Old 10-29-2008, 06:46 PM   #51
Somecallmejoe
Re: runs great, at first
When i say the pickup coil i don't mean the ignition coil on top of the distributor. Underneath the ignition module there is whats called a pickup coil. This link tells you how to test it.
http://www.73-87.com/7387garage/drivetrain/pkupcoil.htm
Somecallmejoe is offline   Reply With Quote
Old 10-31-2008, 08:45 AM   #52
67ChevyRedneck
67ChevyRedneck's Avatar
Looking at your other thread with the pic, I'd remove the fuel pressure regulator and run the truck before I mess with anything else. These trucks never had a regulator on them and with the carb set up correctly there is no use for it at all. It's most likely starving the motor.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-31-2008, 09:08 AM   #53
1970heavychevy
busted knuckles
1970heavychevy's Avatar
I rebuilt the carb last night and its dialed in now. The regulator didn't help the issue and I don't like the way it looks, so I was planning on taking it out. The parts guy suggested it. I am putting a new (used) intake on and the rebuilt carb, flushing the lines and cleaning the tank this weekend. Then I can rule out fuel as an issue. I've also been told to wire my choke open.
1970heavychevy is offline   Reply With Quote
Old 10-31-2008, 09:28 AM   #54
tommyjnns
what kind of filter do you have near the tank, i believe a inline filter mounted before the fuel pump would cause these issues.
tommyjnns is offline   Reply With Quote
Old 10-31-2008, 09:33 AM   #55
1970heavychevy
busted knuckles
I have a small filter with the glass tube casing.
Last edited by 1970heavychevy; 10-31-2008 at 09:34 AM. Reason: miss under stood question
Old 10-31-2008, 09:42 AM   #56
tommyjnns
i have never seen one mounted before the fuel pump so that could be the problem.
Old 10-31-2008, 09:53 AM   #57
Longhorn321
Size Matters
Longhorn321's Avatar
I have two before the pump and it does fine.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 10-31-2008, 09:57 AM   #58
Longhorn321
Size Matters
If you could rig a small gas can under the hood safely and run hose straight to the pump, that would eliminate the tank, filter, lines etc.
...WOOOO HOOOO!!!!
Old 10-31-2008, 11:14 AM   #59
67ChevyRedneck
I've run an inline filter on my truck for the past 12 years. It's under the cab on the PS side. Runs fine with it.
Jesse James
Project "On a Dime"
Old 10-31-2008, 11:32 AM   #60
tommyjnns
well that rules that out, i am sure alot of people are running them before the pump now that i think about it
Old 11-02-2008, 08:40 PM   #61
Somecallmejoe
any luck yet?
Old 11-03-2008, 10:31 AM   #62
1970heavychevy
busted knuckles
I just got it all back together Saturday but had a leak at the thermo housing. Fixed it Sunday and will be trying it out today. Thanks for checking in I will let you know. I will be putting some pictures up also, It looks great, just hope it runs that way.
1970 Chevy C10
Powered by a 1970 Impala 350
Edelbrock 1405 carburetor
HEI ignition
Turbo 350 transmission
http://flickr.com/photos/pelt
Old 11-03-2008, 12:42 PM   #63
Somecallmejoe
OK i hope it works out for ya
