#51 |
Re: '68 C10 Short-Step 6.0 + TT swap
What size are those tires
#52 |
![]() Join Date: Sep 2008
31 X 16 X 15 MT SR Sportsman radials
![]() They were are as wide as possible to fit without ditching the stock frame rails, and still tuck without trimming fenders.
'68 Chevrolet Short Step
6.0 L + 91mm + TH400 + 9" + 4-Link |
#53 |
very nice build, incredible welds!!
#54 |
Thank you!
Scoti - Thanks for the bumper pics. I think that will wait until I do a real resto on it. For now, I am going to rock the PRO FARM look! Side note, for whatever reason, my oil pan wouldn't clear the front cross member. Even after swapping to a F-body pan, it still touched (I used ECE LS1 towers & mounts). SO...had to pull it out and move it back about 1.5". No big deal since there was plenty of room. Now to install the tranny, and measure up for the driveshaft. Thanks for the comments guys.
#55 | |
![]() Join Date: Apr 2005
The truck is looking great. The Cadillac CTsV pan works great with the ECE motor mounts. If you look at my suburban build page, it shows a lot of pictures. If you have an particular questions, let me know.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#56 |
very nice 4 link set up, did you fab that or was it kit? if a kit who sales it? love the meats out back
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#57 |
that suspension looks amazing, nice dimes on the wwelding, and as for the tirees, not quite wide enough
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#58 |
Thanks again everyone.
Sour - the 4-link is 100% fabbed. I agree the tires aren't as wide as I would have wanted, but I didn't want to cut the frame. Hindsight...well, we all know what that looks like.
#59 |
very nice work and engineering! welds look great!
#60 |
Well, how about an update???
Brown Santa came to see me this week: ![]() ![]() ![]() ![]() ![]() Also got 80lb injectors, custom spec'd turbo grind cam & misc other stuff too. I also got away from twin turbos, and will use this larger single. It will be a front mount. Pulled the motor, honed .005 over and went with Eagle rods and Weisco pistons. Worked the 317s over, fulled ported & polished with Patriot Dual Golds. Ported Vic Jr, the Vic elbow and the TB too. Caddy lifters & SFI rated balancer too. Man I am getting stoked about this thing again!
#61 |
Need more progress man, been a while. the turb will get you moving.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
#62 |
Between Trucks...
Totally sick build. Subscribed.
Beat it to fit, Paint it to match... ![]() |
#63 |
Thanks guys. Yes it has been too long, but I have a 7 month old son, so that has been slowing things down a bit.
#64 |
Well, got some time off, and made some progress:
Built motor is in. Pulled the old fuel system and upgraded for the new power levels. 10AN lines to supply the fuel rails and new 80lb injectors. Intake is on and throttle body is hooked up. Radiator mount is done & installed. Changed the front drop from 4.5" to 5.5" and installed new drop shocks. Almost forgot... ![]() ![]() ![]()
#65 |
Love the look, gonna be one hell of a sleeper. What year are those impala fans? they fit pretty good.
#66 |
Late 90's I think. Turns out they won't work with my new radiator, but they fit well on the stocker. I ordered new fans already, so I will probably sell those.
#67 |
that is looking super mean! wait till one of those little punks with a coffee can on their car pulls up to the light with you!! sssshhhhh, see ya!
#68 |
Holy sheeeeet , that is huge!!!!!
#69 |
I Like Mine With No Shine!
![]() Join Date: Apr 2009
Wow! Awesome truck you are building! And great welds too!
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
#70 |
havent checked back in a while, thats one big turbo!! slick work man!
#71 |
need updates.
#72 |
OK, here goes nothing (literally)...
Found some issues with the motor, and had to pull it back out. Kinda a kick in the balls. In the meantime, I decided to ditch the flipped factory manifolds and we are going build a set of turbo headers for it. Just need the motor back so we can stab it back in and resume fabrication. Like I said, nothing worth while going on! ![]()
6.0 L + 91mm + TH400 + 9" + 4-Link Last edited by SCIV; 05-25-2010 at 09:52 AM. |
#73 |
![]() Join Date: Sep 2007
So sick.
#74 |
dont suppose u feel like sharing the motor problems? what happened?
#75 |
main & rod bearing clearances were way too tight for the HP I am shooting for. Good thing I didn't run it & beat on it, it would have ended with a ventilated block.
