Old 04-27-2010, 08:45 PM   #51
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: How to install a Camaro T-5
Well what can i get that will hold up to some power? What about f#rd mustang 5.0 5 spds? Wha'tre they
John
1999 Toyota Tacoma 4x4
Old 04-29-2010, 09:44 AM   #52
Mister laugh
Most of them are t-5's aswell, they won't bolt up to your bell housing either.
Mister laugh is offline   Reply With Quote
Old 04-29-2010, 08:52 PM   #53
oldblue1968chevy
Rats, lol my buddys parting out a stang 5.0
So if I had both sitting side by side same condition/price. Which would I be better off getting?doesnt the camaro have a 350?..why woulndnt it hold up? thanks!
John
Old 04-29-2010, 09:54 PM   #54
mongoose
mongoose's Avatar
because camaros don't weight 5K + lbs nor tow/haul another 4K on top if it..
and mustang trans wont fit.. they have a longer input shaft.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-29-2010, 10:58 PM   #55
oldblue1968chevy
So..what manual trans. would be best for me? (on floor)
John
Old 05-05-2010, 12:25 AM   #56
Mister laugh
If you are pushing 300hp and want overdrive in a manual transmission for a truck you probably want an NV4500. Its definately a truck transmission though, and shifts as such.
Old 05-21-2010, 05:53 PM   #57
raycow
If you're going to thrash it, my vote would be for a Tremec TKO. It is strong, easy to shift, and offers a choice of shifter locations. Its only real downside is cost, because it is an aftermarket-only transmission. In other words, used ones don't come up for sale very often. It couldn't hurt to keep checking the ads though.
Ray
raycow is offline   Reply With Quote
Old 05-21-2010, 05:57 PM   #58
oldblue1968chevy
Yeah...$ is an object id just as soon hunt an ol 4spd for that, or maybe nv4500
John
Old 05-23-2010, 11:33 PM   #59
Old Bluey
Old Bluey's Avatar
I'd go hybrid. NV4500 (if I'm not mistaken) will require more work to build a hydraulic clutch around it. The hybrid will give you the ease of install (bell housing & clutch linkage) and will give you good highway gears.
But that's also my plan for my winter project, so I'm a little jaded.
Old Bluey is offline   Reply With Quote
Old 07-14-2010, 11:18 AM   #60
splehigh
splehigh's Avatar
Nice write up! How is the tranny holding up? Have you put many miles on it so far?
splehigh is offline   Reply With Quote
Old 07-14-2010, 12:19 PM   #61
oldblue1968chevy
whats the nv4500 come in, doesnt it have grannty 1st? And wheres the shifter at with a bench seat 67-72?
John
Old 07-14-2010, 01:05 PM   #62
raycow
Yes, granny 1st. This is a truck transmission and it shifts like one. Think of it as an SM465 + an overdrive 5th gear. It was standard in 3/4 ton and larger trucks starting in the early 90s and optional in 1/2 ton trucks.
The shifter is fine for bench seats, about in the same place as an SM465.
Ray
Old 08-11-2010, 12:37 PM   #63
Kas68c10
Kas68c10's Avatar
Wow, excellent thread!! Wish it was around 10 years ago when I did mine! Exactly it, camaro trans, s-10 shaft, into a short bed, works great!
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 08-16-2010, 06:11 AM   #64
5264chevytrucks
Wow! There is so much good info in these post. I will be looking this up when I get back from Afghanistan to complete my project.
5264chevytrucks is offline   Reply With Quote
Old 08-16-2010, 08:20 PM   #65
oldblue1968chevy
thank you for serving this country!!!!
Cant wait to see your install!!!!
John
Old 10-12-2010, 10:46 PM   #66
Sterlingdeville
Sterlingdeville's Avatar
Talking Re: How to install a Camaro T-5
Greetings all. I enjoyed reading EVERY post and reply in this thread, but am still at a bit of a loss (probably based on my own inexperience), so please humor me with my question.
When I first got my 70 C10, I managed to get about 30 miles on it before shooting a rod through the block. Come to find out I was the 6th owner, and have spent lots of time undoing other people's shenannigans- including speaker wire from the starter to the igniton. I now have a 350 with a mild cam (+/- 300hp) and a 3 speed tranny w/ (what has been guestimated to be) a 4:11 rear end - (tranny and rear end were in the truck when I got it). I turn about 3500rpm @ 85mph (only when passing, of course..ahem).
What manual tranny can I stick under the truck, utilizing a mid-shift position (bench seat now), that will allow me to have good takeoff, haul reasonable stuff, and still have overdrive? Is it the T5, the Tremec TKO, or the NV4500 for the specs I listed? I read that a similar post was dissuaded from using the T5 with his 350. I like to zip down the highway, but the 70 is my daily so I need something reliable for LOTS of shifting. I'm not rich, but I am very good at finding things when I know what I am looking for. I'd prefer to stay under $1000 for the transmission.
Thanks in advance for your patience and advice!
Sterlingdeville is offline   Reply With Quote
Old 10-13-2010, 12:02 AM   #67
raycow
Originally Posted by Sterlingdeville View Post
What manual tranny can I stick under the truck, utilizing a mid-shift position (bench seat now), that will allow me to have good takeoff and still have overdrive? I read that a similar post was dissuaded from using the T5 with his 350.
This may call for a new thread, since we are getting rather far afield from the original topic. However, that would up to the mod.
First off, you CAN use a T5 behind a 350, but you would have to drive it like you own it. Don't even think about dumping the clutch if you have wide tires. If this isn't your driving style, look for something stronger.
If you have a 3 speed in there now, you could look for a 3 speed + overdrive. This was a factory option up till about 69. It is basically a bolt-in and you could even use your stock column linkage if you wanted to. Actually, the 3 speeds aren't really a whole lot stronger than the T5, so if you haven't blown up your 3 speed yet, maybe you could get away with a T5.
Next up the line in strength would be a NV3500 5 speed. These were factory installed starting in the late 80s and GM considered them strong enough for a 350. The main problem with this one is installation. You will need hydraulic clutch linkage and you will lose your stock bellhousing mounts, and all of them that I have seen had an electric speedo drive.
IMO, a better choice than the NV3500 would be an A833, or MY6 as GM called it. This is a variant of a Mopar 4 speed that gives you 3 speeds + an overdrive 4th, and it was used in mid 80s trucks. It is probably stronger than the NV3500 and definitely easier to install. Its only real downside is scarcity.
If you need something still stronger than these, your choices are the NV4500 and Tremec TKO 5 speeds and the T56 6 speed. The TKO is the easiest to install, but also the most expensive, because it is aftermarket only and was never used by an OEM. The T-56 came in 4th gen Camaros. It can be bolted to your stock bellhousing with an aftermarket adaptor plate and it needs an aftermarket shifter re-location kit to clear a bench seat.
The NV4500 is a heavy duty truck gearbox and it shifts like one. If you can find a Dodge version it will bolt to your stock bellhousing with an aftermarket adaptor plate. To use the GM version you will need hydraulic linkage or an aftermarket bellhousing.
There is one more possibility I have read about, but have no hands-on experience with. It is a Japanese AX-15 5 speed used in Jeeps and is similar to the Toyota Supra transmission. This one is at least as strong as the NV3500 and can be bolted to a Chevy bellhousing if you use an aftermarket adaptor plate.
Ray
Old 10-13-2010, 12:31 AM   #68
Sterlingdeville
Thumbs up Re: How to install a Camaro T-5
A thousand thanks, Ray, for your direct and full explanation. I have a floor shifter (a ridiculously tall floor shifter-"http://s54.photobucket.com/albums/g81/sterlingdeville/?action=view&current=shifter.jpg"), not the column shifter, but I think that I can use the info you provided me with to make an informed decision. Again, thanks a ton.
Rod
Old 12-18-2010, 07:00 AM   #69
Rustybaggs
I really like this Idea. At first, I though it would be nice to have a modern drivetrain with an auto tranny out of a Later chevy truck. But now....I'm think'n 5 speed with a 6.0L vortec....oohh yea.
Rustybaggs is offline   Reply With Quote
Old 12-24-2010, 11:34 PM   #70
Rustybaggs
ooops,
I meant to say , I'm think'n t56 with a 6.0Lvortec. Or just the engine/tranny from a Gen IV or newer camaro/firebird/corvette. Since after reading this thread again, I've realized the T-5 tranny wouldn't hold up very well behind a 6.0Lvortec.
If someone has done this sort of engine/tranny swap with there truck, I'm all ears. Once I return from Iraq (in about two months) I will have a 67' stepside that's in need of some TLC.....and some kick--- goodies!
Thanks to All,
this thread has difinetley open my mind to other possibilities.
Old 01-01-2011, 11:53 AM   #71
N2TRUX
Happy to be here
N2TRUX's Avatar
This post is a FAQ topic located here- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-18-2011, 08:03 PM   #72
Old School Kid
Rottenwood Garage Member..Yes!
Old School Kid's Avatar
O.K ... I've read this a few times and am trying to get my info straight...
I have a 68 with a 250 and 3.08 rearend.... I am wanting to put a t-5 behind the 250.. ( I have a lead a 96 t-5... )
My question is will the s-10 1996 t-5 work behind the inline 6 250? What things will I need to do.. look for ? need?
Thanks for all and any help?
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way.
My 65 (SOLD)
http://67-72chevytrucks.com/vboard/s...d.php?t=317013
My 51 (SOLD)
http://67-72chevytrucks.com/vboard/s...80#post3551880
Racetruck III (SOLD)
http://67-72chevytrucks.com/vboard/s...72#post4254972
Rottenwood Garage and Speed Shop.....where everything must be racy!
Gone to dark side for a while...1966 F100 in the stable
Old School Kid is offline   Reply With Quote
Old 02-16-2011, 09:40 PM   #73
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Me too, or maybe a automatic tranny behind my st8 6,
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 02-17-2011, 12:03 AM   #74
Strider
Strider's Avatar
OLD SCHOOL KID,
YOu have a 3.08 rear end? Is it a factory rear? What trans do you have right now?
Putting a T5 in behind your 250 is easy. Just get a bellhousing and make sure your 1996 T5 has the chevy/muncie bolt pattern because it may not. Hamilton Intakes has info on its website regarding different T5 transmissions and you can check yours there.
1967 C-10 250 I6 w/ TH350 3.08 10 bolt HUGGER ORANGE aka "The General"
'57 GMC short step REGINA SPECIAL
2013 CREW CAB SILVERADO 5.3 6 SPEED Z71 WHITE DAILY DRIVER
"When you have eliminated the impossible, whatever remains, however improbable, must be the truth." ~Sherlock Holmes
"Deeds will not be less valliant because they are unpraised." ~ Aragorn
Strider is offline   Reply With Quote
Old 02-28-2011, 03:45 AM   #75
weekendracer728
weekendracer728's Avatar
What do you use for a output yoke? A camero one or the old one on the four speed??
Live life one weld at a time.
'04.5 Chev Duramax CCLB- Winter DD
'03 Grand Prix GT- Summer DD
'67 C10-307/T5(For Now)-R.I.P-Burned Up!
'68 C10-5.3/4L80E
www.one-guys-garage.com
weekendracer728 is offline   Reply With Quote
