Old 07-06-2010, 12:57 PM   #51
ambryatim
ambryatim's Avatar
Re: Adjustable rear trailing arms how-to
How far is it from the end to where the bend (angle) starts?? I would like to build these, but I dont have any arms to use as a template. Awesome work everyone. I plan on putting this TA suspension on my 1957 truck.
Originally Posted by bmfpeterson View Post
Here are a couple pics of what i have built..... I am waiting for a friend to machine the solid stock to slide into the arm and tap it for the hiems joint.
ambryatim is offline   Reply With Quote
Old 07-06-2010, 03:27 PM   #52
SCOTI
SCOTI's Avatar
I would highly recommend finding some OE arms to use as your template & not rely on internet provided measurements because the 'bend' is very mild making it hard to be 100% accurate (one guy measures this way while another measures that way).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-06-2010, 03:35 PM   #53
ambryatim
ambryatim's Avatar
Very true Scoti....do you know of anyone that might have some they want to get rid of or that I might be able to use as a template?? I see you are in Dallas I am in Corinth about 30 miles north of you. But, seeing how they are some what adjustable one could always just adjust them where they need to be, if the measurment was not botched.
Old 07-06-2010, 05:29 PM   #54
bmfpeterson
bmfpeterson's Avatar
I'll try and measure mine. the point where it starts to bend is a little difficult to get exact but I think there is enough adjust on how you build it to make it work. I am sure that the angle was 15 degrees where it kicks up. Ill measure tonight and let you know what I come up with!
I have a stock set of arms painted with new bushings if anyone wants them let me know...
bmfpeterson is offline   Reply With Quote
Old 07-06-2010, 05:31 PM   #55
SCOTI
SCOTI's Avatar
I have a set I use for 'set-up' purposes. You're more than welcome to borrow them if you don't mind driving my way (Garland side of Dallas).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-06-2010, 05:43 PM   #56
ambryatim
ambryatim's Avatar
Ok, I might just have to swing by and do that Scoti. Thank You very much. I will PM you when I am ready if that is ok.
Old 07-06-2010, 06:02 PM   #57
SCOTI
SCOTI's Avatar
Not a problem. I'm real close off of 635 in the Garland area to give you an idea on travel.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-06-2010, 10:54 PM   #58
ambryatim
ambryatim's Avatar
Ok, cool that is actually not that far. I have another problem at the moment, was going to weld in my Trans Am clip and noticed that it looks like it is more to one side, (giving it the ole eye ball measurment) but it is aligned with the frame rails on the inside. So, who knows. I measured 24 times then tacked it in place.......a little frustrated at the moment.
Old 12-06-2011, 12:51 PM   #59
bmfpeterson
I forgot about this thread and came across it searching around. I wanted to post a pic of my arms finished and see what you thought!
Old 12-06-2011, 02:21 PM   #60
theastronaut
theastronaut's Avatar
I don't like this forum anymore! Yall give me these ideas that get stuck in my head so that I eventually have to spend more money for parts I didn't know I needed, and go out in the shop and spend more time making upgrades that I didn't know I needed!
Seriously though, slick work on the trailing arms! I just may have to do this on my '66.
theastronaut is offline   Reply With Quote
Old 12-06-2011, 06:01 PM   #61
bmfpeterson
I hear that, I started out with just a nice little drop and clean it up a little............. 4 years later and I dont even want to know how much Im still not even close to being done! lol
Thanks Im pretty happy with how they came out!
Old 12-06-2011, 06:47 PM   #62
dnd1978
dnd1978's Avatar
HAHA!!! I know what you mean! Check out what i had to build after i read this thread...
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 12-06-2011, 07:25 PM   #63
bmfpeterson
Way cool! I wish I would have thought mine a little more through and I would have adjusted the angle where the rear end bolts to, so it would correct my pinion angle.........
Old 12-07-2011, 03:43 AM   #64
whiteheadcycle
dnd1978 - what size tube did you use for your trailing arms? 1.75x.120?
whiteheadcycle is offline   Reply With Quote
Old 12-07-2011, 09:39 AM   #65
dnd1978
dnd1978's Avatar
Yes,
tubing is 1.75x.120.
bag plates are .250
diff. mounts are 2 pieces of .120 steel plate welded together = 3/8 thick.
I had more pictures but then I upgraded the S/W on my iphone I lost them all…
Old 03-21-2012, 06:46 PM   #66
nuke1
nuke1's Avatar
Just came back to tthis thread for a bit and there si some really neat ways of doing this mod!!! congrats to everyone that has taken my idea and gone wild with it!!!!!!!!!!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 04-10-2013, 02:47 PM   #67
gofastnut
gofastnut's Avatar
Hmmm....I've got a good welder, a cheap angle finder, and a wife that just went back to work. I think I'll have to seriously consider this instead of upgrading my old arms.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 03-09-2014, 04:32 PM   #68
64chevtruck
This is what I was thinking too.
Good fab work guys and thanks for sharing info.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 03-10-2014, 08:20 AM   #69
crakarjax
crakarjax's Avatar
I'm no expert, but wouldn't rectangular stock be stronger than cylindrical in this application?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 08-17-2016, 09:36 PM   #70
firedemon
don't know how I missed this one way cool
firedemon is offline   Reply With Quote
Old 01-25-2017, 07:41 PM   #71
70FarmTruckBob
I am building a set of trailing arm's for my 1970 GMC 3/4Ton Truck. It came with Leaf Springs on it but also had the OE trailing arm crossmember already in place in the frame. So i'm going to build the trailing arm's myself. I'm going to be using Steel 3 x 2 x .180 wall 6 foot long. I Really Need a Blue Print of it. But any HELP, measurement's or angle's would be Really Grate. Cause i have nothing to go off of your by. Thank you in advance.
70FarmTruckBob is offline   Reply With Quote
Old 06-19-2020, 10:13 AM   #72
mookandairin
Old thread i know but I just read: "A wife that WORKS"????? You lucky ......! That is the answer to ALL of my prayers! I've been trying to get her to try that now for about 10+ years. It sure would make it easier to get the truck done But, it aint looking too good. lmfao
mookandairin is offline   Reply With Quote
