Old 03-23-2010, 05:10 PM   #51
Tynee
I miss this truck.
Tynee's Avatar
Re: Need help with wiring stock temperature and vacuum gauges
I bet you drove all the way home staring at the temp gauge...
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 03-23-2010, 11:23 PM   #52
Green Monster
Green Monster's Avatar
Yeah... that's funny. One eye was staring at the temperature gauge and the other staring at the vacuum gauge. I was concerned about the temperature. The needle rests dead center. Jim even called me to check in with me to see how the gauge worked. I'm happy with the gauges. I just need a little help finding the wires to rig up the amperage gauge and all the gauges will be up and running.
Green Monster is offline   Reply With Quote
Old 03-24-2010, 03:41 PM   #53
jaros44sr
jaros44sr's Avatar
Your welcome , but you did all the work
That truck of yours is a time capsule, pictures don't do it justice! I was afraid to touch it...
Next step before the amp, let's do the fuel filter fitting, I would feel better having that situation corrected. Amp shouldn't take more then a few moments
Right after Easter good for you? I have a fishing trip this weekend
Hey, it was great to finally meet you, had fun! We'll do a cruise soon
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-25-2010, 10:18 PM   #54
EFI70Blazer
Active Member
EFI70Blazer's Avatar
I went through this process when i bought my Blazer. Basically had to redo the wiring from the firewall out with connectors like the one below to make it look like factory again. Also had to fix a lot of my under dash wiring too. Everything works now, but it took a lot of work tracing out the wire and making it good again.
Here is a shot of how i routed my temp sensor wire. Basically goes along the intake connects to the water pump and goes back from there. Did not have any of the asphalt loom, so i substitued the split loom.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 03-25-2010, 10:50 PM   #55
jaros44sr
jaros44sr's Avatar
Hey Mike, great pics!! Is that a quadrajet, sorta looks like it...GM and I need some help with the wiring of the solnoids and vacuum lines. Could you take some more specific pics for us
I got my wire loom from M&H Fabricators
SAFETY FIRST
AS usual, off topic
Jim
Old 03-27-2010, 01:59 PM   #56
EFI70Blazer
Active Member
If you let me know what pics you need i can see what i can do. Not sure i can help with the vacuum lines, because none of mine are hooked up right now. I need to go through my A/C unit and get everything hooked back up on it when i get parts for it.
By the way, my carb in a quadrajet. Always been a fan of them, because once you get them set you never have to mess with them again.
Mike T.
Oregon
70 GMC Jimmy 4x4
Old 03-29-2010, 09:21 PM   #57
Green Monster
I would like to resolve the fuel line and amp issues sooner than later. I appreciate the offer. After Easter is perfect. You pick the weekend. As long as the weather is good and my event coordinator (wife) does not have anything planned then I'm in.
Old 03-30-2010, 12:49 AM   #58
jaros44sr
jaros44sr's Avatar
Well, that answers one of my questions! If I don't need the vacuum lines hooked up, I should be good to go. Our problem is the solenoid in the front of the carb, neither one of us has a wire to go to it. My thoughts were that the pink wire off of the electric choke could be jumped to the solnoid. Any input would be great
Maybe the first weekend after Easter...lmk
Hey, keep that core sterile and aceptic
SAFETY FIRST
AS usual, off topic
Jim
Old 03-31-2010, 04:32 PM   #59
Green Monster
April 10th or 11th?
Old 03-31-2010, 05:53 PM   #60
jaros44sr
jaros44sr's Avatar
April 10th or 11th?
you pick,lmk
SAFETY FIRST
AS usual, off topic
Jim
Old 04-01-2010, 12:14 AM   #61
EFI70Blazer
Active Member
Not sure what solenoid the carb has. Could you take a picture of it, so i can see what it is? I did look in my assembly manual and found a diagram that might help. It has two wires going to the carb to a switch. One is orange and the other is pink. I can try to scan it if that will help you.
Mike T.
Oregon
70 GMC Jimmy 4x4
Old 04-01-2010, 12:42 AM   #62
jaros44sr
jaros44sr's Avatar
Thanks Mike for taking the time, I'll try to track down the orange wire. Give me alittle time to take a pic
SAFETY FIRST
AS usual, off topic
Jim
Old 04-13-2010, 09:30 PM   #63
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I really like your setup. Can you clarify what you used (items A, B, C, and D)?
A Vacuum gauge. Male pipe thread? Male compression thread? 1/8" diameter? 1/4" diameter?
B Adapter. Female on both ends?
C Barb fitting.
D 1/4" vacuum line.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 04-15-2010, 04:12 PM   #64
Green Monster
It's actually three parts there. I did use 1/4" vacuum hose. I'll check the package for the two brass fittings to give you the exact part sizes. I bought them from Home Depot so you should be able to get your hands on them pretty easily.
Old 04-16-2010, 01:19 AM   #65
jaros44sr
jaros44sr's Avatar
John, is your engine grounded to the frame and is your radiator core support grounded to the frame???
SAFETY FIRST
AS usual, off topic
Jim
Old 04-17-2010, 12:40 PM   #66
Tbruz
Love the Green Monster. My dash looks unfinished without the vacuum gauge.
Where do we get them?
Were these vacuum gauges available as factory options, dealer installed options or retrofitted from other GM products?
Thanks,
Tbruz
Tbruz is offline   Reply With Quote
Old 04-18-2010, 01:06 PM   #67
capev86
the vacuum gauge was a rare factory option on the 67-72 trucks. that is why there is a blank opening in the dash cluster between the steering column and oil pressure gauge. there is an aftermarket retrofit kit available from several vendors. it requires the clear plastic lens w/ the word vacuum instead of a faux imgage, the inner bezel with the half moon punched out for the gauge to be visible and the back panel where the oil and vac sending units come out as well as other bits. the tach is taken into account 'cause anyone would want a tach also and it always came with the tach option also so the cutouts in the bezels and tach numbers on the clear lens are there. only problem is you don't get the a sending unit.
my home depot did not have the parts, but a local auto parts store should be able to supply you with brass-tite 43050 (1/8" npt female/ 1/8" npt female coupling) and brass-tite 43276 (1/8" npt male to 1/4" hose). i may have to replace the straight coupling with a 90 degree one on my 72 burb because part of the manual trans swing arm (3 on the tree) is right behind the vac gauge.
[IMG][/IMG]
[IMG][/IMG]
capev86 is offline   Reply With Quote
Old 07-10-2018, 07:51 PM   #68
Jcjarvis
Hey guys! I'm kind of late to this party but I'm a bit perplexed. I'm restoring a '69 and I'm sorting out the wiring with the help of a factory diagram (all wiring was disconnected and gauge cluster removed when I got the truck).
On my temp gauge wiring, I've located the dark green wire in engine bay that goes to the sensor. Under dash I've also located dark green wire to gauge cluster harness connector. Unfortunately there are no dark green wires going to ignition switch nor are there any dark green cut wires anywhere that would have gone to ign switch.... I've undone the entire harness.
So where should this mia wire be going exactly from the ign switch? This truck may have had an idiot light cluster originally but I'm using a gauge cluster so different wiring possibly? Any help would be greatly appreciated! Jim
Jcjarvis is offline   Reply With Quote
Old 07-11-2018, 06:52 PM   #69
87Skier
87Skier's Avatar
Really bringing a thread back form the dead!
I recommend testing continuity on the wire from the cluster to the sender. It isn't necessary to switch the Dark Green wire since the gauge requires a 12v switched power source. If there is continuity and you have 12 volts you are good to go.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 07-11-2018, 11:28 PM   #70
Jcjarvis
Thanks, I’ll test the sensor wire. I’m thinking I might have gotten a bad sensor, I hear it’s not uncommon.
Old 07-12-2018, 04:00 PM   #71
Jcjarvis
Got 12 volts to switch with ign on so must be switch.
