Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-30-2010, 10:27 AM   #51
bigarmzz
bigarmzz's Avatar
Re: Impala SS Rear Disc Brake Brackets
Originally Posted by Captainfab View Post
Yes they will work, and yes I do have these in stock. I did slightly redesign them though.....just mainly gave them a little more shape instead of just a rectangle. I've just been busy and haven't posted new pics yet. Let me know how you would like to make the payment. I acept PayPal and money orders. You should be able to use a credit card thru PayPal as well.
pm sent to ya
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 03-30-2010, 02:09 PM   #52
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
If these are anythjing like the first set I got they will be top notch. Very nice workmanship.
--Josh
Old 03-30-2010, 11:31 PM   #53
Captainfab
60-66 Nut
Here is a pic of the new redesigned Impala SS caliper brackets. The hardware is the same as before so I didn't include that in the new pic.
Old 03-31-2010, 12:28 AM   #54
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
any pics of the guys trucks that have bought these brackets?
staggerd86c-10 is offline   Reply With Quote
Old 03-31-2010, 03:55 AM   #55
80stepsideguy
Laid back freak
80stepsideguy's Avatar
Captfab,
ill take a set as well i am looking to turn my rear setup from drum to disc and this will look alot better in the backsides of the 20s i got on my truck
thanks
pat
1980 chevy c10 step side restomod,
1970 cougar convertible 1 OF 24 ever built:
2014 Hyundai Tucson limited (daily driver).
80stepsideguy is offline   Reply With Quote
Old 04-01-2010, 12:24 AM   #56
Captainfab
60-66 Nut
Sorry but no I don't have any pics other than what I've posted. I have hinted to a few customers about posting pics, but so far no one has that I'm aware of.
Pat, I'll send you a PM. Thanks
Originally Posted by 80stepsideguy View Post
Captfab,
thanks
pat
Old 04-01-2010, 12:57 PM   #57
creep
Registered Loser
creep's Avatar
Shot in the dark here, but do you know if they will fit an 8.2 10 bolt from a Chevelle? If not could you give me some dimensions like the offset of the SS rotors, how thick they are at the wheel mounting surface and the distance from the backing plate flange to the axle flange on the 12 bolt rear end?
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-01-2010, 11:05 PM   #58
Captainfab
60-66 Nut
No these brackets won't work on a 8.2 passenger car 10 bolt. The axle tube flange has a different bolt pattern and the Impala SS rotors won't fit since they are a 5 x 5 bolt pattern and the 10 bolt you have is 5 x 4.750 Of course you could drill some holes and they might work, but I don't know if the calipers and rotors would line up on the 8.2 10 bolt.
I'll have to look up those dimensions and get back to you.
Old 04-02-2010, 02:34 AM   #59
creep
Registered Loser
creep's Avatar
Thanks. I'm going to have my axles redrlled to 5x5 to match the front, just hoping I wouldn't have to do rotors too.
Old 04-02-2010, 04:32 PM   #60
Captainfab
60-66 Nut
From the inside of the hat to the inside surface is about 2.090"
The one I have here measures .242"
That varies from 2.437" to 2.500" depending on how the gears are setup. The bolt pattern on the axle tube flange is 2.625" vertically and 3.375 horizontally.
Old 04-02-2010, 05:13 PM   #61
68 TT
Still plays with trucks
68 TT's Avatar
The car housing end bolt pattern is 3-1/8" apart on the top, 2-11/16" apart on the bottom and the sets are 2-7/16" apart top to bottom.
If the hole in the middle of the bracket is small enough you could just redrill the plate for a dual bolt pattern so it fits cars and trucks.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-02-2010, 09:20 PM   #62
TheWraith
interested in a set, just want to make sure you have a set before i paypal. thanks.
TheWraith is offline   Reply With Quote
Old 04-03-2010, 01:06 AM   #63
Captainfab
60-66 Nut
As of right now I am out of these. I've been busy on a new brake conversion, so I haven't ordered any more of these just yet. If need be I can get more parts for these in 2 days.
Old 04-06-2010, 05:51 PM   #64
bigmone
?Do these work on 90 silverados?2wd?If so Im game
bigmone is offline   Reply With Quote
Old 04-07-2010, 12:05 AM   #65
Captainfab
60-66 Nut
As far as I know they do. Tell you what, I have a '90 as well, so let me verify that they are going to work before I go and sell you a set. I should be able to determine that tomorrow.
Old 04-08-2010, 09:07 PM   #66
bigmone
That would be great I was gonna get the Kore brackets but these look like they will do the job also.I will run s10 front calipers in the back and keep it rolling
Old 04-09-2010, 12:13 AM   #67
Captainfab
60-66 Nut
Sorry I didn't get around to pulling a wheel off and checking that out. I will do that either tomorrow or Saturday. You won't be able to use S10 calipers on these brackets. They will only accept the '94-'96 Impala SS/Caprice rear calipers.
Old 04-09-2010, 01:21 AM   #68
Bazooka
Keepin it old school
Bazooka's Avatar
To install these on a 63 12 bolt I would just need to redrill my axles (i have 6 lug now) and grind the rotor a little to allow it to seat on the axle? Rest is bolt on?
Would someone that has done this share with us what they spent on the rest of the parts needed?
Bazooka is offline   Reply With Quote
Old 04-09-2010, 02:09 AM   #69
Captainfab
60-66 Nut
Yes you would need to convert to the 5 x 5" bolt pattern on your axles. I don't think you would need to 'grind' on your axles. The one thing you need to check though, is the '63 12 bolts had pressed on backing plates. So without the typical backing plate flange, you can't bolt on anything. I would check yours though. It may be a late '63 or it may have been changed at one time.
The most expensive part of this conversion is buying the rebuilt calipers. Loaded ones are around $125 ea. plus the core charge. you can sometimes find good used ones locally, on ebay, or on car-part.com
I'm planning on developing a 6 lug rear disc conversion in the near future if that helps you any.
Old 04-09-2010, 04:09 AM   #70
Bazooka
Bazooka's Avatar
ah crap I think I have the pressed on backing plates. I didn't even think about that. Was thinking about going 5 lug so I could run some old school wheels like cragars or supremes. Might have to just do what I was thinking of doing which is drill the axles for 5 lug and get 5 lug drums from ECE
Old 04-09-2010, 04:16 PM   #71
80stepsideguy
Laid back freak
Just received my plates this week.Man they look awesome.Now to have em powdercoated and i just bought my calipers and rotors for a 95 impala SS total was 181.00 w/o the cores.I should go pick up a junk set of calipers somewhere..
Thanks again captfab for the sweet plates.I`m really considering pulling out my spare rearend i got laying over here, gut it clean, have the housing powdercoated and put some new gears in it w/ a locker...
thanks
pat
Old 04-09-2010, 05:20 PM   #72
bigmone
Hmm so thats the kicker..you have to use Impala calipers..Ill read through this thread to see what brake hoses are needed or if I can just get some made at the local hydraulic hose shop..If the rear ends on the other trucks are the same they should work just fine but I can wait for your word thanks again
Old 04-10-2010, 02:13 AM   #73
Captainfab
60-66 Nut
Well bad news.....these will not work on a '88 and up rear end. I thought they would, but the bolt holes on the axle tube flange are different and the distance from the axle tube flange to the axle flange is more than the '87 and earlier rear ends. Good thing I checked.
If there was enough interest I could design a set for the '88 and up rear ends.
Old 04-10-2010, 08:38 AM   #74
bigmone
Well I'll go ahead and tell u... The interest is there I know I want to do mine.. If you post in that years forum they would sell like hotcakes lol
Old 04-12-2010, 01:07 PM   #75
68 TT
68 TT's Avatar
The 88-up rear is a popular upgrade for the square body trucks since it moves the rear wheels out so they are closer to the track width the front have stock.
The modified brackets should sell well to the new body style trucks and to the square body guys who have retrofit their trucks with the newer rear end too.
You shouldn't have a problem selling the revised brackets.
