Old 01-08-2010, 12:18 PM   #51
LooseCannon
Re: Bagged 05 Suburban
Put in some time last night after work on the rear bags and finished plumbing the air lines to the manifold.
Attached a schrader valve to some line and bench tested the rear bags for leaks with soapy water.
Drilled a hole with a hole saw in the upper spring perch and used a cutoff wheel to trim the rest for access to the air line fitting. Mounted the bag and ran the line.
The shocks allow the rear end to drop farther than the bags can extend so I ordered a pair of 18" limiting straps to attach to the shock mounts.
Finished running and securing the lines to the manifold.
Next is to run the electrical, modify the exhaust over the rear end housing, and install the rear height sensors (once the straps come in). Getting closer!
LooseCannon is offline   Reply With Quote
Old 01-22-2010, 04:40 PM   #52
LooseCannon
Anyone want to stop by and help with the wiring?
Lifted the main fuse box to tap into a "key hot" wire. Note: the labels on the fuse box lid are not correct. Took me forever to locate the proper wire.
The 5 wiring harnesses, that need routed to the rear, need lengthened by about 8 feet. Also, there's not enough room to run the wires under the burb without dropping the gas tank (one would think that there's plenty of room with a vehicle this size) so I'm running them inside the cab.
Drilled two 1" holes (didn't have any 2" grommets) for the harnesses to enter the cab. Behind the rear fender well there are 2 more holes where the wires exit.
I started extending the harnesses last night but ran out of solder.
Old 01-22-2010, 04:52 PM   #53
VA72C10
VA72C10
VA72C10's Avatar
Looking good...a part of the build I'm not looking forward to....have a new harness as well as the accuair harness to run and I am going to do whatever I can to hide them.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-15-2010, 02:07 AM   #54
stepside83
stepside83's Avatar
looks good man keep the pics comin
stepside83 is offline   Reply With Quote
Old 02-18-2010, 04:57 PM   #55
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Did you get it back on the road? I just bought an 01 tahoe and I may bag it in the future, I'm curious to see how yours turns out. So far great work!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 02-19-2010, 09:33 AM   #56
LooseCannon
Thanks.
Thanks. It's not on the road, yet. Currently re-working the exhaust to clear the rear end.
Old 02-22-2010, 02:26 AM   #57
miracle whip
miracle whip's Avatar
Verry nice! i installed a kit on my truck b4 they had anything at art. im happy with mine but wish art would have had a kit back then.
miracle whip is offline   Reply With Quote
Old 02-28-2010, 09:30 PM   #58
LooseCannon
Nice!! Any suspension shots?
Old 02-28-2010, 10:06 PM   #59
LooseCannon
The exhaust hit the rearend when aired out so I lengthened it about 3" in order to raise and clear the axle tubes. I used pieces from a 3" "J" pipe from Jegs.
Pieces cut and tacked together for fitment. If you look close you'll notice that they're cut at an angle to provide the necessary bend for clearance.
Had to drop the exhaust to fully weld around the pipe.
The "U" bend over the rearend is within inches of the passenger rear bag so I wrapped that portion of the exhaust in high temp header wrap, probably overkill but better safe. Also, the exhaust was too long to install as one piece so I added a collector to install as two pieces.
The exhaust tip hung down too low and stuck out too far for my taste.
So I cut it off and built a new piece from the "J" pipe. It looks MUCH cleaner now than from the factory.
Now that the exhaust is complete I wish that I would've listened to my wife and had an exhaust shop do the work. Working under it while on jack stands and installing removing the exhaust multiple times was not fun .
Old 02-28-2010, 10:28 PM   #60
drivewaycustoms
drivewaycustoms's Avatar
I think you did a better job than an exhaust shop would have done. lookin' good.
87 Crewcab Dually
66 Cadillac Sedan deVille
55 Chevy Belair
33 Plymouth sedan
03 S-10
86 S-10 Blazer
IG drivewaycustoms
drivewaycustoms is offline   Reply With Quote
Old 02-28-2010, 10:45 PM   #61
VA72C10
VA72C10
VA72C10's Avatar
Really like the new exit. Nice work.
Old 04-01-2010, 01:29 AM   #62
Jacfourteen
You have it on the road yet? Where are the pictures of it aired out? I just thought of this post today and was wondering how it all turned out.
Old 04-16-2010, 09:59 AM   #63
puppetmaster
puppetmaster's Avatar
Looks awesome. Thinking about doing this to my surburban. Maybe with the same type of rims. Great work.
puppetmaster is offline   Reply With Quote
Old 04-18-2010, 01:19 AM   #64
Vega_67C10
Vega_67C10's Avatar
That's going to look sick. Keep up the good work. Are you going to strip that stock molding? IMO it would set it off.
I Saw Elvis at 1000 Feet - John Force
Vega_67C10 is offline   Reply With Quote
Old 04-18-2010, 01:40 AM   #65
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Awesome work! Its gonna be sweet!
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 04-20-2010, 09:54 PM   #66
LooseCannon
Thanks guys! More updates soon to follow...
Old 04-23-2010, 10:37 AM   #67
LooseCannon
Over the past weeks I completed the wiring, had the drive shaft shortened, installed the limiting straps and rear sensors, shortened the rear sway bar links, and a million other little things.
Tested the air ride last night for the first time and everything worked great. I left the bags aired up over night and checked them this morning and all held pressure except the LF corner. Also the air tanks leaked down from 150 PSI to 100 PSI, so after work I'll crawl around looking for the leaks with soapy water.
Next week I plan to get it inspected and aligned and give it a good bath! I'll post up some outside pics when it gets back from the alignment shop.
Old 04-23-2010, 11:24 AM   #68
VA72C10
VA72C10
VA72C10's Avatar
Cool! Looking forward to seeing the new stance!
Old 04-27-2010, 02:37 PM   #69
puppetmaster
Love the exhaust... Looks great. I have the high flow cats. I want to add the magnaflow exhaust next.
Old 04-27-2010, 03:15 PM   #70
Jacfourteen
I don't have the full exhaust, just a magnaflow muffler but it sounds awesome.
You won't be disipointed. Oh, and to the board!
Old 04-28-2010, 10:25 AM   #71
puppetmaster
Thanks for welcoming me to the board. I've been a member for a while but never posted. I had a 81 chevrolet stepside in highschool. I built a stout 350 for it and couldn't keep my dad out of it.....LOL I would like to get another squarebody but I do have a 2003 suburban and I'm thinking of fixing it up to take the family on trips. I have big plans for it. Trying to keep it clean but make it stand out at the same time.
Old 04-28-2010, 10:26 AM   #72
puppetmaster
Whenever I start I will start a thread and post pics.
Old 04-29-2010, 08:19 PM   #73
DieselChevyGirl
very cool, my dads partial DD is an 01 burb 2500. we put EVERYTHING in that thing. it's like driving a boat. pulls everything too.
DieselChevyGirl is offline   Reply With Quote
Old 05-05-2010, 02:32 PM   #74
LooseCannon
Took the burb to get aligned this morning and the guy said that he couldn't align it because it was lowered. He basically didn't want the hassle of adjusting the camber cams with having "limited space". Whatever... Time to find another shop.
Old 05-05-2010, 06:17 PM   #75
VA72C10
VA72C10
VA72C10's Avatar
yep, have you tried a stereo/customizing shop to see if they'll do it or recommend where they take their vehicles?
