Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-14-2009, 07:19 AM   #51
Jim_PA
Re: Manual trans guys -- tips for launching?
Ok, here here it is, as complete as I can be. Most of this I already posted
Originally Posted by CreditGod View Post
Ok I have had enough my dad ten years ago built a driving truck that would do 6.70's in the 1/8 and this is what he tells me
A car or truck is built with a purpose in mind daily driver or go fast.
With that being said you have to look at you combination from front to back
Motor exactly what compression are you running no guessing what is it?
9.9:1 (but I did not CC the heads)
ignition are you running a MSD box.
No, MSD digital E-curve Distributor
Intake single plane or dual plane are you using a 3 inch stack plate for low end torque.
Edelbrock Performer RPM dual plane, and no
heads what size runners? what size valves? open chambered or closed chambered.
185 Runners, 2.02/1.6 valves (Performer RPM aluminum heads)
What size springs are you using. what pressure are they set for.
Springs are 120Lbs, good to .575 lift,
do you have a rev kit. what kind of valve guides do you have.
No, and I'm not sure, whatever came in them new
every cam is built to do something different so what is your cam rated at rpm wise.
1800-5800
What type of rods do you have H-beam rods aluminum rods or stock
Stock
what type of pistons are you using forged, hyperutechtic, stock
hyper
what is their bob weight
what kind of crank do you have cast or steal
Cast
What is the weight of you crank.
Whatever a stock one weighs
Is you engine balanced from the machine shop.
Yes!
what carb are you using and how is it jetted
800CFM Qjet, 76 54M Rods, K hanger, Custom cut secondary rods
what spark plugs are you using
Bosch Platinum cross referenced autolite 3926
do you have full length headers or block huger headers
Full
do you have a lightened drive shaft.
No
are you using slicks or drag radials.
Slicks, 26x9 20PSI
are you setting your rear tire pressure up before you do a run in other words setting it up to make a launch and make the truck go straight.
also is your cam timing set up normal or 3 degrees advanced or 3 degrees retard timing
Cam timing is normal
If you will take the time to answer all of this I will be able to tell you what you need do do to get better 1/8 mile times or 1/4 mile times
I just want to try to answer your quest with out any BS
Jim_PA is offline   Reply With Quote
Old 10-14-2009, 09:32 PM   #52
CreditGod
Ok your pistons are good only for about 150 shot of nitros
you need to get your slicks air pressur down to about 10-12 psi
try 10 on the drivers side and 12 on the otherside
any more rpms, and you will start to get valve flot this is when the springs don't have enough pressure to close fast. so you are losing horse power.
get your machine shop to advance your cam three degrees.
if you want to run nitros go with a digital 6al box that away you can flip a switch to change the spark from straight motor to nitros .
also if you are just running straight motor try setting you timming on 34 degrees.
I sent you a pm so when every you want to start kicking but at the track just call me
CreditGod is offline   Reply With Quote
Old 10-16-2009, 11:04 AM   #53
Jim_PA
I'm not into going the NOS route, but I did have a long talk with Harold (who designed the Lunati cam I was looking at...)
He told me the 401A3LUN would make more power everywhere over the 270H, and pull to 6500 without a problem with the valve springs I have.
So, I ordered it, let the fun begin -- see you in the Spring
